Wire speed changes very little. 5.4 to 5.7 ohms on pot through full turn. Could pot be the problem? Welder is a snap on ya 240
SOURCE: Mig welder
Sometimes dirt builds up at the beginning of the liner, at the drive. Eventually the dirt jams in there so much that it gets very hard to push the wire through it. Carefully cut the wire between the spool and the drive and secure it to the spool through a hole, so it doesn't unspool into a bird nest, then disengage the drive roller, the wire should pull out of the tip freely. If you feel resistance when you pull it out, either there is dirt at the beginning of the liner, or the contact tip is causing resistance. Without the wire in the drive, turn on the machine and try it watching the drive. Does the drive work freely now? Does it change speed with the rheostat? If its a problem with dirt, this is what I do, after you get the wire threaded back through the drive, liner and contact tip, and everything is working, take a small clean cotton rag and simply tie it around the migwire between the spool and the drive, in a way that the drive can't **** it in. This will constantly clean any dust/dirt off the wire before it goes through your expensive drive and liner. Whenever you change the spool, change the rag. Hope this helps, and please post your results.
SOURCE: hobart handler 140 will not feed wire
A schematic would certainly help, give Hobart a call and ask for a wiring diagram. or manual. Hobart are very helpful and may even give you guidance, you may have to pay the postage, they usually fax these documents so it will not cost you anything.
SOURCE: I have a Hobart 135 Handler wire feed welder that
Get a volt meter, go to ohms setting , check transformer to ground for low to zero ohms reading. also look closely at transformer windings for foreign objects in between them, never know what you my find. If transformer is shorted to ground probably time to say some nice words over it before burial. Also just for kicks try a new gun on it, (there is a reason i'm asking you to do(this) see if you can find someone that has spare. A good honest repair shop would probably be reasonable if all else fails. to a least let you know if the transformers a problem. good luck
Signed
Former Miller Certified Tech.
