Question about ASUS P5P800-VM Motherboard
Motherboard problem my system sometimes very well. but frequently and not always hangs with zing display. i tried by changing sockets of RAM but the same problem. i have two zion RAMs of 256 MB each. i have also tried with one RAM but the same problem. sometimes hangs during boot up. last time i have entered set up. but the same problem occured while i was checking hardware monitor.
  • 4 Answers
Start troubleshooting by unplugging everything from motherboard, leaving only power supply, motherboard, cpu, memory. also check make sure cpu fan/ heatsink assembly is attached securely and if encounter no problem booting like this, add harddrive, repeat, then add optical drive, repeat.
also when you check hardware monitor, what do u get for readings, i.e. temp and voltage?
Posted on Oct 30, 2007
SOURCE:
Have asus p4s8x mob,when adding 3rd stick of memory (1gb) total of 3gb.computer hangs on startup 1long 3 short beeps. if i remove one old stick and leave new with old (2gigs total)it works fine,also works...
The Asus Asus Motherboards P4S8X-MX uses PC-3200 type memory and usually ships from Asus with 0MB of RAM. The Asus Motherboards P4S8X-MX supports up to 2GB of RAM. Maximizing your system memory will allow your Asus Motherboards to operate as fast as possible and offer the most productive environment.
RAM modules must be installed in special locations on the motherboard called Sockets. These memory sockets are what hold the RAM module in place and can range from 1 to 16 or more. Banks consist of a group of 1 or more sockets. A system can have 1 or more of these banks of sockets. If a system has more than 1 socket in a bank, a Kit must be purchased for that bank. A kit is simply more than one, usually 2 or 4, like RAM modules. All sockets in a bank must be filled, and for such systems we sell memory in a kit. Typically you will see 2x512MB or 2x256MB signifying you are purchasing 2 units of 512MB RAM modules or 2 units of 256MB RAM modules, respectively.
The Asus Asus Motherboards P4S8X-MX has 1 bank(s) which have 2 socket(s) in each bank for a total of 2 memory socket(s). This means the Asus Motherboards P4S8X-MX can support up to 2 individual RAM modules.
We recommend you purchase the largest capacity RAM module each time you purchase memory. The reason for this is if you decide to upgrade again later and all your memory sockets are filled, you will not need to discard the already installed lower capacity memory.
Below is a visual representation of the memory bank(s) and socket(s) configuration for the Asus Asus Motherboards P4S8X-MX.
Standard Memory Bank & Socket Configurationsocket_2.gif hope this helps John
Jul 01, 2011 | ASUS P4S8X Motherboard
Hello, i have had frequent problems with
MOSTLY BEEPING INDICATES THAT YOU HAVE RAM PROBLEM, TRY TO CHANGE YOUR MEMORY RAM WITH SAME TYPE..EVEN SOMTIMES SYSTEM WILL BE OK, IF PART OF RAM IS DAMAGED, IT WILL DO THE SAME PROBLEM...OR THE OTHER WAY, IF YOUR SYSTEM COMES ON , TRY TO GO TO THE SYSTEM INFORMATION AND CHECK YOUR TOTAL RAM GIVEN, IF IT IS LOWER THEN THE CORRECT AMOUNT INSTALLED, CHANGE IT....BUT TRY TO REPLACE YOUR RAM...
Oct 14, 2009 | Intel Motherboard
I have the same problem
check to see if the CPU is connected to ur motherboard securly and check RAM aswell.
Jun 06, 2009 | Intel D845GVSR Motherboard
MCP6P-M2 v6 not working?
u should change the ram and try again.
Jan 16, 2009 | Biostar MCP6P-M2 Motherboard - v6.0,...
System in hanging
try to replace your RAM
Jan 13, 2009 | Intel Motherboard
Hanging problem
D845GBV no display in skrin.bib tone continuously for 03 times nonstop, after which nothing happens except for cpu fan running.
Sep 03, 2008 | Intel D845GVSR Motherboard
Pc hangs up oftenly or show blank screen
Set your C Drive as Master and other all Drives as Slave
I Think this will slove your problem
Try IT
Mar 07, 2008 | Intel D845GVSR Motherboard
Please help
that shows that the ram memory is low, you need to upgrade to at least 256 or 512mb. because everytime you use the internet a there will always a temporary file that saves. you need to maintain your system by atleast amonth disk clean up. but the best is the you need to upgrade your ram memory
Oct 29, 2007 | ASUS P4S800D-X Motherboard
Display
512 is not alot of memory (especially when running windows XP) as XP needs at least 512 to run (since SP2)
I am not familiar with the Zion brand, I tend to use Crucial or Kingston.
to find the correct mem for your board you can use the Kingston Configurator (just input the manufacturer and part details of your board and it will give you the products that work for your board.)
www.kingston.com
Oct 25, 2007 | ASUS P5P800-VM Motherboard
ASUS P5P800-VM Motherboard Logo
70 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
