Flashing Lights when powered down
Hi my name is Frank and I'm having a problem with my tower. Everytime I turn off my system these blue lights start flashing from the tower and when I try to power back up it just won't turn on until I start shaking the tower and somehow get the flashing to stop but not until the LED light is stable from the motherboard. Can u pls help me with this?
  • bookie175 Oct 29, 2007
    I jusy want to say to marki163 that my tower is a Thermaltake Tsunami it comes with certain alarm functions and keys to open the tower. I'm pretty sure that it's the tower because everything in my case is new and pre-tested. I would appreciate if someone who knows about these tower can help me. I appreciate your time and patience but this problem is the case.
Bookie175, it sounds like you're just trying to turn it off by pressing the power switch, and not by selecting Start, Shutdown from the Taskbar (which tells Windows to save current settings and perform an orderly shutdown process). --LeftyX
Posted on Oct 06, 2008
    Problem Solver:
  • 5 Answers
The flashing LED is because your system is in "sleep" mode. By default windows Vista puts your computer in sleep. What this means is it doesn't shutdown the power completely it leaves a little going through certain computer components (more specifically the ram) to speed up the boot time when the power button is pressed again.
In XP a the default shutdown scheme is a complete shutdown where power is turned off after the shutdown process is done. If you are using XP you are putting your computer to sleep when shutting down.
As for the boot problem. Newer motherboards have an LED on the actual board to indicate that it is receiving power. If it is of either the power supply switch (at the back of the case) if off or the motherboard connection is loose and the shaking makes it fall into place. (Shaking is usually not necessary and indicates a problem...)
There are a few possibilities I can deduct from your description:
  • the connection from your power supply to your motherboard isn't properly seated and is causing this
  • the power supply switch (not the case switch) is being  turned off and results in the computer taking a few seconds before the internal LED become solid
  • ... the dreaded sign that the power supply is failing and is on it's last legs...
My suggestion is to check all connections and if that doesn't work borrow a power supply from a friend and swap them to see if it boots properly.
(If a friends with a spare power supply isn't an option a local PC repair shop should be able to help you out... but probably for a fee...)
Posted on Oct 28, 2007
Power blue light flashing when i turn the computer on
It depends on where the blue light is. Is the blue light on the monitor or on the computer tower? If it is on the monitor the monitor is having problems and needs to be serviced. If it is on the tower it could be an issue with the power supply.
Jan 17, 2013 | Gateway DX4720-03 PC Desktop
My computer lights keep flashing
Well on my father's HP Tower has a Switch for the Lights about 1 inch away from the Power button. Look for your Light Switch so you could Turn them off
Nov 07, 2012 | E-Machines eMachines Desktop PC
My pc is shutting down and I can't wake it up without shutting down the power from power supply. The Antec 300 tower has two blue lights- the top light starts blinking when it has shut down and I
sounds like a power supply problem
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty
http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm
One bad lead can cause a computer to continue on a cycle of restarting or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive power and data cables IDE SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
hope this helps
Oct 13, 2012 | Antec Computers & Internet
What is the pairing security code for xx3 plantronics
The following are detail instructions on how to Pair (sync) a Plantronics Bluetooth Headset to your Bluetooth Cell Phone:
1 - You need to go into the device you wish to pair it and turn the Bluetooth feature first.
2 - Then you need to place the headset in pairing mode so your phone will find it.
Find your model headset in the instructions below. Once the headset is in "Pairing" mode you will then need to follow the instructions in your cell phone or Bluetooth device's user guide on how to go it to your phone and search for the headset & pair it to a Bluetooth headset.
The passkey is 0000 (4 Zeros) except models M1000 and M1500 (see below for their number )
For the Plantronics M3000/M3500 (discontinued):
Pressing and holding down the volume up key and the talk button at the same time. Hold them in together until the indicator light on the headset starts flashing red then green.
For the Plantronics 510 Voyager:
Pressing and holding down the call control button and holding down the volume up at the same time until the indicator light on the headset starts flashing red then blue.
Plantronics Explorer 320,330,340 & 350
Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue.
Plantronics 655, 665
Plantronics Discovery 640, 645, 640e
Plantronics Pulsar 590/590e & 590A & a Bluetooth device:
Begin with the headset turned off. Press and hold the call control button then power the headset on and when the indicator light flashes red and blue, release the call control button. Once the headset is paired successfully the headset will flash blue.
pulsaradapter.jpgFor the Plantronics Pulsar 590 & 590A & the Universal Adapter: Begin with the headset turned off. Press and hold the call control button. Power the headset on and when the indicator light flashes red and blue, release the call control button. Turn the Universal Adapter on. Press and hold the adapter pairing/connect button for 7-10 seconds. When adapter starts flashing red and blue release the buttons. The headset and adapter will flash blue when paired successfully.
pulsar_260_128.jpgPlantronics Pulsar 260
For the Plantronics Pulsar 260, Begin with pendant powered on.
Press and hold both the mute/play/pause button and the power on/off/pairing button simultaneously. When the
indicator light flashes red and blue, release buttons. While pendant is flashing red and blue, use the phone menu to search for Bluetooth devices and select "260 Plantronics." When prompted for passkey,
enter 0000.
For the Plantronics M2500 (discontinued):
Start with the headset powered on. Press and hold down the call control button while also rotating the multi function dial upward (away from the light) until the indicator light on the headset starts flashing red then green. When prompted for passkey, enter 0000.
For the Plantronics M1000 (discontinued):
Hit and hold the volume/mute switch in until the indication light starts blinking.
