Coby DVD-R1200 DVD Recorder Logo
Posted on Jun 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have a coby dvd r-1200 ,go to systems apply
Have a coby dvd r-1200 ,go to systems apply 99999,the dvd can't play, a message appear hello my e-mail [email protected]
Mike Neath
Level 3:
  • Master 315 Answers
  • Posted on Jun 10, 2009
Mike Neath
Master
Level 3:
Answers
315
Questions
0
Helped
193688
Points
1246
Im assuming you want to unlock you DVD player so thats its region free??
Try this:
Coby DVD-R1200
  1. The disc tray has to be empty
  2. Press RETURN
  3. Press INFO
  4. Enter 8, 8, 8, X (X is the region code, 0 = multi-region)
  5. Press ENTER (or RETURN)
Hello, I have a Coby TFDVD1973 side loading TV/DVD combo that will not play the DVD any more. How can I go about fixing this issue?
Hello
you haven't mentioned about whether it plays CDs. if it plays CDs without any problem, and only DVD play does not. the fault is with its Laser Pickup Unit. ther is no repair to this unit, as it can only be replaced with same type and number. Insist on same type and number. Never make a comprmise. OK.
4helpful
Error Message "Disc cannot be played"
Hi, it is may just a lens clean up,
try to clean it whit a q tips and wood alcool
wipe the lens gently to dont apply to much pressure on the lens.
hope that will help
truely A.S
3helpful
How do I unlock the region code on my Coby DVD298 Player?
found this surfing this website: http://forum.ecoustics.com/bbs/messages/2/581769.html
Unlock Coby DVD-298
Open DVD tray
Press 9735
This will bring up a menu to change the region code, after changing the code, go to exit menu.
Hope it helped.
Just bought a coby TV-DVD 1390 and when I play any DVDS there is no color. The TV Part Has Color just when I play DVD's. Any advise??
Try going to the menu, it seem like the dvd is set to another system, eg like pal system which is used on european countries. We use ntsc system in the united states.
3answers
Not able to play region 2 dvds
With remote control and player stopped,
press setup, vol+, vol-, vol+, vol-
Use arrow keys to select region 1-6 or 255 for all region.
Numbers appear on TV screen.
Press setup again to save and exit
Try this to make it multiregion. It should work.
2answers
My coby dvd 925
Coby dvd plays background music and all previews( music and voices ) but the actual movie we cannot hear voices only back voices and music can be heard.
Ray
[email protected] 469-438-3979
4answers
Problem loading dvd
replace the lens of your dvd your problems solve
1helpful
Region
coby 514.
power up. put disc in tray
press set up
then vol+ vol- vol+ vol-
code appears in top right 1
change altering left and right buttons
leave on 255 multi region (all discs)
press set up.
Coby DVD-514M
Turn unit on with remote
NO DVD in the tray (mine was closed, but opened might work)
Press TITLE then 1 then 9
Gray box will appear in the center of the screen with number 1 in the middle
Using up/down arrows change to desired region (0 for REGION FREE)
DVD disc is not recognised
itsmylife70, hello.
Two things, Laser gone low and can't read dvd. Just try cleaning the collimating lens with a cotton swab and glass cleaner. gently wet one end and dry residue with the other end.
The other thing is could be just a mutilated loom (flex) cable connecting the laser from the main pcb board. Laser is most likely gone bad.
Good luck.
Top Coby Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Mikey
Mikey
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
