Using original type disks, DS,DD,720MB new and old. Formatted new disks on a 720mb drive and loaded start setup software using all versions of Windows OSs. Setup software is using DOS OS. 90 out of 100 tries of load sequence will fail to load at startup, rarely will load correctly. All disks load properly on different drives. Red light will turn on and disk will turn momentarily and then stop with "NO DISK" indication on organ. Disassembled Technics-Matsushita SY-FD20 drive, cleaned heads, no mechanical resistance of drive and mechanism. Replaced drive belt with new identical and tighter belts. No slippage. Drive not accessable inside ORGAN enclosure. Cannot extend outside organ to observe. Flat 22 conductor male connector not available for extension outside of organ for troubleshooting. Not compatible with any standard PC components. 22 pin Connector is 2 1/4" (57MM) wide. with 2.3MM flat conductor spacing. Board thickness 1.6MM. Cannot find Technics, Panasonic, Matsushita SY-FD20 drive on Internet. This Technics GN3 organ is about ten years old now and needs setup files to work properly for different musical instruments. My next plan is to get it to work with the MIDI input interface installed if I can't get the floppy to work without schematics. I would appreciate any help or suggestions. Thank You.
sa-ex320 I hooked it up after being stored for a couple of years. Was playing great and then I...
(More)
sa-ex320 I hooked it up after being stored for a couple of years. Was playing great and then I turned it up, just after 3/4 volume the sound stopped. The help button says HIGH TEMP...TURN DOWN VOLUME. This happend yesturday so it has had plenty of time to cool and still has no sound.
how much should i ask for my second hand technics sa-ex320 wot was the price new and how old is it...
(More)
how much should i ask for my second hand technics sa-ex320 wot was the price new and how old is it many thanks rob
The remote transmitter (model EUR 644346) won't turn on my Technics audio receiver (model SA-EX110)...
(More)
The remote transmitter (model EUR 644346) won't turn on my Technics audio receiver (model SA-EX110) from a distance of eight feet or so. I press the Power button every which way but nothing happens,usually. Attempting to turn the receiver off with the remote has the same result. The two AA batteries in the remote are fresh.
Contrary to this, once in a while the remote works and the receiver goes on, but that result usually can't be immediately duplicated.
My question--What makes this happen and can the remote be repaired if I took it apart?
