GE washing machine water overflowing
GE model:  s3700e1ww (top load washing machine)
last week the washing machine did not stop filling with water in the rinse/spin part of the cottons cycle and flooded the laundry room and hallway before we noticed.  It would not stop when we pushed the control knob back in to turn it off and I ended up shutting the water supply off.  I was able to turn the knob to the drain part of the cycle and the water did drain out.  The next time we ran a load through I watched carefully and it functioned normally in the same cycle, however the next day it happened again but we caught it early enough.  We tried the other cycles (delicates, easy care and power wash) and at first they functioned normally but then they also had the same problem.  I thought it was probably a timer issue and was going to replace it  but thought I would ask an expert first.  Thanks for your time and response
  • 2 more comments
  • moreiv00 Nov 08, 2007
    My GE Spacemaker washer (model WWP 1180G) seems to overflow every couple of cycles during the rinse cycle. I was about to call Sears but figured I would check here first. I figure there is some sort of sensor that is off because it will overflow even with small/medium loads.
  • Halobabe Mar 13, 2008
    I have a GE top load washing machine WBSE2090AZWW and it keeps overflowing! The first time, we thought it was a fluke, because it didn't happen again for a couple of weeks, but it's happened several more times. We know to listen for it now...but it's still a mess to clean up. It just never stops filling with water...and it can happen on either the start cycle or the rinse cycle, so you have to pretty much stay in the laundry room unless you want it to overflow. Turning it off doesn't stop it, either! You have to turn the water off. Help!
  • papanana7 Jul 16, 2008
    My washer is doing the same thing. Is there a part that I can replace?
    Thank you very much.
  • arkadiy16 May 18, 2009
    GE model: WBB3300A0WW (top load washing machine)
    last week the washing machine did not stop filling with water in the rinse cycle and flooded the laundry room and hallway before we noticed. It would not stop when we pushed the control knob back in to turn it off and I ended up shutting the water supply off. I was able to turn the knob to the drain part of the cycle and the water did drain out. The next time we ran a load through I watched carefully and it functioned normally in the same cycle, however the next day it happened again but we caught it early enough. We tried the other cycles (delicates, easy care and power wash) and at first they functioned normally but then they also had the same problem.
Sound like the same washing machine from hell that we have. three or four times it has overflowed from want we have been told the hose that runs from the drum to on/off pressure switch cloggeds with soap. we have tried different soap,hot water,cold,water you name it we've tried it. so now evey time we use it we have to clean it with a coat hanger by taking the front off the machine.
P.S. take the hose off top and bottom to clean it, all it takes two/three very small soap bubbles to clogged it
Posted on Dec 30, 2008
I have a GE Adora top-load washing machine. The washer fills up and overflows with water on all settings. Any ideas why?
  • You could have a bad level sensor or a pinched/severed/unattached vacuum hose which goes to the sensor device. The washer cannot determine how much water the tub is filling so the water keeps going in. I would check that the vacuum hose is simply not connected and that would be the easiest fix. The sensor device is usually located inside the control panel area and you can start there.
Dec 27, 2016 | GE Washing Machines
How do i stop machine from filling up with water till it overflows
Sounds like you need to replace the water setting switch.
Oct 13, 2014 | GE WJSR2070B Top Load Washer
I HAVE A GE WASHER THAT FILLS WITH WATER AND OVERFLOWS. DOESN'T MATTER WHAT SIZE LOAD, IT CONTINUES TO FILL WITH WATER AND OVERFLOWS. IT STOPS WHEN I HIT THE STOP/PAUSE BUTTON.
There is a pressure sensor that needs to be looked into. USUALLY, there is a chamber, on the outside of the washer tub, and out of the top of it is a small plastic hose. This hose runs up to an electrical switch.
Too much soap, over time, can plug up this system, so the machine has no idea how much water is going in...and keeps filling..... Sometimes the hose comes loose, but this makes a fairly immediate water leak, so I suspect something is plugged.
Doc
Jul 06, 2011 | General Electric WHDRE526EWW Top Load...
GE washer does not agitate does not stop filling up
If your washer is filling until it overflows without agitating, and will stop filling if you turn machine off or interupt power to it, the machine is not seeing that it is full. This may be caused by a blocked water level tube (usually some "goop" where it connects to the tub), a hole in the water level tube (look near the suspension rod or where a mouse may have chewed a hole in it), or a bad water level switch. You do not state a model number, or even if it is a top loading or front loading machine, so that is the most information I am able to provide at this point.
Oct 19, 2009 | GE Washing Machines
Washing machine water will not shut off when filling the machine
If your unit keeps filling with the power off, it is the water fill solenoid(s). If the machine overflows it is the float switch. Check out partselect.com and put in your model number. It will show a picture of the part and the price.
If you need more help, post another comment.
Thanks,
Tim
Jun 26, 2009 | GE WBSR3140DW Top Load Washer
Washing machine overflowed
Try filling it again and stay with it, when it starts to get near the top, unplug it, if water continues coming out you need a new valve, if it stops, then the level switch inside the control panel is bad
Jun 17, 2009 | Washing Machines
My GE washer wont stop filling with water or go to the wash cycle. my GE top load washer water will not stop and leaks out, overflows. model #GCXRPO9ODAWW.
You have a problem with the water level switch.  It is located in the base of the machine below the tub.  Replace it and you'll be fine.
Nov 20, 2008 | Washing Machines
Fill will not stop
you may have a problem with your pressure switch. or sometimes they call it the water level switch.
try to use it in the small level and see if it would stop filling around medium or large quantities of water.
if it would stop filling , then replace the water level sensor.
tnx 4 using fixya,
drcool
Oct 18, 2008 | GE WBB4500EWW Top Load Washer
Overflowing water
If the water comes out when filling, check your water valve by unplugging the washer when it is filling. If the water still runs, replace the valve. If the water stops, check the small tube that goes from the water pressure switch (in the consul) to the bottom of the tub. This must be connected without any holes or obstructions. If this is ok, replace the water pressure switch.
Jan 03, 2008 | GE WBSE3120B Top Load Washer
Washing Machines Logo
1,170 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
