Question about Microsoft Windows XP Professional for PC
Computer boot up
When booting up my computer it's verifying the DMI pool data then hangs. On the line under that there is this symbol Yo Yo with 2 dots in the middle of the O's, looks like an electical outlet, what are these and what can i do to fix this? I have tried everything, bios, removing video card and putting in another, taking out the ram, unplugging everythin, everything imaginable. I do not want to do a clean install or wipe the drive clean this is a fairly new hard drive with things i don't want to lose.
Thank you in advance, GerBear
    Scholar:
  • 127 Answers
Just worth a try if your using XP. :) using XP recovery console:
To run the Recovery Console from the Windows XP startup disks or the Windows XP CD-ROM, follow these steps:
1.    Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
2.    When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3.    If you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
4.    When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5.    At the command prompt, type the command:
chkdsk  /r
6.    When finished checking, exit the Recovery Console and restart the computer, type exit at the command prompt, and then press ENTER.
Also verify that your HD has been set to master in Primary IDE and the others (if you have like CDROMS) in as slave.
Posted on Oct 28, 2007
Verifying DMI Pool Data..... please help
http://www.duxcw.com/faq/computer/dmi.html
also depending on the operating system, you may have to insert Operating System DVD and boot and select "Boot Repair" or "Startup Repair"
Mar 26, 2015 | Panasonic Computers & Internet
Restore disks didn't find ghostdriver
DMI pool data is a normal boot process if it never boots past this then there is usually a driver or new hardware conflict.....if you have installed any new hardware remove it and try to boot again
Apr 08, 2010 | E-Machines eMachines Desktop PC
Yea sorry, forgot that tid-bit of info. It,s the W3118 eMachine / Gateway FIC K8MC51G
This issue can be caused by any of the below reasons.
-Corrupt boot files on the computer.
-Settings for hard disk drive are not correct.
-Floppy diskette or CD in computer causing issue.
-Boot devices not set properly.
-BIOS corrupt or misc. setting not set properly.
-Connections loose or disconnected.
-Bad Hard disk drive or other bad hardware.
Solution:
If the computer has no bootable files on the drive it is attempting to boot from it is possible that the computer may halt at " verifying dmi pool data..."
To resolve this issue:
Boot from a bootable floppy diskette. Ensure that this diskette was made on the same Microsoft Windows operating system that is installed on your computer.
Once at the A:\> prompt type "sys c:" and press enter. This should report the message "File system transferred." Once transferred remove the diskette and reboot the computer.
If the computer continues to not boot attempt to re-create the master boot record by booting from the bootable floppy diskette again. Once at the A:\> prompt type "fdisk /mbr" and press enter. This should return you to the prompt without giving you any message. Once at the prompt remove the diskette and reboot the computer.
Note: The above information only applies to Microsoft Windows users. If you are running a Linux / Unix variant or other operating system such as OS/2 and the computer is freezing at this DMI message ensure that Linux / Unix has been properly installed first and/or your boot manger is not corrupt.
The computer freezing at "Verifying dmi pool data..." may be caused when the hard disk drive settings within CMOS are not set properly. Enter CMOS and verify that the hard disk drive settings are set properly and/or that it is set to Auto Detect.
Verify no floppy diskette or CD is in the computer. In some cases the computer may be trying to boot from either of these drives causing issues with the boot sequence.
The computer stopping at " verifying dmi pool data..." can be caused when the boot devices on your computer are not set properly in CMOS. First, verify that no CD or diskette is in your computer. If a CD or diskette is in the computer attempt to remove this first to determine if it was attempting to boot from it.
If No CD or diskette is in the computer and your computer still halts at the DMI message enter CMOS setup and verify that the boot options are set properly. We commonly recommend that the floppy be set the first boot device, hard drive as the second boot device and the CD-ROM as the third boot device.
If none of the above recommendations have resolved your issue attempt to reset the BIOS / CMOS settings to the factory or default settings.
If the computer has been recently moved or new hardware has been installed in the computer it is possible that a connection may be loose or even disconnected. Verify that the hard disk drive, floppy and CD-ROM cables are properly connected.
