Question about Kenmore 93702 Top Load Stacked Washer / Dryer
Laundry center 41799570120
On spin cycles getting very noisy sounds like a loose gear uponing winding down?
  • Anonymous Nov 01, 2007
    replaced belt and machine is still rapping a little with water mixed with oil comming out of the bottom??
    Scholar:
  • 146 Answers
Could be the bearing. The water seal may be damaged, allowing water to get to the bearing. You should have the seal and bearing replaced.
Posted on Nov 01, 2007
GE front load washer model number WBVH6240HWW SERIAL NUMBER RM200099T spins freely by hand but started smoking and belt behind looks fine. What could be the problem. Before the smoke started when spin...
Hmm... Kind of difficult to say for sure. Does your inner spin basket wiggle up and down? If so, you've got a main bearing going. Also, put it in a spin cycle for a minute or so and then try smelling the windings on your main motor. If they smell burnt, you'll need to replace the main motor. Also, one last thought, check to see if your drain pump overheats. I say this because the drain pump is active during the spin cycle and a bad drain pump can sound extremely noisy and start overheating.
I hope this helps. Good luck!
Oct 19, 2014 | Washing Machines
My frigidare laundry center, FFLE2022MW will not fill with water at all.
I have a Frigidaire Landry center model # FEX831FS4 I washed a small but heavey rug in it and it quit during the spin cycle and now wont do nothing but the dryer still works...can you help me out?
Aug 21, 2014 | Frigidaire FFLE2022MW Electric Laundry...
Washer is noisy in spin cycle and won't spin water out
but clutch or loose worn belt, also check bad motor coupler
Aug 02, 2014 | Maytag Bravos MEDB400VQ 29" Electric Dryer...
Kenmore Elite Oasis HT makes loud noises during spin cycle.
The tub may be unbalanced and wobbling. This may be due to washing heavy items such as rugs, towels, etc. If it is noisy with regular laundry loads, the mechanism that supports the tub may be loose or broken.
Sep 10, 2012 | Kenmore Oasis Agitator 4.5 cu. ft....
Kenmore laundry center model 92702 burning smell during spin and water doesnt drain
mine does this regular easy job if your desent at diy are you missing socks or wires from bra's as it probably the pump blocked take the pipe of the pump and see if there is any thing stuck in the pump remove it as long as pump not damaged should be fine probably get some loose change as well lol
Aug 17, 2012 | Kenmore 92702
At the end of the spin cycle there is a whirrring sound like two gears meshing together and winding down. this machine si 13 years old, top load, direct drive. There are no other noises during any other...
Possible problem within the GEAR BOX as this is a direct drive. So you will need to remove the drive box and check within if the lubrication is low , if the bearings are bad or the gears are worn out as the case when the spin ends on the higest RPM.
Proper resetting with lubrication must solve the issue.
Jul 14, 2011 | Maytag Washing Machines
Very noisy on spin cycle only
Hi, please describe the type of noise you are hearing. If it is a grinding type noise, it is likely to be the drum bearing.
Oct 25, 2009 | LG WM1814CW Front Load Washer
Ariston Margarita 2000 NOISY spin cycle....
Remove drum drive belt, and spin drum by hand, if there is any resistance,. or it feels rough or noisy, the the main bearigs have probably failed.
If it is o/k then check motor for worn or noisy bearings,
Please rate my solution.
Thanks.
Jul 24, 2009 | Ariston Technologies Ariston AWD12 Front...
Kenmore 93702 Top Load Stacked Washer / Dryer Logo
139 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
