Argox X-2000+ Thermal Label Printer Logo
A
Anonymous Posted on Feb 21, 2014
X-2000+ Thermal Label Printer driver - Argox X-2000+ Thermal Label Printer
Zm400 media darkness settings get reset after printings lable from SAP
The printer driver settings override the printer settings unless you tell the driver to use the printer settings. You can tell by setting the printer setting and saving it permanently. Print a configuration label. Send a label to the printer. Print another configuration label. Compare the config labels and If it changed, then the driver changed it. Set the driver as above and it will not change when you print.
Driver for e4205
Free Windows Printer drivers for Datamax can be downloaded here: Custom Design Label Systems from Able Label Systems
Look for the link toward the bottom labeled "Free Thermal Printer Drivers."
1helpful
HAVE A FLASHING ERROR LIGHT. CHECK RIBBON. RIBBON IS NOT USED ON THIS PRINTER. HOW DO I CLEAR THIS UP?
Changing the setting on the printer The default setting is thermal transfer for this printer. You can change the setting on the printer so it doesn't show you the error any more by doing the following: Press SETUP/EXIT Press Plus (+) to scroll through the different parameters About the 6th parameter is "PRINT METHOD" Press "SELECT" to select the parameter Press Plus (+) or Minus (-) to change to Direct Thermal (no ribbon) Press "NEXT/SAVE" to save your changes If you make the changes to you printer and as soon as it prints it reverts back to thermal transfer, then your label software or your driver are overriding it and you need to make the change there.
Changing the setting in your label software - this will also change the settings for this label only Open your label Make the change under "label setup" or "page setup" inside your label software.
Changing the setting on the driver - this will also change the default settings for all future labels that you create Go to control panel and devices and printers. Locate the driver for your label printer and make the change under "Printing Preferences".
1helpful
We have 13 s4m Zebra printers. We try to change from thermal to direct. Which was no problem during our initial test. But when we try to change actual printer that was being place inside a cooler we kept...
2answers
We are in need of thermal printers and Zebra LP
The LP2844 can only print on Direct Thermal labels.
DT labels have the ink within the label and the labels react to heat. If these labels are to be exposed to direct sunlight they will eventually turn black.
Hint:
If you scrape the label with fingernail you can usually see the black ink on label
The physical size of the labels is this max width 1 inch (MInimum) to 4 inches (Max). Maximum length of label depends on the amount of memory in printer but maximum size for standard LP2844 is 11 inches. With full memory can be 22 inches long.
The labels must be on a 1 inch core.
These printer can handle all label types.
1: die cut Labels - Use gap sensing.*
2: Labels with Black mark on back - Use Black mark*
3: Continuous roll - select continuous *
* Select in printer driver media setting
Use the latest ZDesigner Driver V1.5.10
Download from Zebra Website.
Printer Preferences - Advanced Setup - Media Type.
2helpful
PRINTER PRINTS ONE LABEL THEN DISPENSES 4 TO 5 MORE BLANK LABELS. UNABLE TO RESET WITHOUT TURNING UNIT OFF AND REWINDING LABEL ROLL. WE HAVE A COGNITIVE LX THERMAL PRINTER.
Printer needs calibrating. This can be accomplished through the printer driver under 'printing preferences' or the Cognitive Printer Setup Utility.
I need driver for datamax m 4206 e mark II
3helpful
2answers
I can't find a driver for my ELTRON LP2443PSA thermal label printer. Please help
Please send me an e-mail to: [email protected]
With the subject line: Eltron Orion LP2443 PSAT Label Printer, and I will be more than glad to help you.
If you will use this subject line, then it will be easier for me to identify that the message that you are going to send me is NOT spam message. Because I get a lot of junk mail per day. Which is about 75% of the total e-mail's that I get in my inbox every day. And usually I do not have time to go through reading all of my messages, so if the message title will look suspicious, or all capital letters, or all small letters, than I may flag your message as "Spam".
I have the same exact printed which I also bought at the end of January, 2009, which I originally received without any drivers at all, but after I spend a lot of time looking, and with hard work, I finally found the correct drivers that I use for this same exact Thermal Label Printer.
Also, just a suggestion: If you are going to use this printer for shipping online, then you can go to www.UPS.com, and get free Thermal Shipping Labels to use with UPS shipping service.
Currently, I have 2 completely compatible working drivers for this label printer. 1 of the drivers is for Windows 2000, or earlier systems, and the other driver is for Windows XP, or later operating systems. I use the second driver, with Windows Vista, and I have no problems using my Thermal Label Printer.
Therefore, I do not remember where I exactly downloaded the 2x drivers for this Thermal Label Printer, and do not have enough time to upload them online, because I am very busy, but, I do have 2x of the drivers downloaded on my computer, in it's own folder, that I can upload later on to some online file sharing site, like www.mediafire.com.
So, if you still need the drivers for this Thermal Label Printer, please send me an e-mail, and I will be more than glad to help you with both getting the drivers, and if I will have time, or if it won't take me very long time, Installing this Thermal Label Printer on your computer.
Hope I could help you. Thank you very much.
Intermec 3400 label printer - Connected but no printing...
your com setting must be 9600baud 7 data bits even parity
you may need to drop back to win 98
here is the syntax you need to send to the printer STX ESC E5 CAN DATA CR DATA CR ETB ETX PRINT
Top Argox Office Equipment & Supplies Experts
Dominic Harborne
Level 1 Expert
Norman Weimar
Norman Weimar
bvmihai
Are you an Argox Office Equipment and Supply Expert? Answer questions, earn points and help others
