Question about Dryers
Changing the Drive belt
I want to replace the broken drive belt but am not sure how to access the drive wheel
  • 4 more comments
  • alastai8 Oct 28, 2007
    The product is a Hotpoint Aquarius Tumble Dryer TL21A
  • submitting Nov 09, 2007
    hi, I the belt seems tobe to small to go around both the drum and the moter,how do i get it to fit. thanks for any help you can give.
  • Anonymous Nov 28, 2007
    I have the same problem on a hotpoint WF440, The belt seems to small.
    It has the same numbers as the old one?
  • Anonymous Jun 16, 2008
    tumbler doesn`t turn blowing heat
  • cmore963 Jul 20, 2008
    How do you change the Tumbler drive belt on Maytag LDG7304AAE gas dryer
  • Anonymous Mar 22, 2014
    The rear wheel drive will not propel the lawn mower. Do you replace a belt or what>>>
How do I replace the drive belt on a zanussi TD265? any help
Posted on Apr 09, 2008
Depress drive pedal forward or reverse, tractor will not move
Assume it's a hydrostatic transmission - most probably the drive belt has come off or broken. Be sure to replace it with a Kevlar belt as changing the belt isn't easy and you don't want to have to repeat the process too soon.
Apr 19, 2014 | Cub Cadet Garden
Hard to turn steering wheel
Check your drive belts. Possible loose or broken off.
Dec 23, 2013 | 2002 Nissan Altima
I need to replace the drive belt
There are several steps to follow in changing/replacing the drive belt. You need to loosen/remove the drive wheel so you can replace the belt on the saw. Then you need to check and make adjustments on the tension on the belt. But it would be best if you can check the operator's manual for the saw.
Nov 07, 2012 | Craftsman 12 Tilt Head Band Saw Owner...
I have a Honda HRR2165VXA mower that is having issues with the smart drive.
hello, hello, Drive belt replacement for front drive mowers. remove the belt coved on top of deckand clean out grass,turn mower on side where carb is facing up,use a pair of vice grips on side of mower deck so the blade can stop,remove the blade,remove the belt cover and clean out the grass,remove belt from rear and front pulley pulleys. install new belt,put belt cover and blade back on,put front belt cover on, should work,if that is not the problem; wheels will not prepeal the mower,wheels turn only when raised off ground, Check the gears or groves on the inside of the wheel for access wear that is a common problem,check the axle drive gears to make sure turns ok, to check gear box if ok pull mower back wards while drive is engaged,if wheels turn backwards than the trams is bad,all of this is caused by the operator,by not disengaging drive while pulling mower backwards or by holding mower back not allowing to propel self completely,hope this helps,any comments welcome,thank you.
Feb 15, 2012 | Garden
Instructions to replace drive belt on toro model14ap80rp744 and daigramn
Hi. Here's the procedure on how to replace the belt. Sad to say i dont have a diagram for that. Please see below instructions.
The mower should be drained of gas and drain the motor oil before starting procedure.
Disconnect spark plug wire from spark plug.
Motor side of the belt:
Remove two bolts under the lawn mower body which holds the top cover over the drive belt.
Remove the belt guard that is around the pulley on the crank shaft.
Then work the belt around the blade and off the the drive pulley.
While blade is removed, sharpen or replace as necessary.
Transmission side of the belt:
Remove the "S" clip on handle for speed / traction cable
Remove the plastic "Rear Baffle" two screws on each side on frame in front of rear wheels one screw in the rear
With the baffle removed, rotate the drive shaft and transmission to gain access
to the pulley drive belt guard, it is held in place with three screws.
Once belt guard is removed, you can easily remove the drive belt
Reverse procedure to replace the belt.
Lubricate drive Axel bearings, wheel bearings, control cables, as necessary.
Replace all fluids as necessary.
Aug 19, 2010 | Toro Garden
Changing a belt on a washing machine
There is no belt on this machine.
It uses a direct drive coupling between the motor and transmission.
Ope the control console,then remove the cabinet clips to remove the cabinet for access to the motor.
Remove the motor then remove the broken drive coupling(3 parts).
Replace the part and re-assemble the washer.
Jul 25, 2010 | Roper RTW4100SQ Top Load Washer
Drive belt broken is it worth replacing it? Other parts OK
the cost of the replacement belt is cheaper than a new trimmer so has to be worth changing
Jul 06, 2010 | Black & Decker 14" Grass Hog Xp...
Engine runs at full throttle.
hi this sounds like the the drive part is faulty, if it is a belt it more than likely is slipping and will need changing, if it is chain driven, the bolt/nut that holds the cog to the drive part is either loose or broken tighten if needed but also make sure the washer ( anti vibration type ) is ok or renew it if it is coming loose, also use thread lock of some sort to stop it coming loose in future.. hope this is sorta helpful
Apr 14, 2010 | Toro Lawn Mower With Toro Power Tools
Why won't the Kenmore top loading washing machine agitate?
There are two types of Kenmore top loading washing machines. The direct drive models and the belt drive models. Direct drive models do not have a back access panel and the water inlet valve is located on the left side viewed from the rear while belt drive models do have back access panel and the water inlet valve is located on the right side viewed from the rear.
The most common problem causing a top loading machine not to agitate, particularly when the motor seems running, is a broken motor coupler for direct drive models and a broken or worn out drive belt for belt drive models.
The best way to exactly determine the cause is to access the drive motor. Open the back access panel for belt drive models and check the drive belt. Check the drive motor if it is running, humming or stuck.
Please indicate the model number of the washing machine if it is a direct drive model for the procedure in accessing drive motor.
Jan 15, 2010 | Washing Machines
Change drive belt on converter
dear atv owner there is no need to remove the pulleys to replace the drive belt. you must open the large pulley by hand and drop the new belt in bottom of this pulley this will hold it open then pull the belt across to engine pulley then turn the rear wheels in clockwise direction this should force the belt on the engine pulley job done jim
Mar 29, 2009 | 1998 kawasaki KLX 300
Dryers Logo
588 people viewed this question
Top Dryers Experts