For the Plantronics M1500 & A500 adapter (discontinued): Turn the headset on and the adapter off. On the headset push in and hold the mute/volume dial until the indicator light begins to flash. On the adapter press and hold the blue power button for 10 seconds. The light on the adapter will flash once after 3 seconds- continue to hold the power button for another-7 seconds until the light flashes red. If the pairing is successful, the headset will sound a tone and both the headset and adapter lights will turn off.
For both the Plantronics M1000/M1500 (discontinued): If you remove the battery cover from the headset and then remove the battery itself. On the Green PC board itself there will be a letter followed by 4 numbers. These 4 numbers are your personal PIN code.
You can also use the Plantronics Bluetooth Pairing Guide
Feb 05, 2011 | Cell Phones
I have a Dimension 3100 everytime I turn on tower an orange light comes on Please help???????
i removed the connector at "J5J3 pswrd."
this is the blue thing between the battery and the card slot.
i tried everything else such as new M/B battery. remove/change ram. take out extra card, etc.
I just fixed my dell dimension 3100 by doing this.
Mar 08, 2010 | Dell Dimension 3100 PC Desktop
Wont post led 3 flashes
if its the red flashing light on the tower, its the hard drive activity light.
when the monitor goes on stand by, does the tower retain power? (green light on and flashing red light sometimes?) Does your keyboard's scroll lock/num lock/caps lock keys and keyboard lights work?
Sep 07, 2009 | AOpen AX4SPB-UN (91.8AT10.013) Motherboard
PS3 won't turn on
hi Torgsrus.
PS3 Light sequence
The following pictures illustrate the CECHX0X model, however the light sequence is applicable to all PlayStation 3 models.
No lights are on:
When no lights are on, this means that the main power switch on the back of the ps3 is off or the PS3 is unplugged. When the main power switch is off (the '0' is pressed) and you will not be able to access any features of the PS3 system. To turn on the PS3 system, make sure the main power switch is on (the 'I' side is pressed down).
If the PS3 does not turn on:
· Make sure the power cord is not frayed or damaged
· Try using another power cord, if available
· Make sure the main power switch on the back of the PS3 system is turned on
· If you continue to have issues contact our Technical support.
Solid Red:
When the power status light is solid red, this means that the PS3 system is off (or in standby mode).
Standby, mode means the PlayStation 3 system is off, but is ready to be turned on by pressing the power button.
If the ps3 system will not turn on when you press the power button, this is an issue with the PS3 system and you will need to send your system in for service.
Solid Green:
When the power status light is solid green, this means that the PS3 is turned on.
You should be able to navigate the XMB, play games, access the Playstation store,etc.
To turn of the PS3, simply press and hold the power button for two or more seconds.
If the power status light is green ,and you are experiencing problems- have a look on our forums for troubleshooting.
Flashing Red:
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly overheated.
This may be caused by poor ventilation or the vents may be blocked.
If this happens:
· Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like an entertainment area, move it to a more open area.
· Leave the ps3 system off for 30 minutes to let it cool down.
· If you continue to have issue, you may need to send the console in for service.
Flashing Green:
When the power status light flashed green, it means that the PS3 system is turning off. Please wait while the system turns off.
If the PS3 system does not shut down immediately, it may be trying to finish save data to the Hard Drive. If it is, do not turn the main power switch on the back off as it may cause data on your hard drive to be corrupted.
If the green light continues to flash green, the ps3 system maybe trying to write to the hard drive, shutting down or running programs. It may take longer to shut down depending on when you pressed the power button. If the green power light flashed for a very long time, you can try holding the power button down for 5 seconds, the console will beep and should turn off. Then try to restart the PS3 system.
Flashing Green, Yellow and Red:
When the power status light goes from green, to yellow, to green, then to a flashing red, this means that they may be an issue with an internal part with in the PS3 system. This may be caused by a variety of reasons and would need to be diagnosed by our support line.
When the PS3 power light flashes in this order, you can contact our Support Line for further assistance.
Solid Blue:
When the disk status light is remaining a solid blue, it means the disc is inside the PS3 system. If you wish to eject the disc, hold down the eject button for 2 seconds and the blue disc status light will flash indicating the PS3 system is attempting to eject the disc . (NB: the power indicator light will always be a solid green).
If the disc is inserted into the ps3 system, but does not show up on the xmb or will not play, this may indicate an issue with the reader- check our guide Discs are not loading in my PlayStation 3? for further troubleshooting.
Flashing Blue:
When the disc status light is flashing blue, it means a disc was just inserted into the ps3 system or a disc is trying to eject from the ps3 system. Depending on when you pressed the eject button, it may take longer for the disc to eject. (NB: the power light will always be a solid green)
If the light constantly flashes blue, it may be an issue with the disk being stuck in the system. If this happens there is no way to remove the disc yourself if you are using an orginal 60GB PlayStation.
Dec 02, 2017 | Sony Playstation 3 (PS3) Console
Computer shutting down
do you get a blue screen when it shuts off? or... does the monitor just turn off, or does the computer tower and everything turn off?
If everything turns off,(like a normal shutdown) try checking your power options in the control panel, to make sure there aren't some power saving settings that are causing it.
If its a blue screen type issue, then there may be a hardware problem that is causing the computer to shutdown to avoid further damage to the system.
Jun 27, 2008 | Acer Aspire T120 PC Desktop
K800i Not switching on
Hi there, i am having problems with my k800i, it is not turning on & everytime i try to do so, there is a series of red flashing lights from the infra red port. Please help.
Regards
Lubova
Nov 21, 2007 | Sony Ericsson K800i Cellular Phone
Emachine W1135
when ur starting the tower and it light are on and ur fan there is no problem with the power supply, i think that u rily need a new motherboard because ur board will not boot on start up..
Oct 17, 2007 | AMD eMachines Desktop System w/ 17'' CRT...
Computers & Internet Logo
231 people viewed this question
Alun Cox
David Payne
David Payne
