Question about Espresso RMI La Cimbali Espresso Machine
Used parts for la cambali M29 select
I brought my M29 to the local dealer for repair.  the motor and pump didn't work.   the boiler and switches did.  after 4 hours of work a was told that the CPU was bad.  a new one was $2,000.  it didn't seem right that some things worked and some didn't if the CPU was out but what can i do.  HELP
    President:
  • 1,618 Answers
Sounds like the relay for the pump is gone. Replace relay.
Posted on Feb 26, 2009
M29 wiring diagram
M29 is a semi automatic machine. Wiring is straight forward with the normal variance for single phase and 3 phase. Sorry i don't have a digitized diagram on hand. Maybe later. Dosing, is done with the control board which will need replacement if its not working.
youtube; ukeboy57
Mar 14, 2014 | Espresso RMI La Cimbali Espresso Machine
Brown water coming from la cimbali m29
Sounds like boiler is contaminated with milk.
Aug 26, 2013 | Espresso RMI Coffee Makers & Espresso...
Hi all. In desperate need of help. I have a La Cimbali M29 Select. I am unable to get hot water from the hot water tap and when the machine dispenses a shot of coffee, I have to turn the machine of...
From your description it sound that the button strip need to be replaced. All the buttons of the coffees and also for hot water are all set in one unit the button strip. This like a membrane and is located under the buttons. This is frequent problem with m29 select since the connector of the button strip it is exposed under the cup warmer area and is very easy to absorb the humidity from steam escape inside the machine and when one short circuit it happens then since the whole strip is one unit it will mull faction as you described.
Jun 14, 2011 | Espresso RMI La Cimbali Espresso Machine
La Cimbali Espresso Machine: How do you calibrate the dosing for a Cimbali M29 ...
Press and hold any Group stop button until beeping, then all the button will copy what you press. Hit any stop button to leave program.
May 18, 2010 | Espresso RMI La Cimbali Espresso Machine
How do you calibrate the dosing of the La Cimbali M29 Select?
should be the same method unless the stop button needs replacement. The stop button is one of the most often used (abused) buttons and frequently needs replacement.
ukeboy57
Mar 26, 2010 | Espresso RMI La Cimbali Espresso Machine
La cimbali junior does not pump water into the boiler
The connection from the boiler to the pump is clogged, you can descale or remove connecting hose and clear.
Mar 12, 2010 | Espresso RMI La Cimbali Espresso Machine
WANT TO BUY A SECOND HAND M29 SELECTRON 2 GROUP- LA CIMBALI
The price for the m29 select new is about 5500 to 6000. So for one of 4-5 years you can give about 2500-3000. However I sugest to open the machine and check if their are rusting points or any leaking points which propably be white points from calcium color. Also ask if their were any water filter like everpure or and a water softener conected to water supply of machine during the operation of the machines.
If you see minor points as above and the water was treated before entering the machine then your machine can work for minimum another 10 years.
Water calcium (scale) is the biger enemy of the machine.
Good Luck
Mar 10, 2010 | Espresso RMI La Cimbali Espresso Machine
Cimbali M29 Select
Remove the 3 screws on the side of the bell they might be bolts or allen wrench screws. That will give you easier access to the screen and screw(make sure you have extra screen and screws).
Aug 18, 2008 | Espresso RMI La Cimbali Espresso Machine
La Cimbali M29 Select - No power
sometimes italians use brown colour for neutral, please check it. if it is so than the problem is solved
Mar 19, 2008 | Espresso RMI La Cimbali Espresso Machine
Espresso RMI La Cimbali Espresso Machine Logo
466 people viewed this question
Top Espresso RMI Coffee Makers & Espresso Machines Experts
Mohamed Ismail
Mohamed Ismail
John
Mark Cheong
Mark Cheong
Are you an Espresso RMI Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
