Question about Panasonic AG-DVX100A Mini DV Digital Camcorder
How to you fix reel lock problem
I have being geting an auto off reel lock display on my panasonic dvx 100be
how can fix that problem.
My hozelock auto reel has stopped locking. Have tried pulling it all the way out and then releasing but it does not solve the problem.
40 meter Hozelock auto reel would not lock when winding back into the drum.
1, Make sure the Hozelock hose has fully retracted into the drum.there should be no tension on the hose reel spring.
2, Use a Black & Decker Workmate.
3, Carefully opened the side cover taking out all of the Torx screws (10 in total) remove handle.
4, Turned the reel over and placed the auto reel onto the Black & Decker Workmate.
5, Placed a socket into the Workmate vice then line up the centre shaft bolt on the auto reel onto the socket, this will hold the steel spring in place so that I could undo the 2 security Torx screws. Slowly remove the 2 screws- there will be a little spring tension when removing the 2 screws, take care.
6, Lever up the centre shaft up out of the reel to expose the internal hose reel, take note the rotation of the plastic cog inside the cover.
7, Remove the brake locking arm from the side cover.
the arm had broken in half, I used a soldering iron to weld the two halves of the brake lever back together.
8, Rebuild in reverse order.
8, When rebuilding the auto reel use the ratchet and socket to tension the steel spring, I unwound the hose out of the drum then slowly wound the spring using the ratchet and socket. This wound in the hose onto the drum up to the hose stop then a couple more turns on the ratchet for a little more tension.
9, Whilst holding the ratchet keeping the tension on the spring. Replace the 2 security screws on the centre shaft .
10, This link on Youtube I found very helpful (46 sec into video) you can see the internal working and the brake lever.
Apr 24, 2015 | Hozelock 2490 Auto Reel 20m Hose 12.5mm
"where can I purchase a Panasonic DVX 100 camera mains power adaptor
http://www.ebay.co.uk/sch/i.html?_trksid=p2050601.m570.l1313.TR0.TRC0.H0&_nkw=+Panasonic+DVX+100+camera+mains+power+adaptor&_sacat=0&_from=R40 i hope this helps you .
Feb 16, 2014 | Panasonic AG-DVX100A Mini DV Digital...
Auto off s reel lock
Please tell model no. And details.
This error comes in most of panasonic 102b,202 etc models I will give you solution
Khatrricamera@gmail.com
Nov 08, 2012 | Cameras
Error codes E1 to E5
E1: tape end detection LED open
E2: front loading motor lock
E3: loading motor lock
E4: cylinder motor lock
E5: reel motor lock
These are from a Panasonic AG-7500 service manual.
Mar 04, 2010 | Panasonic Televison & Video
PSD Warning Panasonic DVX 102A
I can help you with this.Disassemble the right side which includes the lcd display,so you can see the lens unit.Use a blower to blow air inside and point it to the lens.Better if you can remove the lens unit and blow air on it with caution and then assemble it back the problem disappears.
PS
If problem insists remove ccd block and apply inside a small amount of grease on the metal axis inside ois coil which is used for moving coil mechanism for optical stabiliser purposes.CAUTION THIS ONLY IF NO RESALTS WITH THE ABOVE METHOD.GOOD LUCK!
Nov 04, 2009 | Panasonic AG-DVX102AE DV Digital Camcorder
Reel to reel plays audio backwards
HAVE YOU TRIED TURNING THE REELS OVER? ON SOME PANASONIC UNITS THE REELS CAN BE PLAYED IN EITHER DIRECTION BUT THE SOUND IS REVERSED IF THE REELS ARE UP SIDE DOWN. TRY TURNING THE REELS OVER AND IT SHOULD STRAIGHTEN OUT YOUR AUDIO PROBLEM AS WELL AS BOOST THE VOLUME
JAMESFWALKERJR2006@YAHOO.COM
Aug 29, 2009 | Quantegy 456 Reel-To-Reel Recording Tape...
Panasonic dvx parts
We are one of the Panasonic ASC and so far we had no problem with DVX100P parts. Although that model has been discontinued parts are still available.
Most of the DVX100A parts are common for DVX100P
Eric
www.Digitronelectronics.com
Dec 17, 2008 | Panasonic DVX-100 Camcorder
Panasonic AG-DVX100A Mini DV Digital Camcorder Logo
142 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
