I need to reset my sons tabeo pass code pass word. he accidentally locked it and now he cannot get back into it
If any problem arises in computer, we are habituated to format the PC. The same applies to laptops also. But when there is any problem in your tablet PC, there is no other option except factory resetting. It is similar to formatting. When your tablet gets infected with some virus, or when you got it locked accidentally, or if you feel that your tablet PC is running slow, you might have to go for hard resetting or factory resetting. You might opt for hard resetting due to various reasons, but theprocedure of resetting is similar in most of the tablets. First of all, when you are going for hard resetting of the tablet, you have to check whether the manufacturer of your tablet has mentioned any specialprocedure for it.
In most of the cases, the procedure will be same on all Android tablet, unless specified. You can check the official website of your tablet manufacturer or can also go through the manual book given at the time of purchase of the tablet. If nothing is specified, you can carry out the generalized process. For factory resetting your Tabeo tablet, you have to go to 'settings' page. In this menu, you can find an option for 'hard reset'. If you click or tap this menu, you can get a new options where you will find option for hard reset. In this list, you can also find the option for hard resetting. If you select that option, the tablet will ask for confirmation.
Once you confirm, the tablet will perform factory resetting. Factory reset or hard resetwill wipe of the data present on your tablet. So, it is very much necessary that you take back up of the data present on the tablet before heading for resetting. It is a good idea to keep the back up of all the files regularly so that you can go for hard resetting at any time, if the tablet gives any problem.
My daughter forgot her pass code to unlock her tabeo. Is there a wayto unlock it or reset it