Bad hard disk drive or other bad hardware
If you computer continues to freeze at the DMI message after attempting all of the above recommendations it is possible that the computer may be freezing because of a bad hard disk drive or other bad hardware in the computer.
Before replacing any hardware we first recommend you attempt to erase everything on the hard drive and start over.
If you're unable to get to the point of re-installing the operating system it's likely your computer has a hardware issue and it's suggested that the hard drive be replaced. If that doesn't resolve the issue then have the motherboard replaced.
Oct 20, 2009 | E-Machines eMachines Desktop PC
This Acer AST 160 I'm working on crashed...
Computer stops at verifying dmi pool data. Issue: Computer stops at verifying dmi pool data.
Cause: This issue can be caused by any of the below reasons.
  1. Corrupt boot files on the computer.
  2. Settings for hard disk drive are not correct.
  3. Floppy diskette or CD in computer causing issue.
  4. Boot devices not set properly.
  5. BIOS corrupt or misc. setting not set properly.
  6. Connections loose or disconnected.
  7. Bad Hard disk drive or other bad hardware.
Solution: Corrupt boot files on the computer
  • Boot from a bootable floppy diskette. Ensure that this diskette was made on the same Microsoft Windows operating system that is installed on your computer.
  • Once at the A:> prompt type "sys c:" and press enter. This should report the message "File system transferred." Once transferred remove the diskette and reboot the computer.
If the computer continues to not boot attempt to re-create the master boot record by booting from the bootable floppy diskette again. Once at the A:> prompt type "fdisk /mbr" and press enter. This should return you to the prompt without giving you any message. Once at the prompt remove the diskette and reboot the computer.
Additional information about the "fdisk /mbr" command can be found on document CH000175.
The computer freezing at "Verifying dmi pool data..." may be caused when the hard disk drive settings within CMOS are not set properly. Enter CMOS and verify that the hard disk drive settings are set properly and/or that it is set to Auto Detect. Additional information about entering CMOS setup is found on document CH000192.
If No CD or diskette is in the computer and your computer still halts at the DMI message enter CMOS setup (steps found on document CH000192) and verify that the boot options are set properly. We commonly recommend that the floppy be set the first boot device, hard drive as the second boot device and the CD-ROM as the third boot device.
Sep 10, 2009 | Acer Aspire T160 (AST160UA3400) PC Desktop
My Zenith PC displays Verifying DMI pool data . Update Success
Sometimes this can be even simpler. Put in your Windows CD and boot to safe mode command prompt and type fixmbr. This will repair your master boot record for your primary boot harddisk. Eject the windows CD and reboot and see if it fixes your problem.
Sep 02, 2009 | Computers & Internet
Hangs during boot. Last entry on screen is "Verifying DMI Pool Data........" Then blinking cursor at bottom of screen
restart the machine in Safe Mode. And restore to a back date. Alternatively, at boot time press F8 and select When OS booted correctly or some such option, meaning that when your PC booted correctly the last time.
Aug 07, 2009 | Northgate (STAX2517C2) PC Desktop
My first build,when I boot up the screen hangs up at verifying dmi pool data??This has been going on for 2 days.I have reset my bios,changed dvd drives and made some changes in the bios.Still hangs up at...
Is the error from the board boot up before windows engages? If so, perhaps a faulty program in the BIOS PROM/EPROM. Just to let ya know, Windows is very picky about just taking a drive and using it in another computer. They like you to RE-Register usually by buying the Op-System. They only way around this is to boot up the HD in the original system and do the "Transfer to Other Computer Procedure" before you swap the hard drive to it.
Else, you'll need to buy Windows for the new unit. Sory, but that's Microsoft's way of protecting their software.
Jun 12, 2009 | Microsoft Windows? Vista Home Premium...
No harddrive detected, verifying dmi pool data, disk boot failure
Help on making a bootable XP install CD for including storage device drivers (such as SATA drivers that's not included in older XP CDs): http://rapidshare.com/files/211421782/nLite_Instructions_XP.pdf
Follow my brief instructions to make an updated XP CD.
May 15, 2009 | Acer Veriton 7500G PC Desktop
Frezes at verifying DMI settings. Already changed MB and Power supply. Lan connection only flashes green once in a while should be constant. Tried on a working terminal and does the same.
