Question about Jensen TS2050J 20" TV
My volume wont turn on on my samsung tv - Jensen TS2050J 20" TV
My samsung tv model#LN52B530P7FXZA volume doesn't work, remote wont turn tv on
If you can manually turn on the TV and manually adjust the sound, then the remote is your problem. Get a new remote.
Jan 12, 2018 | Samsung Televison & Video
How do i set up a new remote control for a samsung ht ws1 sound bar
2-Function Remote Stopped Controlling my Sound Bar - Verizon Forums
https://forums.verizon.com/t5/Fios...Remote...Sound-Bar/td.../559715
Apr 6, 2013 - It won't even control volume through the TV (Samsung). ... Did theremote ever turn on the sound bar, or have you been controlling ... Does the sound bar or TV have sound (sound but not volume control)? ... NO, UNFORTUNATELY THE FIOS REMOTE NEVER POWERED ON/OFF THE SOUNDBAR - I HAD ...
Your remote reprogramming woes solved - Rogers RedBoard
redboard.rogers.com/.../your-remote-reprogram...
Rogers CommunicationsJun 18, 2014 - Once the TV turns off, press the SETUP button once to lock the code.... the Rogers remote to turn TV on/off but can't get the remote to control volume. ...New Samsung smart TV and I have entered all the proper codes but the ..... Doesanyone have a code for volume control of Samsung Soundbar HW-J250.
Wireless Genie remote Doesn't turn on/off the soundbar - AT&T ..
Jan 08, 2016 | Samsung HT-WS1 Speaker System
40 samsung lcd tv problems
remove batteries from remote control and adjust volume to desired level. If the volume stays the same then there is a problem with the remote. If the volume lowers again then the problem is with the TV. the volume button on the TV or on the remote may be malfunctioning. Hopefully it will be on the remote. If it is the remote, take it apart and clean it with damp cloth. after allowing it to dry, re-assemble and try it out.
Sep 12, 2013 | Televison & Video
Volume working
Code for NEO 1451 TV?(universal remote control)
Aug 14, 2013 | Samsung TV Remote Control
Can not turn off and volume turns down by it self changed batteries in remote
Need more info to assist you with the issue. Does the tv work except the volume turns down by itself even with the batteries removed from the remote? If so its either the Tact switch for the vol down has an issue or the main board has an issue. If the remote wont work the tv properly either or not at all too then i would say the main board is causing both conditions. If you require further assistance please let me know.
Jan 01, 2013 | Samsung 50 in. Plasma TV
My samsung le32r74bdx remote control wont change channels and cant turn volume on tv up or down
You can verify that the remote is working. Get a digital camera with a LCD display.
Aim the remote at the camera lens and press the volume and channel buttons. If you do not see
a flash through the camera the remote is bad or the batteries are dead.
If you know someone with any samsung hdtv remote, you can borrow it and try the volume/channel
to see if the tv remote receiver is good.
Feb 08, 2011 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
I have a Samsung HCL552W projection that wont turn on.
I have the same tv.. Does the power light even try to come on? or do you hear clicking sounds? let me know maybe i can help u out
Apr 26, 2009 | Samsung HCL552W 55" Rear Projection...
Problem getting panel lock unlocked on combi tv
need to turn volume up but panel lock wont let me and i have have no manual
Jan 02, 2009 | Samsung CXJ1352 13 in. TV/VCR Combo
Samsung LCD Flat Screen TV LN-S2651D - Volume Problem
I lived with it for about six weeks, then took the back off the TV. Just now it seems to be fixed, but I don't know if it will last.
I disconnected the wire leading to the channel up/down, volume up/down and source board, turned on the tv, turned it back off, reconnected the cable, and everything seems fine now.
Aug 24, 2008 | Samsung LN-S2651D 26 in. LCD Television
Jensen TS2050J 20" TV Logo
27 people viewed this question
Top Jensen Televison & Video Experts
Jaime Hernandez
Are you a Jensen Televison and Video Expert? Answer questions, earn points and help others
