Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
Tv has green outline
My HDTV has a green outline and I do not know what to do to fix it!  PLEASE HELP
  • 1,139 Answers
Hello fameus2,
Try to adjust your convergence from you menu items. If this does not work, the problem may be your convergence Correction ICs but make sure you try to adjust your convergence first. There is a lot of information on the net about how to change the two convergence ICs (so I will not reinvent the wheel here). I would however suggest that you get a qualified TV repair person to do this for you since some folks have run into other issues in trying to do it themselves.
I hope this helps,
Thank you,
Posted on Oct 28, 2007
I have a PHILLIPS scrren HDTV MODEL #51PP9100D/37 and it hs green and red outline on picture. Can you tell me what could be wrong? Can this be fixed? Didn't know if it is something I can do myself or...
Its a convergence problem. The three color guns have drifted and it shows on the edges. Typical of an old projector tv
These will help how-to instructions:
Mar 08, 2014 | Philips 60PP9202 60" Rear Projection...
Our tv is showing green and purple outlines on screen and showing double words. do you know what the problem is? thank you!
Bad convergence ICs STK392-110s use 180s , you also need to CK pico fuses in front and behind STK ICs they will look like resistors but are Green or Yellow 5amps/6amps they are fuses.
Mats has STKs 1-800-628-1118
Mar 24, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Red & Green outlines but only on left/center portion of screen.
Its a convergence problem. You may want to check the site Every thing they said every description was right on. The best money I ever spent and the confidence you get from doing it yourself, Its a great feeling of achievement not to forget the live messenger support is instantaneous, friendly and informative if you need to fix your tv go to I fixed a philips 60 inch tv in 45 minutes, The convergecne chips were bad thanks a million. You guys saved me 250.00 bucks. I'll be recommending you to everyone I know!
Aug 18, 2009 | Sony KP-46WT500 46" Rear Projection...
Outline of images turn florecent lime/green!
I have seen this before. It is a tricky problem it's caused by two distinct problems causing one symptom. The first problem is with your backlight and the driver for it (this includes the ballast and inverter) and the actual LCD screen (the elements on the edge are not reacting fast enough to voltage changes.
A quick fix would be to replace inverter board that would stop the overdrive problem, now for the bad new the get rid of the green haze you may have to replace the screen, and that could get costly. I am only goin on what I have seen, in the past with this problem there may be other causes, however these will require the use of test equipment to do the job properly. I would me the suggestion that you have a qualified TV technician repair this TV for you.
I hope this helps,
Thank you,
Jun 17, 2009 | Vizio SV470XVT 47 in. LCD TV
Hello , I just purchased a 26" Toshiba LCD/HD flat screen TV today. The floor model had the nicest picture at Circut City of the other 26" TVs - but they were hooked up to receive HDTV. When I got it home,...
Yes, the newer flat panel TV's look great with HDTV but amplify the substandard analog TV signals.
I would compare the non HD to VCR quality. If that is what you are seeing then this is normal with non HD broadcasts (typically the channels 1-100).
Hope this helps, please rate my solution.
Jan 11, 2009 | LG 42LG50 42 in. LCD HDTV
Sony KDP57WS550 Projection tv red, green and blue virtical outlines on left and right sides
This is a convergence problem. You will need the stk's changed and a pico fuse or 2. also from looking at the pic you might want to clean the lenses and mirror after the repair to bring back some of the vibrant colors the set once had when it was new. This repair should run you anywhere from $300-$500 depending on your area and the tech that comes out. If you need more information or would like to try to fix it on your own please let me know.
Sep 10, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Red outlines in the picture
somewhere in the tv menu there is a place to make video adjustments. one should be for aligning the color guns. one is for red and the other two are green and blue. it will give you a cross in the center of the screen. it should also give you prompts to adjust the lines for centering and to save changes. this happens eventually on all rear projection tv sets.
May 02, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Green Screen
If set displays intermittent green outlines around images, check DVI cable attached to DMD board from digital board. Poor connections on the DVI jack on the DMD board can cause the intermittent symptom. Pull up slightly on the body of the DVI cable connector and check video. Replace DMD board as necessary.
Jan 20, 2008 | Samsung HLR5667W 56" Rear Projection HDTV
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
98 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