The Desktop Management Interface (DMI) is a new
method of managing computers in an enterprise. The
main component of DMI is the Management Information
Format Database, or MIFD (the DMI Pool Data). This
database contains all the information about the
computing system and its components.
At times, some systems may experience hang
conditions after partitioning, formatting and initial
bootup of a hard drive. The message, "Verifying DMI
Pool Data" appears and the system hangs. This
condition may continue after the drive has been
removed.
! WARNING ! ALL SUGGESTIONS LISTED IN THIS
INFORMATION BULLETIN ARE BIOS RELATED. FOR
A PERMANENT SOLUTION, MAXTOR RECOMMENDS
THAT USERS CONSULT THEIR SYSTEM OR
MOTHERBOARD MANUFACTURER FOR BIOS
UPGRADES.
Suggestions to Resolve the Condition:
1.Apply power to the computer.
2.Access the system BIOS.
Set the drive type as None or Not Installed.
Load BIOS Defaults
Load SETUP Defaults
3.Save the BIOS changes and reboot the PC to a
System Boot Diskette.
4.Shut down the PC after the memory count is
displayed.
5.Reconnect the power and interface cables to the
hard drive.
6.Access the System BIOS.
7.Auto-Detect the hard drive. Ensure that the LBA
Mode option is enabled.
8.Save the BIOS changes and boot the PC with a
System Diskette.
9.Partition and format the hard drive via the
operating system.
10.Reboot the system. On bootup, the screen should
read:
Update Successful
The system should continue booting normally.
Other Possible Solutions:
2.Access the System BIOS.
3.Disable both the Internal and External CPU Cache.
These features are located in either the "BIOS
Features" or "Advanced Settings" options of the
BIOS Setup.
NOTE: Consult the System or Motherboard User's
Manual for exact location of the Internal and
External CPU Cache settings.
4.Save the BIOS changes and reboot the PC to a
System Boot Diskette. On bootup, the screen
should read:
Update Successful
5.After the system successfully boots, re-start the
PC and access the system BIOS.
6.Enable the External CPU Cache. This feature is
located in the "BIOS Features" or "Advanced
Settings".
Manual for exact location of the External CPU
Cache setting.
! WARNING ! User's MUST re-enable this feature
for optimal system performance.
7.Save the BIOS changes and reboot the PC to a
should read:
Update Successful
NOTE: If the aforementioned suggestions fail to
resolve the issue, contact the system or motherboard
manufacturer to:
Remove the "Clear CMOS" Jumper and reset the
system BIOS
Obtain a Flash BIOS Upgrade
from pc help;
SYSTEM HANGS AT MESSAGE: "VERIFYING DMA POOL DATA":
You did not say what operating system you are running but I assume Windows 95 or 98. It is possible some Windows
system files are corrupted or perhaps the system doesn't like your ram (if you added or installed ram recently). There
is also a possibility that there is something wrong with your BIOS and you *may* have to update it, but I would avoid
doing that if at all possible.
A quick fix - if the problem is software related - is to:
1. boot to a Windows startup disk (one that matches your operating system). this step assumes that your PC is setup
to boot to the A: drive before the C: drive (via the BIOS SETUP program). If you don't have a Windows startup disk,
you will have to make one on another person's computer that has the same version of Windows. You make one via:
my_computer/control_panel/add_remove_programs/startup_disk
2. run "scandisk c:" to make sure that any file corruption is fixed before going to next step
3. do a "sys c:" from the "a:" prompt to transfer a good copy of Windows system files to c: drive
4. remove the boot floppy, reboot the system and see if all is well.
If that does not solve the problem you may have to reinstall Windows 95/98. Ouch!
I recently had someone bring me a computer that had this DMI error message problem and I tried the "sys c:" method
(with the startup disk) without success and had to entirely reinstall windows 95 (and almost all applications except for
some programs that did not need to be placed in any Program Files directory or other special location) to cure the
problem. However nasty a job that is, it did cure the problem.
Jun 23, 2008 | Computers & Internet
Microsoft Windows XP Professional for PC Logo
119 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
