Question about Compaq Presario 5000 PC Desktop
Help and support files???
My Help Center Application gets this error message when I click the HELP button on the START menu "Please report the following error number to Microsoft support: -2147143679". Microsoft no longer supports windowsME.
       Can I get an update somewhere other MS so i could fix my CLOCK auto adjust app.? and access my HELP Cenmter app.?
  • tinocker Oct 28, 2007
    thi pertain to my COMPAQ presario 5000 desk top PC
  • 328 Answers
Use an Atomic Clock, get it hear
http://www.atomtime.com/download.html
Posted on Oct 28, 2007
I can not get my Lexmark printer to print out an email I rec'dI have the Lexmark printer X2650 please help me. i unpluged it and truned it off and back on again nothing happens.
To be sure that the issue was caused by the enabled Image Sharpening option, do the following:
Go to Control Panel > Administrative Tools > Event Viewer > Application, and look for entries that start with the Error sign, as in the table below:
Windows XP pattlnk_5142009_1243-err.jpg Windows Vista pattlnk_5142009_1244-err_v.jpg
After opening it, look for entries that report faulting application, such as spoolsv.exe, and the faulting module is lx??ibuf.dll. See image.
If using Windows Vista 64-bit, one might also see this error message (click on the link to view image).
Solution
Windows XP Click Start, then select Printers and Faxes. Right-click the Lexmark printer, and from the drop down menu select Printing Preferences.
Go to Image Enhancement and deselect the Image Sharpening option. See image.
Windows Vista Click Start (Ribbon), then select Control Panel. Click on Hardware and Sound and from the list select Printers. Right-click the Lexmark printer, and from the drop down menu select Printing Preferences.
See image.
Jan 18, 2011 | Lexmark X2600 InkJet Printer
Tip
How To Get Help Soving Problems With Windows 7 Easily
There's One Cool Feature in Windows 7 that's not available in it's predecessors, which is called "Problem Steps Recorder".
This "Hidden" tool, can help you record the steps you took in which leads to the problem occurring.
To access the Problem Steps Recorder in Windows 7, you should follow the steps below:
1. Click on your Start Menu Button in the Lower Left Hand Corner,
2. Next in the "Run" Box, type in "psr" (Without the Quotes), to which you should see something like in the below image
3. Next, Double Click on the found file "psr" and you should see the following program appear on your desktop:
4. To Start Recreating What You Did When Your Problem Occurred, First, Click On The "Record" Button.
5. Now, Just Navigate To The File/Folder or Application To Which You Are Experiencing Problems With. (This Can Be Accomplished The Same Way in Which You Normally Open/Access Files/Folders & Applications).
6. Once You Have Got To The File/Folder or Application That Was Giving You An Error Message When Opening The File/Folder or Application & The Error Message Can Be Seen On Your Desktop, Then You Can Press "Stop" On The "psr" Application.
7. You Shall Then Be Prompted To Create A Name For Your "psr" Report, Which You Should Name Accordingly To The Problem You Have Recorded. IE: If You Were Having A Problem With Windows Media Player, Then Name The File "Windows Media Player Error Message Report". This File Will Then Be Saved in ZIP Format in a Location That You Chose To Save It. (Probably Best To Create A Folder On Your Desktop Called "Problem Steps Recorder Reports) or (PSR Reports).
8. Now, When The ZIP File is Extracted, It Will Contain A Single HTML Page Containing The Steps You Took (With Colour Pictures That Can Be Clicked On To View The Full Size Image). This Can Then Be Emailed or Recorded To A USB Flash Drive or Floppy Disk, & Examined By Someone With Experience Of Troubleshooting Windows Software / Hardware Errors Easily.
9. An Extra Tip So That You Don't Have To Keep Searching For The "psr" File Would Be To Right Click On The "psr" File After Running A Search For it As Described in "Step 2" & Then Clicking On The "Pin To Taskbar " or "Pin To Start Menu" Options, So That The "psr" Tool Will Always Located on Your Windows Taskbar, and/or in Your Windows Start Menu.
on Jul 15, 2010 | Computers & Internet
Werfault.exe -application error\r\n
You can try to disable this service by following the below steps:
Step 1: Open your computer's Control Panel by selecting "Start" > "Control Panel" from your computer's Start menu.
Step 2: Choose the "System and Maintenance" > "Problem Reports" menu option from the Control Panel menu.
Step 3: Select "Change Settings" > "Advanced Settings" from the Problem Reports program menu and turn off the automatic problem reporting feature in Windows.
Step 4: Exit the Problem Reporting application by selecting "File" > "Exit" from the File menu. Werfault.exe will now only run on your computer in the event of a catastrophic application problem.
If disabling the application does not work, y
ou should keep in mind that many malware programs can show up on your system as seemingly legitimate files by using file names that are very similar to those of legitimate files. Whenever you are in doubt about a particular file, always scan your system for viruses.
Jun 10, 2010 | Dell Dimension 4400 PC Desktop
'Print error #5'
MYOB requires that you have a default printer selected on your computer system. If no printer driver is installed, when opening a company file, a printer error #5 is displayed.
