Question about Crocs Croc Classic Flat Iron Titanium Black Plates 1"
My avanti ultra flat iron shows 122 does not heat up
BABNT2091T
The Problem with BaByliss PRO Nano Titanium 1" Ultra Thin Hair Straightening/Flat Iron can be resolved if you call the company support line or web page.
May 10, 2014 | BaByliss PRO Nano Titanium 1" Ultra Thin...
Avanti wet dry nano titanium ceramic silver digital flat iron 1 3/8 WD-AVCROC It was working fine then all of a sudden one day it does not have any heat, it shows 450 and then goes to 80 then shows error...
Does it still heat at all? There is a thermal fuse that trips if the iron gets too hot. The fuse can be purchased from DigiKey and others, but it is not easy to replace, and you need a multi-meter to check the fuse. I have repaired dozens of flat irons, not sure about that brand but they're all nearly the same.
Sep 20, 2013 | Avanti Nano Ceramic Silver Digital Flat...
My avanti ultra hair straightner does not heat hotter than 230 deg..id there a reset button..help?
I have the same problem!! It switched from farenheit to celsius thats why its at 230 but i want it back in farenheit!
Sep 18, 2011 | Avanti Ultra Silicone and Ceramic Flat...
My croc flat iron goes to 69 than shows error message
It's not working! I've tried unplugging it for a minute, plugging it back in and holding the power button on....am i missing something. I've had this damn thing for about 2 months. Please dont tell me i have to buy another one....AAAHHHHH!
May 28, 2011 | Crocs Croc Classic Flat Iron Titanium...
How do I clean the water reservoir in my T-FAL Avantis 90 iron. When I use the iron hard particles come out of the steam holes.
Hi, Brown water and whitescale are often the result of the water you use in the iron... If you have scale, white vinegar will clean that... For brown water, empty the iron, rinse out the insides with bottled water, and then use the bottled water instead...
Also check out this tip...
Cleaninga Steam Iron White Scale and Brown Water
heatman101
Mar 23, 2011 | Tefal Avantis 90 Iron
When empty, fill with white vinegar, let it heat up then hold the steam button down to let the vinegar run through the iron. Do this over the sink!! Then fill with water and repeat to rinse the vinegar out.
The vinegar will dissolve the mineral deposits in the iron.
Dec 07, 2010 | Tefal Avantis 90 Iron
No instructions came with my Avantis 100. Mode. 1829/A 3.12 104. I have used it for several years, just guessing and hoping I am using it correctly. Would you have information on it.
If you have been using it for several years, you are using it correctly already. the fact that it still operates indicates that you use the proper sort of water in it (not using distilled water is the number one cause of failure in irons). The information available for the Avantis is really generic and will not add to your success, I assure you. Iron on! Farmerbear at FixYa.com
Sep 30, 2010 | Tefal Avantis 100 Iron
Hi My iron seems to auto shut off in 2 secs when I plug in the power, it shows the red light for a sec and off, what could be the issues.
How old is it?
Is it still under warrenty? if it is take it back to where you bought it.
Otherwise it sounds like the thermostat is broken. Wallmart has some very nice cheap irons.
Aug 02, 2009 | Tefal Avantis 130 Iron
T-fal ultra glide easy cord iron stopped working while ironing
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Jun 03, 2009 | Tefal UltraGlide 1569 Iron
Crocs Croc Classic Flat Iron Titanium Black Plates 1" Logo
454 people viewed this question
Top Crocs Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Tilburn
Jeff Tilburn
Are you a Crocs Health and Beauty Expert? Answer questions, earn points and help others
