Question about Olevia LT27HVX 27 in. LCD Television
Olevia input issues - Olevia LT27HVX 27 in. LCD Television
I can't get my Olevia tv (537-B11) to scan for channels
I don't know this model of TV, however, you may find that you need to use the Source button on the remote to cycle through the available inputs & select digital tuner as the input source before you press the Menu button & go into the setup section.
Jan 05, 2014 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
Turns on to olevia screen but then just flashes the olevia logo
Just check the input connection. Check it connected with external antenna. Check its input selection. Refer the user manual for details.
Feb 26, 2013 | Olevia 26" 226-t11 hdtv widescreen lcd tv...
Front panel switches and inputs disabled
Yes it is, it is, after all it is an input. Here is the owner's manual that should tell you how to reset:
tv.manualsonline.com/manuals/mfg/olevia/olevia_flat_panel_telev
Jan 13, 2013 | Olevia 32" 232v 1080i widescreen lcd hdtv...
No signal! Need help with HD input!
Can you please go through guidelines in the operation manual, especially what system/format is supported in HD input?
Aug 22, 2012 | Olevia 227-S11 27 in. LCD TV
I hooked my olevia tv up to cable tuner box but cannot get a pict
Try switching throught the various video inputs on your tv until you get a picture.
Jan 30, 2009 | Olevia LT32HVM 32 in. LCD Television
Channel Scan
If you have not discarded your old conventional TV or can borrow one, I would connect it to the same signal source you are using with the Olevia. If you get reception with the substitute set, then the Olevia is defective. If you live in a metropolitan area, you could also try sticking a piece of copper wire into the input of the Olevia and selecting antenna input as the source from inside the Olevia's setup menu. If you still get no signal indications (quality is not important for this), then the Olevia is defective.
I'm disappointed to see you having trouble with this set as we own one too. Also disturbing is Olevia's current state; they are in bankruptcy so I would start complaining soon and loudly if you have satisfactorily   identified the Olevia as the problem.
Nov 24, 2008 | Olevia LT42HVi 42 in. LCD Television
Says no signal when switched to hdmi when there is one.
Have the same problem with a 532H - but here is what I did to resolve the issue:
1) Click your Menu button on the TV remote.
2) Go to Screen (click the right button)
3) Go to Main Picture Source (click the right button)
4) Select HDMI (click the Menu button when done)
Aug 20, 2008 | Olevia LT27HVX 27 in. LCD Television
Dark picture on composite inputs ?
Are there any other components connected to your set?
There could be a conflict with those devices is the reason I ask..
Mar 28, 2008 | Olevia LT32HVE 32 in. LCD Television
FIOS remote with Olevia 532B12
I just got FIOS and had an Olevia 237 TV. Tried the LG, Phillips, RCA and Yamaha codes, no luck so I tried this:
- press and hold TV key
- still holding TV key, press the OK key and release both, device keys blink
- press 922
- point remote at TV and press play button
- press next button (two arrows pointing to right) about 325 times until the TV goes off.
Remote controls power, volume, input, and aspect.
Jan 10, 2008 | Olevia LT32HVM 32 in. LCD Television
QUESTION ABOUT PROGRAMMING CABLE REMOTE TO T.V
the code for olevia for cox cable is 1610. Hit tv then hold setup till light blinks twice. release setup. enter 1610 and wah lah
Dec 31, 2007 | Olevia LT42HVi 42 in. LCD Television
Olevia LT27HVX 27 in. LCD Television Logo
Top Olevia Televison & Video Experts
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
