Question about Tomtom ONE GPS Receiver
Pc says no device connected - Tomtom ONE GPS Receiver
  • 2 more comments
  • Anonymous Nov 03, 2007
    my tomtom keeps on showing the red cross on screen
  • Anonymous Dec 10, 2007
    samsung yh-920 .der hd player braucht ne neue fimware.
  • Anonymous Dec 27, 2007
    Same here, have tried all 5 USB ports but nothing !
  • Anonymous Apr 23, 2008
    PC does not detect device at all.
    Problem Solver:
  • 7 Answers
That happened to me and I had to try a different usb port. Make sure your TT is off before you connect it and then after it is connected, turn it on.
Hope that helps!
Posted on Dec 17, 2007
How to connect bluetooth device on LIFEBOOK AH530
You are going to have to pair your device with your computer. Open the PC Bluetooth manager. Select seek all devices when connected. Make sure to check that option. Turn on your device making sure that it is also set to seek a connection once PC has found the device. The software will open a window that will give you paring code make sure that you type the code into the box it has to be perfectly done. Then the devices can be paired up. To see if you located your Bluetooth device go to devices you should see your device there. If not click on add new device make sure your device is turned on again able to seek. It will connect to the PC.
John
Apr 20, 2012 | Fujitsu LIFEBOOK AH530 NOTEBOOK (FPCR33681
How to use my samsung wave as a modem
Two methods are there to use your phone as modem
1)you can use your PC suit to use your phone as modem You need PC suit software provide by SAMSUNG
To use your phone as modem *install the pc suit software *Open PC suit and select "Connect too internet" *if its failed you can use manual setting by selecting "Connect to internet">Select access point>select the name of network operator from the access point list(if you did't get your network operators name in the list you need to contact your network operators customer care they provide the access point name you need enter this access point in the manual updation list and try to connect now.....
2)you can use Bluetooth technology to connect to internet For this you need *Bluetooth on your PC and phone
To connect(in windows OS) *Click on Bluetooth symbol on task bar *Select add device select from device which can be connected to your pc list(set your bluetooth device to visible mode) *Add your device to your pc Add completion of the above...
*Again click on bluetooth symbol on task bar *Select "show all devices" *now select your device(one click) at this time 4 options appears on top your devices list *select connect using>access point
and 2nd method is *Again click on bluetooth symbol on task bar *Select "show all devices" *double click on your device *select connect to internet from the dialog box which appears after selecting the your device
Thank you
Jan 29, 2011 | Samsung Cell Phones
How to download pc suite of htc viva
This mobile runs on Windows, the following software is provided for synchronization with a PC (i e PC suite):
Depending on the Operating System of your PC, you will need either Microsoft ActiveSync 4.5 or Windows Mobile® Device Center to synchronize your device with your PC.
To synchronize your device with a Windows XP PC
  1. Download and Install ActiveSync 4.5 on your PC from here.
  2. Connect your device to your PC using the supplied USB cable. The Synchronization Setup Wizard automatically starts and guides you to create a synchronization partnership. Click Next.
  3. Clear the Synchronize directly with a server running Microsoft Exchange check box and click Next.
  4. Select the information types you want to synchronize and then click Next.
  5. Select whether or not to allow wireless data connections on your device while it is connected to the PC. Click Next.
  6. Click Finish.
To synchronize your device with a Windows Vista PC
  1. Download and Install Mobile Device Center on your PC from here.
  2. Connect your device to your PC using the supplied USB cable. Windows Mobile Device Center will open. On the screen, click Set up your device.
  3. Select the information you want to synchronize and click Next.
  4. Enter the name for your device and then click Set Up.
Dec 20, 2009 | HTC Touch Viva Cell Phone
How can i connect HTC P3300 to pc with bluetooth
It's as simple as that.
1. Enable bluetooth on your HTC phone.
2. Tap 'Start' > 'Internet sharing'.
3. From the 'PC connection' drop-down list, seletec 'Bluetooth PAN.'
4. Tap 'Connect'.
5. Enable bluetooth on your computer/laptop.
6. Go to 'Conenction Manager'.
7. Select 'Conenct via bluetooth'.
Both devices will be in sync now enabling you transfer data.
Oct 18, 2009 | HTC P3300 Smartphone
How do you connect a bluetooth device to your computer
If your PC doesnt have a bluetooth capability, you need to have a bluetooth dongle, this device is a USB plug and play,, in order for you to connect any bluetooth device to your PC.
Sep 18, 2009 | Gateway M305CRV Notebook
How to send photo from mobile to our computer
there are 3 ways
1.
You can use the USB data cable to transfer data between
the device and a compatible PC or a printer supporting
PictBridge. You can also use the USB data cable with
Nokia PC Suite.
To activate the device for data transfer or image
printing, connect the data cable. Confirm "USB data
cable connected. Select mode.
" and select from the
following options:
Nokia mode — to use the device for PC Suite
Printing & media — to use the device with a
PictBridge compatible printer or with your
compatible PC
Data storage — to connect to a PC that does not
have Nokia software and use the device as a data
storage device
To change the USB mode, select Menu > Settings >
Connectivity > USB data cable and the desired USB
mode.
2.
Set up a Bluetooth connection
Select Menu > Settings > Connectivity >
Bluetooth and from the following options:
Bluetooth — Select On to activate the Bluetooth
function. indicates that Bluetooth is activated.
My phone's visibility — to define how your device
is shown to other Bluetooth devices
Search for audio enhancements — to search for
compatible Bluetooth audio devices. Select the
device that you want to connect to the phone.
