Universal remote I have a ge universal RM24912 and a 29 inch magnavox 27ms343s, none of the codes work and I am having problems. There is a way to set the auto code search on the remote, but I dont know how. Plus the child lock is on the tv, so I cant even turn it on.
  • 1 more comment
  • Anonymous Nov 02, 2007
    i have a universal philips remote ... and i dont know how to do the auto code search help please ...
  • Anonymous Dec 07, 2007
    how to worh the auto code search
  • Maya Vinokurov Jun 13, 2008
    I can't found code for my TV mizubishi
  • 7 Answers
Click Here
For the 4 digit Universal Remote Code List From GE (suppose to work with all GE Universal Remotes as long as they use 4 digits to program.)
Click Here
For the 3 digit Universal Remote Code List from GE (uses 3 digits to program, unless the remote was purchased before August of 2002)
Click Here
For the 3 digit Universal Remote Code List from GE if your remote was purchased before August of 2002.
Posted on Dec 13, 2009
  • RaeNiCoLe Dec 13, 2009
    Oh, and I forgot... If you can't get your device to work with any of those codes, Their instructions to do the Code Search is as follows:
    "CODE SEARCH
    If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of thee code library for your code by following the steps below:
    1. Manually turn on the device (TV, VCR, etc.) to be controlled.
    2. Press and hold the SETUP button until the red indicator stays
    on, then release the SETUP button.
    3. Press and release the desired Mode button (TV, VCR, etc.). The
    red indicator blinks once, then stays on.
    4. Press the CHANNEL UP button (or Play for VCR/DVD)
    repeatedly (up to 300 times) until the device to be controlled
    changes channel. The red indicator blinks, then stays lit.
    5. Press and release ENTER to install the code. The indicator light
    goes off.
    Most users will search and store DVD codes under the DVD button, Cable codes under CBL, etc. If you want to search and store a DVD code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY DVD code in step 3 of the Direct Code Entry. Then follow the steps above for Code Search.
I have a ge universal remote and my tv is a Magnavox can I find the code for my tv with this remote
You can use code search to find something that works. If a search through all codes stored in the remote fails, you may have to try a different universal remote (such as Philips). All universal remotes do not store all possible codes.
Jul 07, 2016 | GE Televison & Video
I have a ge universal remote. I've put in all the codes to my tv and none of them worked. My tv is a magnavox mod# 20ms34442/17 can you help?
What model number of the remote do you have? I also have a GE universal remote and I have used it on over 30 tv's and every single 1 worked. Do you do the autoscan or put them in manually?
Dec 30, 2012 | Philips Magnavox 27MS343S 27" TV
Unable to turn magnavox TV on. Child lockout is on and unable to turn on TV. Do not have original Magnavox remote. I do have a Universal RCA Remote. Can you give me the code for my RCA Universal...
What brand is your universal remote? Best thing would be to go on the universal remote manufactures website and they should have a list of codes for models based on what model number your universal remote is. Then you can look up possible codes for your tv found in the users manual (which you can print from online) and it gives you like 5-7 codes that you try and will give you instructions on how to enter the code and save that code to your remote. I hope that helps.
Aug 16, 2009 | Philips Magnavox 27MS343S 27" TV
New GE universal remote, but none of the codes work for my tv
Try one of these magnavoz codes=164-116-003-363-333-226-390-467-431-594, put them in remote one by one. Hope they work for you. God-Bless! These are the codes I got with my remote!
Oct 27, 2017 | TruTech T2000D TV
Codes
You have to check the instructions for the universal remote. The codes are not "universal", just the remove it.
If it's not in the manual, check the manufacturers website.
If that doesn't help, start trying the codes in the manual one at a time until you find one that works. If none of them work, buy a different remote.
May 07, 2008 | Philips Magnavox 27MS343S 27" TV
General electric Universal remote control codes
i lost my code book for my ge remote control
Apr 11, 2008 | Broksonic CTVG-5463GVC 19" TV
Universal Remote not working
With nearly all brands of universal remote control, there is usually more than one code for Philips. Keep going through the codes until you find one that works correctly.
So if you know that the 1st code doesn't work, then don't save it, and move to the next.
You may find that several codes will actually put the TV into standby, but other functions will be different.
Mar 12, 2008 | Philips Magnavox 27MS343S 27" TV
Need RCA univeral remote control code for Magnavox 27MS343S
Push in and hold code search button until it stays lit, then pushed the TV button, it flashes quickly. Then hit the number zero once, then hit channel up button until tv finally changes channel. Hit the mute button once to get it to store the code.
Feb 20, 2008 | Philips Magnavox 27MS343S 27" TV
Magnavox 15 inch lcd hdtv
the typical power cord is usually the same kind that is plugged into your monitor right in front of you. Buy another one of those. A universal remote should work (not promising anything)
Feb 12, 2008 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
1,408 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
