Question about TruTech TT1620 DVD Recorder
Humax Tivo will not record to DVD
When I try to record a program from Tivo to the DVD, it begins to record but at the end always has the message "Saving Failed".  The only message is "internal error".  I have tried several different brands of DVD-R's.  It was recording fine previously.  The DVD is built into the Humax Tivo unit.  Thank you.
    Novelist:
  • 141 Answers
Www.funai.us
Customer Support Representatives may also be reached by telephone at 800-242-7158
Posted on Mar 27, 2008
SOURCE:
I have a DVD that is stuck in my TIVO. The screen
Take the DVD player aparts,take out DVD disc out of the drawer,check the open/close drawer button again.Same result indication on the screen say is open infact it close.The motor the help open and the dvd drawer it dead.Need the motor replaced.
Jun 26, 2010 | Humax T800 TiVo 80-Hours Video Recorder
How can i program the Humax remote control (RM-F01) to work with my Sony TV and DVD
In the Setup Menu, Go to Remote,
Select your TV Type and try the different codes.
Jan 30, 2010 | Humax DRT800 TiVo Video Recorder
I can't find a Humax/Tivo repair service san francisco peninsula
Try tivorepair@gmail.com. Services SF Bay Area (Peninsula, San Jose, East Bay). They make housecalls. Can repair and upgrade all Tivo's - Series 1, Series 2, Series 3 (including your Humax)
Apr 16, 2009 | Humax DRT800 DVD Recorder w/ 80 hr Tivo
Cannot get dvd recorder drive to read dvd-rw
manual should tell you to use either dvd(+)rw or dvd(-)rw typ disks
Feb 07, 2009 | Humax DRT800 DVD Recorder w/ 80 hr Tivo
Humax Tivo Stuck on the welcome screen
I just had the same problem with mine and found another post that at least fixed mine.
I had a DVD in the unit as it was restarting. I took a flathead screwdriver and opened up the DVD slot by inserting at the top right corner and opening the door. On the inside, at the bottom right, is a button that ejects the DVD player (the eject button on the outside won't work while it's booting up). I ejected the DVD that was in it, unplugged the unit for 30 seconds, and then it rebooted just fine.
Hope it works out for you too...
Jan 02, 2009 | Humax DRT800 TiVo 80-Hours Video Recorder
Can I use HUMAX like a 24 hour surveillance recorder?
For the TIVO series 2: hit the TIVO button, then go to messages and settings, then to to video input, then go to change input, then pick which input your camera uses. It will ask you if you can see the picture. If you can click the answer and then hit the select button. Then hit the TIVO button again then hit watch live tv.
The Humex should work very similar.
Sep 10, 2008 | Humax DRT400 TiVo 40-Hours Video Recorder
Connecting my Humax Series 2 Tivo to a Motorola HD DCH3416 Cable Box
Yes, the Tivo will just record in standard definition, instead of high def.
You can still hook the two up together, though.
What I would suggest (and have done in the past) is this:
Split the cable coming out of the cable box.
Hook one up to your HD cable box, and the other up to the Tivo.
Hook the output of your HD cable box to one HD input on your TV
Hook the output of your Tivo up to a different (non-HD) input on your TV.
This will allow you to watch HD while recording standard definition, and vise versa.
Running the HD through the Tivo will work, but will limit you to not be able to watch HD through it.
Aug 10, 2008 | Humax DRT800 TiVo Video Recorder
Humax Tivo Recorder
Power cycle the unit. See if the works.
May 16, 2008 | Humax DRT400 TiVo 40-Hours Video Recorder
After the update to 1.15 I had to delete EVERY recording on the unit. After that, any new recordings would burn just fine. However, some have found that same failure even after a hard reboot (repower). Called Humax level-1 support and they suggested a replacement unit so I swapped it out. But I've since learned that TiVo "pushes" a DVD firmware patch (possible supplied by Humax) from 1.08 to 1.15 and that patch is the culprit. That patch is suppose to make the DVD burn at a higher spin rate. After talking with level-2 Humax support they heard of the problem and said "the unit is working as designed", meaning, the DVD drive manufacturer specs say the drive is capable of a faster burn rate. So now I have Humax DTR800 #2 and so-far-so-good, but TiVo hasn't pushed the patch onto the box yet!
Nov 10, 2007 | Humax DRT800 DVD Recorder w/ 80 hr Tivo
TruTech TT1620 DVD Recorder Logo
101 people viewed this question
Top TruTech Televison & Video Experts
Steve Allison
Steve Allison
Joaquim Martins
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
