Question about LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher
LG LD12AW2 leaking
I have an LG LD-12AW2 Which is leaking from the left hand bottom corner of the door. It seems to me that the dishwasher is filling up with far too much water. It starts to leak quite bad after only a minute or two.
  • 1 more comment
  • kelsa Dec 08, 2007
    Hello
    My LG ld12aw2 also leaks from the front of the machine, seems the machine keeps filling up with water and the fill switch dosn't cut off water supply. From previous post where can i locate the fill switch so i can try to clean it. thanks for your help.
  • kayecaru Jul 20, 2008
    Our dishwasher is doing the same thing and i have read the post. The second person asked for the location of the fill switch, but to my knowledge never received a reply. Can someone please advise me where the fill switch is located so i can see if it is contaminated.
    Thanks
  • Anonymous Mar 29, 2014
    starts to leak from the bottom after about 5 minutes and I can't see exactly where the leak is
    Scholar:
    New Friend:
  • 67 Answers
The fill switch may be contaminated with soap or debris that makes it heavier and makes it float lower in the water which means more water is required to trip it. Try moving it manually and see if it is hard to move at the top of its travel.
Posted on Nov 30, 2007
My LG dishwasher - model LD-12AW2 has 'E1' alert & won't work
This sounds like a anti flood activation due to water leak / spill detection. This device (polystireen float and micro switch) at the base of the washer detects any water leak and stops the washing cycle once water leak activates the switch via the float. Check if any water at the base of washer is cuasing the float to activate the switch. Rectify any leak / spill (normally a pipe / clamp) and this should solve the problem.
Mar 26, 2010 | Dishwashers
LG LDS 5811 has started leaking at the bottom of the door left hand corner.
Could be 1 of 2 things.
1: Open door and look for any" Obstruction" Between the Door Seal and the Dishwasher.
2: the Seal is Warped from General useage or, twisted.
hope that helps
Please Rate Me
George
Apr 30, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
LG DISHWASHER LD-12AW2
ae unknown code,,,but ie that means uinit is taking to long to fill,,your inlet screens are clogged or the water pressure is to low...kinked hose...onthejob
Jan 19, 2009 | LG LDF6810ST Stainless Steel Built-in...
LG LD12AW2 Dishwasher overflowing
On the LG LD-12AW2 model, there is a float assembly just behind the wall where the water inlet port is located inside the unit.
When that float (or the micro-switch inside it) fails, water will continue to flow in without stopping . That causes the overflowing.
Post back here if you are looking for more specific guidance.
Good Luck!
Dec 11, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
Too much water where is fill switch
the fill switch is actually a pressure swith located at the bottom front of the d/w.
take care.
Jul 20, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
LG LD-12AW2
this unit has an anti flood device. if it leaks it lifts a piece of plastic in the base and hits the microswitch. try leaning the unit to one side and i would put towels down. if water comes out then try a program. hope this helps.
Feb 12, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
LG Dishwasher LD12AW2
You've done every thing the way I would of done it but check the float switch it is located in the front of the tub near the door if this is open it wont allow power to go to the solenoid see if your getting power across this switch and let me know what you find out god luck
Jan 21, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
Water leaking out of bottom of door
There is a rubber seal that runs along the bottom of the door. If you carefully run your hand along there just to see if it is all even. Sometimes they get out of place and you can push it back and then closing the door it realigns itself and all is good. If the seal is damaged, you have to replace the door liner as the seal is attached.
Sgt 48
Oct 24, 2007 | LG 24 in. LD-12BS6 Stainless Steel...
HE error code on an LD-12AW2 dishwasher
also check the back of the pcb and see if the plastic case is melting.
Sep 21, 2007 | LG 24 in. LD-12BW5 Free-standing...
LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher Logo
658 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
