Question about Dell UltraSharp 1901FP 19" Flat Panel LCD Monitor
Dell 17" flat screen monitor
Monitor does not come on. Power light flickers intermittently. Might be a loose wire but I do not know how to get the display open. E173FPC
Thanks in advance for your help.
Rich
rhalama@gmail.com
    Novelist:
  • 138 Answers
This is the way how to examine where the problem is. You have to check that you can see the image on screen by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons (Power on both cpu and monitor), there will be a minor problem. Like me, I can see window image using flashlight and check lamps inside. Some of them were broken. It can be easily replaced. If you cannot see any icon on the screen. I would say that there are some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or dark spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Posted on Feb 10, 2008
Monitor intermittent power problem and horizontal green flickering lines
separate wiring. touching wires creates cross-talk of signals.
Jan 28, 2014 | Computers & Internet
Dell 1704FPVs 17
Check you video cable ..if loose tight the screw..if still the problem presist try changing the video cable.
Sep 26, 2012 | Dell 1704FPVs 17" TFT LCD Flat Panel...
My Dell 17 inch monitor keeps dying out. At first, it would flicker black and then go back to the original setting. Now, it flickers black and dies out -- the "on" button goes from green to...
You can verify that it is the inverter going out by turning the monitor on in a dark room and shining a light directly into the screen. If you cannot see anything, then something has happened to the power circuit. Perhaps the solder on the power port has gone bad, and needs to be redone, or part of the circuit board fried. The only way to figure this out is to open it up and take a look-see. If you don't wish to try this, you can always take it to a shop and have them look at it. Be careful opening it, the inverter is high voltage. Don't have any power going to the monitor if you do this.
Mar 11, 2011 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
The DELL E172FPb LCD Monitor (switch light flicks green)scr black
hi, extremely common problem for dell 17 in monitors. the capacitors and transistors on the power board internally have gone bad. to get repaired, it may cost 40-50 at a shop. i have repaired these in the past and they always come out well for at least 3 more years. may want to find another monitor though. if you would like steps on how to repair, let me know and i will find my old repair threads to give to you.
May 12, 2010 | Dell E173FP 17" LCD Monitor
Describe your Dell E173FP 17" LCD Monitor Problem The monitor seems to be turning itself repeatedly on and off. No picture is ever seen, the screen stays black with a slight flicker.
Sounds like the monitor is cycling power.
Try plugging the monitor into a different power socket. Try not to use the same power bar as your computer
Mar 24, 2010 | Dell E173FP 17" LCD Monitor
Strobe-like flickering in upper half of Dell monitor
The problem is the inverter on your dell monitor this is very comon.
Jun 15, 2009 | Gateway XHD3000 LCD TV
Dell 17'' flat panel monitor power light is blinking
some transistors on the board have shorted they supply power to the inverter to run the lamps, they power is not cut off intermittently and the protection circuit has stopped the monitor. the fix is here
http://josepino.com/other_projects/?howto-repair-dell
goo dluck if you want it fixed for you let me know
Mar 22, 2009 | Dell E173FPf 17" TFT LCD Flat Panel...
Flickering switch light, blank screen
Hi, First of all it is not advisable to open up monitors without proper tools as they contain hazardous elements. Dell monitors however do have a 3 year SEPARATE warranty. Check on the back of the monitor and look for the monitor serial number. is should start with CN-xxxxx-,, or JP-XXXXX-. give that to a dell tech and they should be able to replace that.
Oct 01, 2007 | Dell E173FP 17" LCD Flat Panel Monitor
Power light going to blinking amber
Sounds like a problem in the monitor's power supply. This will need component-level troubleshooting.
Jan 01, 2007 | Videoseven R17PS 17" LCD Monitor
Dell UltraSharp 1901FP 19" Flat Panel LCD Monitor Logo
156 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
