Sony Ericsson Xperia X10 Mini Pro U20i Smartphone Unlocked Logo
A
Anonymous Posted on Feb 21, 2014
I need a help to open the program
Kernel version 2.6.29 SEMUser@SEMCHost #1
Fix kernel dell xp
There are several different ways that kernel.dll errors can show up on your computer. Here are some of the more common ways that you might see kernel.dll errors:
  • "Kernel.dll Not Found"
  • "This application failed to start because kernel.dll was not found. Re-installing the application may fix this problem."
  • "Cannot find [PATH]\kernel.dll"
  • "The file kernel.dll is missing."
  • "Cannot start [APPLICATION]. A required component is missing: kernel.dll. Please install [APPLICATION] again."
Kernel.dll error messages might appear while using or installing certain programs, when Windows starts or shuts down, or maybe even during a Windows installation.
The context of the kernel.dll error is an important piece of information that will be helpful while solving the problem.
Cause of Kernell.dll Errors
Kernel.dll errors are caused by situations that lead to the removal or corruption of the kernel DLL file.
In some cases, kernel.dll errors could indicate a registry problem, a virus or malware issue or even a hardware failure.
How to Fix Kernel.dll Errors
Important: Do not download kernel.dll from a "DLL download" website. There are many reasons why downloading a DLL file is a bad idea. If you need a copy of kernel.dll, it's best to obtain it from its original, legitimate source.
Note: Start Windows in Safe Mode to complete any of the following steps if you're unable to access Windows normally due to the kernel.dll error.
  1. Restore kernel.dll from the Recycle Bin. The easiest possible cause of a "missing" kernel.dll file is that you've mistakenly deleted it.
    If you suspect that you've accidentally deleted kernel.dll but you've already emptied the Recycle Bin, you may be able to recover kernel.dll with a free file recovery program.
    Important: Recovering a deleted copy of kernel.dll with a file recovery program is a smart idea only if you're confident you've deleted the file yourself and that it was working properly before you did that.
  2. Run a virus/malware scan of your entire system. Some kernel.dll errors could be related to a virus or other malware infection on your computer that has damaged the DLL file. It's even possible that the kernel.dll error you're seeing is related to a hostile program that's masquerading as the file.
  3. Use System Restore to undo recent system changes. If you suspect that the kernel.dll error was caused by a change made to an important file or configuration, a System Restore could solve the problem.
  4. Reinstall the program that uses the kernel.dll file. If the kernel.dll DLL error occurs when you use a particular program, reinstalling the program should replace the file.
    Important: Try your best to complete this step. Reinstalling the program that provides the kernel.dll file, if possible, is a likely solution to this DLL error.
  5. Update the drivers for hardware devices that might be related to kernel.dll. If, for example, you're receiving a "The file kernel.dll is missing" error when you play a 3D video game, try updating the drivers for your video card.
    Note: The kernel.dll file may or may not be related to video cards - this was just an example. The key here is to pay very close attention to the context of the error and troubleshoot accordingly.
  6. Roll back a driver to a previously installed version if kernel.dll errors began after updating a particular hardware device's driver.
  7. Run the sfc /scannow System File Checker command to replace a missing or corrupt copy of the kernel.dll file. If this DLL file is provided my Microsoft, the System File Checker tool should restore it.
  8. Install any available Windows updates. Many service packs and other patches replace or update some of the hundreds of Microsoft distributed DLL files on your computer. The kernel.dll file could be included in one of those updates.
  9. Test your memory and then test your hard drive. I've left the majority of hardware troubleshooting to the last step, but your computer's memory and hard drive are easy to test and are the most likely components that might cause kernel.dll errors as they fail.
    If the hardware fails any of your tests, replace the memory or replace the hard drive as soon as possible.
  10. Repair your installation of Windows. If the individual kernel.dll file troubleshooting advice above is unsuccessful, performing a startup repair or repair installation should restore all Windows DLL files to their working versions.
  11. Use a free registry cleaner to repair kernel.dll related issues in the registry. A free registry cleaner program may be able to help by removing invalid kernel.dll registry entries that might be causing the DLL error.
    Important: I rarely recommend the use of registry cleaners. I've included the option here as a "last resort" attempt before the destructive step coming up next.
  12. Perform a clean installation of Windows. A clean install of Windows will erase everything from the hard drive and install a fresh copy of Windows. If none of the steps above correct the kernel.dll error, this should be your next course of action.
    Important: All the information on your hard drive will be erased during a clean install. Make sure you've made the best attempt possible to fix the kernel.dll error using a troubleshooting step prior to this one.
  13. Troubleshoot for a hardware problem if any kernel.dll errors persist. After a clean install of Windows, your DLL problem can only be hardware related.
Applies To
The kernel.dll error message could apply to any program or system that might utilize the file on any of Microsoft's operating systems including Windows 8, Windows 7, Windows Vista, Windows XP, and Windows 2000.
tip
How to convert lotus notes mailbox to word format?
Kernel For Lotus Notes to Word converter software is an advance and cost effective software program that easily convert lotus notes mailbox to ms word format. You can use this software to quick and safe Lotus Notes to Word conversion. The software support lotus notes version 6.5, 7.0, 8.0 and 8.5 versions and Ms word version 2010, 2007, 2003, 2002, 2000, 98, 97 and MS Word 95 version.
Download free trial version of Kernel For Lotus Notes to Word converter from http://www.notestoword.com/ and visit more detail about this software from http://windowsrecoverysoftware.jimdo.com/2012/07/18/enjoy-the-ease-of-accessing-your-documents-outside-the-lotus-environment/
on Feb 17, 2014 • Computers & Internet
tip
How can I connect the USB Bluetooth bugs in Ubuntu 8.10?
