Question about Sanyo EM-U1000W Microwave Oven
Microwave will not work
Got up one morning and the micowave will not work.  We just used it the night before. Cooked baked potatoes and green beans..back to back for about 30 minutes total.
It is plugged in and the outlet works for other things.  The display is blank and the unit doesn't seem to have any power for anything.
The inside of the door has a sticker describing a fuse, but could it be the problem and if so, where is it?  The owners manual makes no mention of it.
It's only 3 or 4 months old.
thanks
  • George M Jul 18, 2008
    The Sanyo EM-U1000B in our employee lounge just stopped working. The display is blank and it won't turn on. The power source is fine, and we've tested the microwave in other outlets. It is way out of warranty. I would like to replace the internal fuse myself, if that's the problem. I'd need to know how to get at it and how to get a new one. Thanks.
  • Sanyo Master
  • 9,098 Answers
This is still under warranty, so I would not recommend voiding your warranty by attempting repair.
I would call Sanyo at the number in your manual and ask for the nearest authorized servicer so you can take it in for repair on their dime.
If it's an over the range model, I would make sure to have a second person to help remove it from the wall.
If I had to bet, I'd say thge temperature fuse / thermal fuse / thermostat on the magnetron is open, but it may be the power fuse.
Please post back if you need more help, or if you decide to work on it yourself.
Posted on Nov 05, 2007
How to heat cooked potatoes for mashed potatoes
hi Judy.
Put in the large pot as you peel and slice so they don't turn brown. Be sure water covers the potatoes by 2 inches, on medium-high heat and bring to a boil. Reduce to medium-low heat, cook the potatoes for 20 minutes until the potatoes are soft and fork tender. Turn off the heat, and drain well in a colander.24 Nov 2015
Make Ahead Mashed Potatoes Reheated 5 Ways - Delicious Table
https://www.delicioustable.com/make-ahead-mashed-potatoes-reheated-5-ways/
if you want to know more go to this link.
How to heat cooked potatoes for mashed potatoes Google Search
Nov 23, 2017 | Microwave Ovens
How do I remove salt from a soup after it is cooked?
you put peeled potato in it for a while, than take it off, the potato will absorb all the salt.
Jan 24, 2015 | Microwave Ovens
While baking a sweet potato, the potato exploded and caught on fire. The microwave no longer works.a fire bro
I haven't heard of such a thing. You must have cooked it until there was no moisture left in the potato. That would also account for the failure of the oven. It would be the same as no load in the oven.
A thermal protect part is your current problem.
Apr 02, 2014 | GE SpaceMaker Microwave Ovens
Auto Cook not working
If autocook is not working and everything else it, there is an issue with the sensor in the oven that detects the steam, The emission of steam is what triggers that unit to shut off. If it wont cook on any settings then the issue is with the microwave generator not putting out enough power. This could be from a lot of things.
Dec 16, 2013 | Sharp R959SLMA 900 Watts Convection /...
Microwave won't restart after baking potatoes.
If your microwave is not a convection then the moisture most probably is somehow getting to the controls as potatoes has quite a bit.
Oct 27, 2017 | Emerson MWG9111SL Microwave Oven With...
GE microwave not heating, sensor error.
first suspect is the inverter board (power) and magnatron a distant second----in either case the part involved unless an expensive unit is pricey.
Aug 26, 2012 | GE SpaceMaker Microwave Ovens
How do you use auto defrost
Auto defrost is rather clever. There is a sensor that detects moisture evaporating from the defrosting food. I won't go into the equasions used to work out the optimum point at which the food is defrosting, it suffices to say that when the moisture content in the exhaust air reaches a predetermined point, it is thawed out. If it reaches a higher point, for baked potatoes for instance, they in turn will be cooked.
Hope this helps.
Feb 07, 2011 | Microwave Ovens
I have a 3-year old Amana microwave installed above my stove. Last night I was baking two potatoes in the microwave. I noticed that the microwave sounded "louder" than normal. After about 13...
No! But it will need to be repaired. Did you wrap the potatoes in tin foil? The reason for the smoke needs to be found and repaired. Smoking means a short or a part shorted, failed, or wires touching another wire that did not blow any fuss.That is not good.
Trained technicians can help the mfg improve their products if they find the problem and report it to the Mfg.
LOL
Jan 28, 2011 | Amana MVH210W Microwave Oven
SET TIMER FOR 20 MINUTES FOR BAKED POTATOE.. CAME BACK AND FOUND POTATOES CHARCOALED. SMOKE AND SINGED INSIDE. MICROWAVE WILL NOT COME ON. CHECKED CIRCUIT BREAKER. POWER TO UNIT.
That was a very long duration to have set for potatoes. It would have made the magnetron burnt by exeeding the limit and findinf there was no conductive medium by moisture , it has ended up burning the magnetron.
First of all clean up the inside and clean up the point of the magnetron beam.Now confirm on the inside to be totally dry.
Disconnect power and check inside for break of fuse to the magnetron.If the microwave does not heat on testing with a cup of water , then it is possible that the magnetron is cooked.
Confirm the cost for the unit to decide on replacement.
Hope this helps.
Aug 21, 2010 | LG LMV1630 Convection/Microwave Oven
Sanyo EM-U1000W Microwave Oven Logo
131 people viewed this question
Top Sanyo Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
robert landry
Are you a Sanyo Microwave Oven Expert? Answer questions, earn points and help others
