Do not know how to download music files from my PC to the MP3 memory. Does not match up with ITunes or direct download from a CD.
SOURCE: I need to buy a Remote for a Pyle PLDVD65IN in dash cd player
i lost the face of my pyle plts76u i neet to buyit
SOURCE: can the Pyle PLCD-42
Yes there is a couple possible ways.
1. Get 2 RCA Y adapters and split your Preamp Output you will not have any type of fader control this way because you are using a single output.
2. Run one amp from the radio with a set of RCA Cables.
Hook up amp #2 using a Line converter connected to the output of your stereo which will convert you to RCA the just run a cable to the amp..
3. If one of the amps has a High Level Input Run a set of speaker wires from the stereo outputs to the High level Input.
I personally prefer the above 2 methods I find Low Level input sounds better.
Hope this gives you some Ideas and helps
SOURCE: I can't seem to eject the dvd or cd from the pyle
just replace loading belt and it will eject.u can program songs see manual
