Question about Jensen VM9410 Car DVD Player
Monitor won't come out
My monitor won't come out on it's own.  I have to use the remote to open it up and pull the monitor and push the angle button all at the same time to get it to come out. I think the belt may have come off of the motor or something like that.  Does anyone have any suggestions???
I have the same problem but i lost my remote so i cant even get my monitor to stay it just opens and close real slow can someone help
Posted on Dec 24, 2007
RESET DELL MONITOR E1709WC
Instructions
    • 1 Push the "Menu" button on the front or side of your Dell monitor. The button's icon resembles a miniature monitor. This will open the main monitor setting menu. Push the button again to exit the main menu and open the OSD menu.
    • 2 Push the "Down Arrow" button on the monitor to scroll through the OSD menu. Stop at "Factory Reset." Push the "Menu" button to open the factory reset menu.
    • 3 Push the "Down Arrow" button to select "Position Settings Only" to reset the monitor's horizontal and vertical screen settings. Press the "Menu" button to activate the setting changes.
    • 4 Push the "Down Arrow" button to select "Color Settings Only" to reset the monitor's red, blue and green color settings. Press the "Menu" button to activate the setting changes.
    • 5 Push the "Down Arrow" button to select "All Settings" to restore the monitor to its original factory settings. Press the "Menu" button to activate the setting changes.
    • 6 Push the "Up Arrow" button to select "Exit" to leave the monitor reset menu. Press the "Menu" button to exit the OSD menu. Push the "Menu" button again to exit the main settings menu.
Aug 02, 2012 | Dell Computers & Internet
My Power Acoustik PTID-7350NRBT angle feature isn't working
If you're still looking for help I have the same one and had the same issue. You have to push the eject button once and right after push and hold it and it will let you change the angle. You have to be really quick between the push and push and hold. If it opens, just close and try again.
Jun 29, 2012 | Power Acoustik PTID-7350NRBT 7 in. Car DVD...
Dell 8200 beeps 10 times monitor won't come on says power saving mode
Hi
Remove the sound card and blow the slot with dry air to rid off dust.
Examine it to make sure nothing's damaged and fix it again.
Checkout the RAM's.Probably remove them,wipe the slots off dust and fix them again.Make sure they're well seated on their slots.
Feb 05, 2012 | Computers & Internet
An emachine monitor menu keeps popping up and can't be turned off. what do I do
Press the "MENU" button on the monitor to turn it on or off. If that doesn;t work, press the AUTO button, let it reset and then press again to exit.
Good Luck
Nov 18, 2010 | E-Machines eMachines Monitor E15T4
The on and off button won pop back out so that i can push it in to turn the monitor off and on.
Call dell with the 20 digit serial no at the back,if it is in warranty you will get a replacement monitor for this issue i had the same problem mine was replaced
Normally Monitor has 3 year warranty for parts
Dec 30, 2009 | Dell UltraSharp 2407WFP 24" LCD Monitor
My monotor its all black but u can
This should be an (LCD) screen. They are the ones that usually have this kind of problem. You will need to take it to have it checked if the problem is the VGA signal cable leading to the monitor. They will check if it is properly connected or has gone bad. It is very unlikely that the screen is bad. When this VGA signal cable goes bad it could result in a totally blank screen.
Sep 13, 2009 | Dell Computers & Internet
How do I open the HP Pavilion F1703 17" LCD Monitor so I can check or fix PC board connections causing my monitor to turn off at times. (My power adapter is good voltage).
if there are no screws holding the covering on then there maybe a "snap/barb" type fastener. Theres a special tool that is nothing more than an "angled tool" which can depress and keep barb out of way and you wiggle a side free, more than one is preferred. NO NOT FORCE it but depress if that what it uses, otherwise you'll break it off, though flexible. Think of angle as in a ramp that slides into place and hits barb and pushes out of way so it can be pulled through hole from behind. Also, it need not be pushed down too hard, otherwise the barb is forced against side and removal is still hard. I hope you get the idea.
I used a small screw driver and gently wiggled and snapped at the corners and the midpoints around the moniter.
Aug 02, 2009 | HP Pavilion F1703 17" LCD Monitor
I have a 19 inch lcd monitor philips model number 190s6fs/00
just check the contrast and brightness with the buttons or if you have some experience in opening up things then just open it up and check the wiring
Aug 01, 2009 | BenQ FP71G 17" LCD Monitor
How to angle the monitor
I have Model X203H & had the same problem. The support CD explained how to adjust the monitor:
Screen position adjustment
To optimize the viewing position, you can adjust the monitor tilt by using
both of your hands to hold the edges of the monitor.
The monitor can be adjusted to 15 degrees up or 5 degrees down.
Apr 16, 2009 | Acer 22" X223w LCD Monitor
Vizio in stand by (amber lights) mode on monitor
Does the remote have one power button for on/off .... or, does it have separate buttons ?
Jan 13, 2008 | Vizio Gallevia GV42LF 42 in. LCD...
Jensen VM9410 Car DVD Player Logo
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
