How to change battery
Either the remote control is regular size or miniature like the remotes for cars. The only real difference is the type and size batteries it uses. The regular size remotes usually use 1 or 2 "AA" or "AAA" batteries, or occasionally, a 9 volt battery. The miniature remotes take "button" batteries that are available at Radio Shack or the big-chain drug stores like CVS. Whether the batteries are the regular type or miniature here's what you do: On the back side of the remote there will most likely be a small phillips-style screw in the middle. Remove this screw and then you will be able to open the battery compartment door. Write down or take pictures (better) of how the batteries are configured and note this as you remove the old batteries. Radio Shack has a battery tester. If ALL the batteries are still good, then the remote is defective. If ALL the batteries are dead or very weak, then most-likely the remote is working fine & will come right back to life. Enjoy!
