Question about Dell Dimension 5100 (D51L1) PC Desktop
Reinstall system How do I reinstall our Dimension 5100 Dell Desktop back to it's original state? Our son has messed it all up and now I can no longer burn cd's and when I try to bring up anything that has microsoft on it it tells me that I am not connected to the internet when I am? I do not know a lot about computers and need help please!
  • 55 Answers
Re: Reinstall system
Solution depends on what CDs you got from Dell. Generally you are best off doing a Windows XP repair install from the CD. Follow these instructions and you should get a working version of windows and still keep all your programs, documents and settings.
If you have a system restore CD you could loose all your data and settings so use this carefully.
You could try typing sfc /scannow into the run box (Start, Run) and this should repair damaged files. Errors with the internet connection can be caused by viruses or spyware. Try a trial version of Nod32 from
and see if that helps.
Posted on Oct 28, 2007
  • 1,601 Answers
    Problem Solver:
  • 5 Answers
Most computers you buy from vendors come with what is called a "recovery disk" it is a disk that restores the operating system to how it was when it was originally shipped. Before using the recovery disk make sure to backup all important files to another location (to cd/dvd or in this case to an external hard drive, usb drive or other computer). Once all important files and information is backed up use the recovery cd to recover the operating system.
If the recovery cd has been lost or was never shipped, call Dell and ask for their advice. If they are unable to to send a recovery cd for your system or support for that system has been discontinued, proceed to a local PC repair shop and be prepared to pay some $$$ for them to do what I suggested.
Good luck.
0 characters
3 Points
I want to make a windows xp tower run to its optimum
Windows XP is no longer supported by Microsoft, you should load Win 7.
May 02, 2013 | Dell Dimension 1100 PC Desktop
Dell 8400 Boots to Black Error Screen in XP States to reinstall System 32
This might be caused by hard-drive failure. You should run hard drive test from BIOS to make sure hard drive is ok. You can access BIOS by pressing F2 during start up, from there start hard disk self test and wait for it to complete.
If hard drive is ok after test, insert in your original Windows installation media and reinstall OS.
Oct 02, 2012 | Dell Dimension 8400 PC Desktop
More likely it is a HDD problem, allow it to reinstall system 32
Error messages say: root32\hal.dll missing or corupt. :setup cannot copy file :fsusd.dll. :NTLDR is missing. : also i cannot use the safety mode. My computer is dell dimension 5100 os windows xp home
Good day. Regarding this error that you have you its just a normal thing for Operating system such as windows xp to get corrupted. Most software do as well. What you need to do is to have your windows xp reinstalled on your computer or you might consider using another installer of windows xp if it continues to show the same error after you reinstall it in your system. Hope this information help you a bit in resolving your problem. Have a great day to you.
May 23, 2011 | Dell Dimension 5100 (D51L1) PC Desktop
Dell dimension 5100 will not boot, numbers 2 and 4 illuminated on front panel
According to the manual this indicates a possible failure of the graphics card. The solutions from your manual: • If the computer has a graphics card, remove the
card, reinstall it (see page 71), and then restart
the computer.
• If the problem still exists, install a graphics card
that you know works and restart the computer.
• If the problem persists or the computer has
integrated graphics, contact Dell (see page 116).
The manual is available as a PDF at:
I hope this helps.
Feb 16, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Bios screen freezes at startup
go to bios/set up and check in advanced set up and select the first boot device as HDD 0 or HDD 1 (hard disk 0 or 1) and also you need to see that the hard disk is seen in the bios, save and qite. if it is the same reinstall the operating system
May 23, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
How do I return our Dimension 5100 Dell Desktop back to it's original state? Lost the recovery CD.
Have you tried restoring your operating system to a previous restore point?
To do this click on start- all programs - accessories - system tools - system restore. Then choose a date from the calendar which corresponds to a time before you began to experience problems on your PC. Follow the on-screen instructions to restore your PC to its original state.
Note that a system restore will remove any programs which were installed AFTER the selected restore point date.
Hope this helps.
Apr 19, 2009 | Dell Dimension 3100 PC Desktop
Dell dimension 5100 won't burn CDs from itunes suddenly.Error comes up once Disc starts to burn. Any ideas?
There is a problem in your system. did you try burning using other application such as nero or other burning program.
try to reinstall your itunes program and then install again after restarting. else your system need to refresh so that all application program will be seat organize and and functional.
Mar 02, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Power problem on Dell Dimension 5100
plz check the ram and powersupply unit and try to reset the bios
Sep 02, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Ethernet Controller
I had to reinstall XP like 6 months ago, on a dimensions 3000. just reinstall the drivers. here i think this is all of the drivers.
just start "Dell Driver Reset Tool.EXE"
and run "Sownd driver for 3000.EXE"
driver for vga "Intel(R) 82865G Graphics Controller.exe"
and the Ethernet driver "Intel PRO100 VE Network Connection.exe"
Click Here for a zip of all the drivers.
Feb 05, 2008 | Dell Dimension 3000 PC Desktop
Dell Dimension 5100 (D51L1) PC Desktop Logo
197 people viewed this question
Top Dell PC Desktops Experts
Brian Sullivan
Brian Sullivan
Are you a Dell PC Desktop Expert? Answer questions, earn points and help others