Active devices — to check which Bluetooth
connection is currently active
Paired devices — to search for any Bluetooth device
in range. Select New to list any Bluetooth device in
range. Select a device and Pair. Enter an agreed
Bluetooth passcode of the device (up to 16
characters) to pair the device to your device. You
must only give this passcode when you connect to
the device for the first time. Your device connects to
the other device, and you can start data transfer.
My phone's name — to set the device name for
Bluetooth connections
3. Take off you microSC memory card then read directly to your computer
cheers!
Jul 11, 2009 | Nokia 3110 Cellular Phone
Firmware
The firmware has corrupted.
Run the Philips Device Manager, installed from the driver CD.
Connect the PSS110 to the mains and PC, when the Philips Device Manager registers that the device is connected click on the Restore option, and follow the on-screen prompts.
This will format the device and replace the corrupted firmware.
NOTE: ANY TRACKS WILL BE DELETED
Apr 25, 2009 | Philips PSS110/17 MP3 Player
How to connect blue tooth from pc to samsung cameramobile?
hi there!
While the specific user interfaces implemented by manufacturers may differ from device to device, there are still some very basic steps to go through in connecting two devices for the first time. Users should always conduct the pairing process in a secure environment.
Charge the Devices
If the devices are new Bluetooth devices, often they must be charged before they can connect or turn on. This is particularly true of new Bluetooth headsets, which must be charged before use.
Power Up the Devices
Power up the devices you are trying to pair. With some devices, like Bluetooth wireless headsets, powering up the device also initiates the pairing process.
Turn the Bluetooth Functionality On
The Bluetooth functionality in a device may or may not be turned on when you receive the device. For many computers, users will need to turn the Bluetooth radio on from the control panel or system preferences.
Make the Devices Visible
As a security measure, some devices allow the Bluetooth functionality to be off, hidden, or visible. When trying to connect devices, users should make the devices visible so the devices can discover one another. After the devices are paired, users can set the devices to hidden if they have concerns about their devices being discovered by others.
Place Both Devices in the Connection Mode
After both devices are charged, powered up, and the Bluetooth functionality is turned on, each device needs to initiate a communication session. Typically, in a connection between two devices, one device acts as the “host” and the other device acts as the ”guest.” The device in the host role is the one with the user interface from which most of the connection setup will take place. A device can be in the host role with one device and in the guest role with another device. For example, in a phone and wireless headset pairing, the phone is the host. However, in a phone and laptop pairing, the laptop is the host.
Enter the Passcode
After the two devices have discovered one another, the user will be asked to enter in a passcode in one if not both of the devices. In some cases, like with wireless headsets, the passcode is a fixed passcode assigned to the headset by the manufacturer. In those cases, the user enters the assigned passcode into the host device. The user will find this passcode in the user manual. In other cases, the user will be able to enter in his/her own passcode. In these cases, the user will enter the passcode once into each device. It is highly recommended that users employ an eight character alphanumeric passcode for the one-time pairing process. After the passcode is entered, the devices will validate one another and complete the establishment of a trusted connection.
Deleting or Disconnecting Trusted Devices
When should a user delete or disconnect a trusted device? If one of your Bluetooth enabled devices is lost or stolen, you should unpair that device with all the devices to which it was previously paired.
How do you unpair or delete a trusted device? For devices like a mobile phone or computer, the user should go into the device connectivity settings and find the list of trusted devices. The user should then have the option of adding a new device or deleting a trusted device. Highlight the device you want to delete and push the delete button. A device like a keyboard or mouse, which only has a button or switch as a user interface, can only connect to one device at a time. To delete its previous trusted device, the mouse or keyboard just needs to be connected to a new device
Or you can try this:
Bluetooth Mobile Phone to Bluetooth Personal Computer
  1. Power up both the mobile phone and the personal computer.
  2. On the PC, open up the control panel and find the Bluetooth Device Wizard. This will assist the user in setting up a Bluetooth connection between the PC and trusted devices.
  3. Ensure the Bluetooth connectivity is turned on in the PC.
  4. Find the connectivity settings of the phone. Make sure Bluetooth connectivity is on and visible.
  5. On the PC, choose to find and add a specific Bluetooth device.
  6. Of the devices found, pick the mobile phone with which to pair.
  7. PC will generate a PIN code.
  8. Mobile phone will ask if you wish to be connected to the PC.
  9. After the user answers in the affirmative, the user will be prompted for the PIN code on the mobile phone. Enter the PIN code into the mobile phone, which the PC generated.
  10. Allow devices to complete the establishment of a trusted link.
  11. If prompted on the PC to choose the Bluetooth services, the user may have several services available. The user may be able to sync the phone and PC. The user may be able to set up dial-up networking (DUN) preferences so that the user can use the mobile phone as a modem for the PC over the Bluetooth connection. The user may be able to transfer files, like pictures or business contacts, between the mobile phone and the laptop.
  12. After choosing which services the user wishes to enable, the user can then finish the connection and exit the setup on the PC.
better yet go to this website: http://www.bluetooth.com/Bluetooth/Products/Devices/Generic_Pairing_Instructions.htm
Feb 16, 2009 | Samsung SGH-E251 Mobile Phone - Black
Nokia pc suite
Uninstall every BT software you have and any Nokia PC Suite software you have. Plug in your BT phone dongle and let windows auto recognize the device. after it is done installing, then put in the Nokia cd. Do it in this order.
Nov 11, 2008 | Nokia E71 Smartphone
Tomtom ONE GPS Receiver Logo
1,215 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