Highlight your Printer and go to File on then Menu bar/Set as default.and Turn off user account control if you're using vista. It's in your security center in the control panel. Turning this off should fix the printer error 5 issue .
Mar 03, 2010 | Myob Accounting Plus (BPJUBC00) for PC,...
I get the following message. "This application has failed to start because MSVCRT40.dll was not found". I get the message on some other application. How do I get the dll back on my computer.
  1. Download the repair software here. (Free download)
  2. Click on Save File and follow the instructions.
  3. Scan your computer.
  4. Click on the Fix Errors button.
Aug 31, 2009 | Microsoft Windows XP Home Edition
Problem about "services.exe - Application Error" pop-up menu
Apparently, you computer has some unexpected software running during the startup. In order to get ride of these software, you could check your register table manualy by regedit or download this software, which will help you to find if there are any suspect software running at the startup.
files.filefront.com/sreng2zip/;8049311;/fileinfo.html
May 07, 2009 | Computers & Internet
Hi, recently i had virus in my comp called win32.worm.autorun.MQ i restored my windows through restore after cleaning up when i click on my drive it gives me error saying "resycled\boot.com is not valid...
This is a solution i found at another site that i think could help you with your probem
Hi
If you still need help with this please do following:
Download and install TrendMicro HijackThis
* Once installed open HijackThis by clicking Start > Programs > HijackThis and click the button labeled
Do a system scan only
* Click the scan button in the lower left hand corner of the interface and HijackThis will quickly scan your system.
* Once the scan is complete the scan button will now read save log. Click this button to save the log file to your PC. Once you select where you would like to save the file it will open in your systems default text editor. Typically this application is Notepad. Post the log here.
The link:http://www.techsupportforum.com/security-center/virus-trojan-spyware-help/hijackthis-log-help-inactive/306207-resycled-boot-com-not-valid-win32-application.html
Please let me know if you need more help with this problem
Jan 06, 2009 | Computers & Internet
Windows dvd maker
What OS are you using? Ultimate, Premium, Basic?
Windows DVD Maker has stopped working Issue : While trying to create DVD in Windows DVD Maker in Vista, or while creating a DVD from Windows Movie Maker, which uses Windows DVD Maker, the burn process stops with error message.
Error message : " Windows DVD Maker has stopped working. A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available. "
Cause : Windows DVD maker stops working because of incompatibility with one or more codec files which are outdated or incompatible with the particular project or the DVD Maker software itself.
Resolution :
These Codec files should be located and renamed to resolve the issue.
1. Open Start menu and type Event Viewer in the Start menu search bar. Open Event Viewer from the menu.
2. In the Event Viewer window Click on Windows Logs in the left panel
3. Click on Application Logs under Windows Logs
4. Locate error messages listed in the Central panel of the Event Viewer window and double click the error to check if this is log is related to DVD Maker.
Sample Error Log :
Problem signature
Problem Event Name: APPCRASH
Application Name: DVDMaker.exe
Application Version: 6.0.6000.16386
Application Timestamp: 4549b5b0
Fault Module Name: nevideohd.ax
Fault Module Version: 4.6.15.0
Fault Module Timestamp: 459bb828
Exception Code: c0000005
Exception Offset: 00008b89
OS Version: 6.0.6000.2.0.0.256.1
Locale ID: 1062
5. Locate Fault Module name, it should be a file with extension .ax.
6. Once the file name is identified, try to locate the file in C:/Windows/System32 folder. ( Please click on Show Contents if the files are not listed Automatically ).
7. If the files are not listed in System32 folder, search for the file, with search containing system files and folders.
8. Locate the file and rename it.
9. Check if the issue persists. If the issue persists and the error message again appears, locate the new .ax file that is causing the issue from the Event Viewer, error log.
These steps will resolve the issue instantly without a restart.
Sep 18, 2008 | Computers & Internet
M3plugins
(This is very specific). For Windows XP.
Right click once on the start button & slide up to & left click on search. In the search windows under, All or part of the file name: type in m3plugin.dll
Than under, Look in: click the drop down menu & click on C: Click search. Once the file is found right click on it once & slide to & left click copy. Right click once on the start button, slide up to & left click on Explorer. Left click on the + sign next to Program Files. Left click the + sign next to MyWebSearch. Left click the + sign next to Bar. Right click once on the 1.bin folder & slide to & left click past. The m3plugin.dll file will than be copied into the correct folder. Re-start you're PC.
Mywebsearch help link: http://help.mywebsearch.com/sbar2.html
Things you should know about the program:
http://www.emsisoft.com/en/malware/?Adware.Win32.MyWebSearch+Toolbar
Fix 2# If you no longer have the mywebs free screensaver program and your still getting this error message simply go to run, type in MSCONFIG and go to, startup & uncheck the link that says c:\progra~1\mywebs~1\bar\1.bin\m3plugin.dll. Click apply than OK & let windows restart.
If this does not correct the error message post your findings.
If this fixed your troubles great. Please vote.
Mike
Aug 24, 2008 | Intel Motherboard
Compaq Presario 5000 PC Desktop Logo
55 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
