Fixyahttps://www.fixya.com > ... > Isuzu > Rodeo
1 answer
It's on the inside of the cylinder head at the rear of the engine. Will be hard to see it because the intake plenum hides it. where to locate the camshaft ...
Doesn't include: LS ' Must include: LS
https://www.justanswer.com > Car Questions
Mar 30, 2013 - If you are just testing the sensor, you can check the cam sensor signal at the ECM on pin 11 of connector number 2. It is the same blue wire.
Emission control mechanism or relay is either a vacuum plunger type or a relay switch electrical plug that controls vacuum for the smog. Go to the parts store and look at one and ask where it goes or just trace it. This stops from buying one if you remove the hose or connector and the same problem is still there!
Underhood fuse block swap out relay #7 thats the ECM relay. Ground Circuits Using a DVOM, touch negative voltmeter lead to a good ground. Touch positive voltmeter lead to each ground terminal. With vehicle running, voltmeter should indicate less than one volt. If reading is greater than one volt, check for open, corrosion and loose connection on ground lead. See ECM GROUND LOCATION table for ECM ground location. Page 1 of 1 SYSTEM/COMPONENT TESTS - 2.6L EFI -1994 Isuzu Rodeo
Any car repair manual should tell you how to find the engine numbers. I like the Haynes manual; about $20 at autozone. If you ever plan to do any work on your vehicle it is very handy to have a good repair manual
