Paper jaming in ricoh af 1022 in adf
Hi all i have problem in ricoh af 1022 adf gating paper jam
    New Friend:
  • 31 Answers
Paper jams in Ricoh Adfs ( or others), generally have origin in dirty rubber rollers. Oh yes, they can look clean but try to wash them with Benzine and check the cloth! You have to have full traction between the rubber and the paper , otherwise they skew and jam or are not picked up even. Other problem is in the exit (lower ADF side) , a misalignement between adf and the machine body. This can be solved with the mounting screws in the Adf back. Dont forget to have the paper format sensors (top right of ADF) clean and last, you may want to check the horse shoe sensors INSIDE (rear cover ADF). In my lifetime as a Ricoh tech, it only happens this once, and because the machine suffered ADF damage due to Portuguese bumpy roads, Ahahah. I am excluding the obvious, such a paper clip, a stapple, a coin , etc.. This happens very often...
Posted on Apr 28, 2014
4 Suggested Answers
SOURCE:
  • 70 Answers
SOURCE: paper jammed .....but no paper jammed
Sounds like this is a common problem with these printers. Hopefully, this is a malfunction of the printer that you can remedy.
I'm assuming that you have THOROUGHLY searched the printer for any evidence of paper and/or debris. Have you tried resetting the printer? If this issue is as simple as just needing to clear the error from the printer then a reset should work. (If you still have the manual, it should provide instructions on resetting the printer.) This is the best that I can provide on how to reset it:
  1. Turn the printer off.
  2. Hold the Resume button (red circle in the triangle), add a printer (click Power) an indicator light green.
  3. Hold the Power button and release the Resume button.
  4. NOT releasing the Power button, double click Resume and release BOTH BUTTONS (Power and Resume).
  5. Click Resume four times.
  6. Click Power to confirm the selected action (reset counter absorber). Click Power again to disable the printer.
Please rate this solution or let me know if this was any help.
Posted on Mar 27, 2009
  • 197 Answers
SOURCE: Ricoh 1022 service sc544
This is a code for the fuser, which indicates a very serious overheating condition. Your machine has something _seriously_ wrong with it, and should be looked at by a service technician.
SC544 - Fusing overheat error 2
A fusing temperature of over 251°C is detected by the fusing temperature monitor circuit in the SBCU board.
Potential Causes:
• Fusing thermistor defective
• Power supply board defective
• SBCU board defective
Posted on Nov 12, 2009
SOURCE: Epson Artisan 800...adf keeps saying paper jam,
epson artisan 800 keeps saying "paper jam" but there is none.
HELP!!!
Posted on Jun 01, 2010
How to solve paper jam issue in DF unit of ricoh mp6005
  • Clean all the Rubber rollers with Ethyl Alcohol.
  • After cleaning leave it 1 minute for dry and Start Your Job.
  • If Problem persists spray Ethyl Alcohol with a Syringe.
  • Do not leave it for Dry start your job.
Jun 30, 2016 | Ricoh Office Equipment & Supplies
REMOVE PAPER FROM ADF
1 - Open the ADF cover
2 - While pushing the release button, lift the ADF unit
3 - Remove the jammed paper
Aug 07, 2014 | Ricoh Aficio Office Equipment & Supplies
Epson gt-1500 always jam
I'm a GT-1500 owner. The ADF was always jaming. The problem was very simple to fix : I had to disassemble the ADF and tighten the little spring located on the "end paper detector".
You'll need 15 minutes and a Phillips screwdriver to fix it.
Regards
May 08, 2012 | Office Equipment & Supplies
I have af 2035/45 ricoh i am facing paper jamming at exit unit. i have done replaced sensors and bicu board and check all related wiring, but couldn,t find solution.
paper jam in aficio hasnt reset . but you must check all doors .it may be one door in your machin is open .more than more right door check it
Apr 27, 2012 | Ricoh Aficio 1035 Copier
Richo is200e scanner ADF thinks there is paper in the ADF and asks to clear the originals before trying to scan. We have checked the ADF for paper jam and tried cleaning the unit but it will not clear the...
These scanners will collect alot of paper dust. You need to remove the ADF cover and using compress air and or a vaccum blow out the jam/original photosensor's, I believe there are 4 sensors. Power OFF then ON and try it..
Mar 22, 2010 | Ricoh IS200E Flatbed Scanner
Ricoh Aficio MP 2000 ADF (auto document feeder) is not working
tape is on the underside of the ADF causing a sensor to not tell the machine that the ADF is in the lowered position. look under where the hinge area goodluck
Apr 22, 2009 | Ricoh Office Equipment & Supplies
Open Questions:
78 people viewed this question
k24674
Marvin
Marvin