<p>USB and Bluetooth connectivity errors in Ubuntu 8.10 are the result of two different errors. If you are running KDE, you have a patch on their Bluetooth connectivity problems (see Resources) to download correct. USB connection errors are the result of a bug in the current version of the Linux kernel. Run "apt-get package manager to upgrade the kernel is usually the fastest and most trouble-free. After the upgrade, the system restarts. <br /> <p><br /> <p>1. Open a copy of the console when running a graphical user interface (GUI). <br /> <p><br /> <p>2. Type "apt-get update" and press "Enter". <br /> <p><br /> <p>3. Type "apt-get upgrade" and press "Enter". The window that appears available updates. Find anything related to the kernel that "n" followed by pressing "Enter". <br /> <p><br /> <p>4. Type "apt-get install package-name" where "package name" is the updated version of the kernel. Press Enter. Confirm that you have to install the update by typing "Y" and press "Enter". Once the upgrade is complete, restart your computer. <br />
on Jun 26, 2011 • Computers & Internet
Trying to install an Iogear gwu625 in Ubuntu
Hey Richard,
Which version of Ubuntu are you trying to install this on??
The minimum requirement is that you have at least kernel version 2.6.27.5-117 or later installed. This works with Ubuntu 11.04
It will not work with any kernel versions previous to this. If you are having trouble installing it, you might have to upgrade your Ubuntu and kernel version for this to work.
3helpful
4answers
Kernel32.dll can be a problem, so my pc taking too much time to shut down
How to perform kernel32.dll repair, one common methodinvolves acquiring a new version of your kernel32.dll file and installing itright into your registry. This will fix most problems with the file- like ifit's missing or if it's still there but has become corrupted at one point oranother.
tip
How to correctly setup an R4i card version 1.4 (red box)
First, take everything out of the packaging. Turn you computer on and go to your desktop. Then take you MicroSD card out and connect it to/ insert it in the T-flash (the USB port connector), and plug that into you USB port. Wait for the "what do you want to do?" menu to load and click "open folder to view files. After that, go to http://www.ishopvideogame.com/r4i-for-dsi-cid-167.html. Search for your version and download the latest kernel version. ( the kernels are wat say "r4i version 1.4," and etc.) Once you have downladed it, if you do not have an extractor/unzip program go to http://rarlab.com/download.htm and download winrar for you computer. If you already have an unzip/extractor program, use it on the kernel file you just downloaded. You will see a new file appear with the same name. Open the file and drag your mouse over all of the folder's contents, then right click and select 'copy' then paste them into your MicroSD card folder. Thats all you need to do, and for roms you just copy and paste them into the MicroSd card folder. i would suggest making a members account on Romulation.net, a great downloading place for roms.
I have just installed my first dual boot XP and Ubuntu on my old desktop. The floppy drive is recognised on XP but not on Ubuntu - What do I need to do to use it under Ubuntu 8 ?
Here are the steps to follow:
1. Click on "Applications -> Accessories -> Terminal".
2. In the terminal type "gksudo gedit" and enter the system password (you created this when installed Ubuntu). This will enable you to temporarily edit the "modules" file which is usually a read-only system file.
3. Click "Places -> Computer".
4. Click on "Filesystem".
5. Open up the directory (folder) called "Modules". It is the grey icon nearer the bottom of the list (you have to move the navigation bar down).
6. The file "Modules" should open in the "gedit" program.
7. It should look something like this:
# /etc/modules: kernel modules to load at boot time.
# This file contains the names of kernel modules that should be loaded
# at boot time, one per line. Lines beginning with "#" are ignored.
fuse
lp
8. Now add the word "floppy" to the bottom of the file. It will now look like this:
fuse
lp
floppy
9. Now save the file by pressing pressing the "save" icon.
10. Exit the "gedit" program.
11. Now restart ubunutu (reboot the computer).
12. After reboot is complete, the floppy icon should be found under "Places" on the panel. Click on it to open a floppy. Remember to "unmount volume" when you remove or change the floppy. Linux will not let you change floppies like windows by just popping it out.
Hope this helps!
3helpful
2answers
Unstable internet connection with a DSL2640U
I've heard that the issue can be resolved with a firmware update.
Go here to get it.
http://www.dlink.co.za/dsl-2640u_t.php
Intel PRO/Wireless 2200BG Network adapter not recognized
Hi
Check Intel PRO/Wireless 2200BG Downloads - http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=1637
Select Linux from and click on go
You can download Intel PRO/Wireless 2200BG version 1.2.0 or 1.1.0
Installing/updating Intel PRO/Wireless version 1.2.0 driver for Linux
- To extract the archive file, type from a console: tar xzvf ipw2200_linux_1_2_0.tgz
- To install the driver the following is needed:
1. Linux with a 2.6.8+ kernel. See README.ipw2200 for information on
specific options required to be enabled in the kernel.
2. Wireless Extensions (v16) and Tools (v27-pre23) if not included in
your distribution
3. The driver (ipw2200-1.2.0.tgz)
4. The binary firmware image (ipw2200-fw-3.0.tgz)
5. For instructions on how to build and use the driver, please see the INSTALL document in the ./intel_ipw2200_120/ directory.
More info http://ipw2200.sourceforge.net
Regards
Mike
Top Sony Ericsson Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Sony Ericsson Audio Player and Recorder Expert? Answer questions, earn points and help others
