Home | Shredders | Shredder won't shred any...
Shredders
Problem for Shredders
Generic problem for all Shredders
Shredder won't shred any more.
By cac_jac on Oct 28, 2007
Shredded 5 or 6 credit cards, one at a time.  Will not shred anything now.  Can go in reverse, but not forward.  Unplugged it and looked underneath, can't get anything to move - not sure what to do now.
Looked for Infoguard website, found this site.  Any suggestions?  Can't find instruction book, was hoping to download from Infoguard website.
Same Problem
Feb 02, 2009
-   I have the same problem with mine. It will go in reverse, but not work in the forward position. I could hear that the motor was spinning though, when engaged in the forward shredding position. After disassembling the unit, I discovered that the first plastic gear (running directly off the motor shaft) is worn flat about a quarter of the way around the gear. Have not had any luck finding a replacement as of yet, but will post if I do. -   Guest
Dec 30, 2008
-   door light ajar-   rmartinez106
Nov 20, 2008
-   Definely a gear problem, The pin/axle that holds the gear together has snapped off, probably beside the plastic gear. Looking for a replacement gear now.-   Guest
Mar 14, 2008
-   need plastic forward button not working. can swap with reverse and it works.-   JSCOPYMAN
Dec 08, 2007
-   My shredder runs and the paper passes through but does not shred. Before this I had a problem with the shredder running and did not stop unless I pulled the plug-   peggylgb
Best Solution
posted on Mar 02, 2008
Helpful)
fellowesrep
Rank: Guru
Rating: 87%, 143 votes
I personally work with Fellowes brand shredders, but it sounds like you have a paper feed sensor issue. This may be a mechanical or electronic sensor located in the center of the paper feed slot. If it is electronic it may just need cleaning(qtip dipped in rubbing alchohol. If it is a mechanical sensor check to make sure it has not been broken or it may be stuck because of paper that has become wedged behind it(you may need to jiggle the switch a few times to free it). If none of this works you may have a burned out switch or a bad pc board, contact manufacturer for more info.
Was this helpful?
Yes
No
Popular Solutions for Shredders
Questions and Unsolved Problems for Shredders
Answer
My Texet CC11L shredder has stopped working, after too much 'soft' paper, possibly including... (More)
Answer
need drive gear for staples shreadder spl-826x. Thanks
Answer
CX12 motor runs but shredder wheel doesn't turn
Answer
I need to replace the on off swithch for my fellowes shredder Powershred 220. How much and how do I... (More)
7 Other Users Have The Same Problem - Continued
Comment by boboclem, posted on Nov 16, 2007
Have same problem with Mainstays 6 sheet Cross Cut. Does anyone know where I can get a replacement gear for it.
Thanks
Comment by Guest, posted on Nov 07, 2007
Shredded 5 pieces of paper and now it won't shred anything.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Shredders:
Top Shredder Experts
Rank: Guru Guru
Solutions: 709
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Shredder Experts
Top Copier & Fax Repair
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
