Back to:
Tags:
Wireless Adapters
Generic problem for all Wireless Adapters
Connecting PS3 via Belkin router to internet,... (by 7 users)
posted by pally on Oct 28, 2007
Please can you explain how I may connect my PS3 via a Belkin router wirelessly so that I may uprade my PS3 o/s via the internet - I have Virgin Broadband connection.
with thanks
Mike Griffiths
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
6 Other Users Have The Same Problem
Comment by Guest, posted on Aug 22, 2008
just wanna play pro online and i keep getting the message
"dns error 80710102"
Comment by Guest, posted on Jul 10, 2008
I'M TRYING TO CONNECT TO MY ROUTER AND i NEED A WEP KEY
Comment by Guest, posted on Jun 29, 2008
Exactly same prob!!
Comment by mileser, posted on Mar 14, 2008
well i got belkin router too and when i try play cod4 with friends of mine its dosn't want to connect everytime it says unable to connect to host. its just my ps3 all my friends can play together apart from me
Comment by Guest, posted on Mar 07, 2008
ps3 is asking me for a system update.. go to do the update and it cuts off after 16% of loading.. why does this happen?
Best Solution
posted on Mar 08, 2008
Helpful (85)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I found thats if you take away any passwords on your belkin wireless box then the ps3 allows you to use the internet and play online
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on connecting PS3 via Belkin router to internet, wirelessly:
I don't want to Accept this solution
Solution #2
posted on Feb 04, 2008
Helpful (85)
Johnny9826
Rating: 85%, 1 votes
im having alot of problems getting the ps3 to connect to my belkin router i am also with virgin broadband, mine will also pick up the ip addresse but keeps getting a dns error, i have made sure the wep key has been entered but it still wont work some one please help im going crazy
Thank You!
Solution #3
posted on Mar 02, 2008
Thanks for Trying (70)
dylan_ho
Rating: 70%, 1 votes
Have you tryed using a ethnet cable from your roter to the ps3
Thank You!
Solution #4
posted on Nov 02, 2007
leevoy
Rating: 70%, 15 votes
hi mike. i have virgin broadband and a belkin wireless router to so let me assure you that it will work. anyway, if you have a wep key, then make sure this is entered on the ps3's settings.if not, then just search for the router on the ps3, it and it should find it with no probs. (make sure the router is no more than 100 metres away from the ps3)
Thank You!
Solution #5
posted on Sep 15, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
me too its so annoying my signal strenght is strong aswell
Thank You!
Solution #6
posted on Aug 14, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
throw away the belkin router they are rubbish buy a linksys one.
Thank You!
Solution #7
posted on May 03, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
there is a box in the route setup page, that says something along the lines of connect unp device. This allow plgu and play connection that the ps3 needs
Thank You!
Solution #8
posted on Dec 27, 2007
Not Rated (0)
Guest
Rating: 0%, 0 votes
I am having the exact same problem as alexsebuliba... Belkin routers really stink as far as my experiences go with them...
Thank You!
Can you Help with these Wireless Adapters problems?
Generic Memory (WLG1203) Wireless Adapter
I do not have the original installation disc (lost it)....
Linksys Rangeplus Wireless Pc Adapter
I have Windows Vista and bought the Rangeplus PCI adaptor,...
Vodafone Mobile Connect (055270) Wireless...
I am using a Blackberry locked for vodaphone use only. I...
fastinnerhtml!
fastinnerhtml!
6 Other Users Have The Same Problem - Continued
Comment by alexsebuliba, posted on Dec 13, 2007
i have a problem. im using a belkin wirless router. when i test for an internet connection, it stats that ip adreess succeded but internet connection failed. due to a dns error??? please can sombody help me. i just want to play pro online. wat do i do???
Loading problems.
Repair Service
Find Wireless Adapter Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
