FixYa.com
Tags:
Hard Drives
Generic problem for all Hard Drives
Hard drive problem (by 2 users)
posted by compnovice on Oct 28, 2007
had to switch off computer manually as it would not respond. I tried con alt del but it didnt work.  when i switched it back on it went to blue screen and chckdsk it completed so far and stopped responding again. had to turn back off and skip chckdsk, looked for help and found you. can you help ?
Comment by compnovice, posted on Oct 28, 2007
thank you for ur help it worked i'm very grateful.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Feb 09, 2008
I connected simple drive but can not use it as it does not appear as external drive in MY computer
Can you help pls
Best Solution
FixYa! (100)
Lemmor
Rank:Wiz Wiz
Rating: 84%, 325 votes
I recently have that kind of problem just a few days ago... I suspected a new virus... I scanned the hard disk but didn't find any maybe its new... so I have made a back-up of the files in it (burn them on a CD/DVD) then re-installed the entire system... so far my computer works fine now. You could try the "system restore" to fix the problem but if it doesn't work. I think the only way is to re-install it, just don't forget to get all your important files.
Rating Locked! (?) compnovice has rated this solution as FixYa!
This Problem Also Relates To: Buffalo Technology 250GB MINISTATION TURBO USB 2.0 5400 RPM PORTABLE HDD 250 GB Hard Drive Buffalo Technology 320GB MINISTATION TURBO USB 2.0 5400 RPM PORTABLE HDD Hard Drive Fujitsu Siemens (MAJ3091MPB) 9.1 GB SCSI Ultra160 (16-bit) Hard Drive Fujitsu Siemens (MHV2060AH) 60 GB Hard Drive IOGear (GHD125C40) (DHGHD125C40) 40 GB Hard Drive IBM Axiom 80GB HDD ThinkPad 755, 750, 360, 355 (AXM0580) Hard Drive LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive
Can you Help with these Hard Drives problems?
LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Will not turn on
My power cord is plugged in,... Answer This...
Kingston (DTIU3/2GB) 2 GB USB Hard Drive
kingston micro sd with adapter
how do i put music into the... Answer This...
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB...
Seagate FreeAgent Pro -...
Seagate FreeAgent Pro -... Answer This...
Seagate FreeAgent Go 80 GB USB 2.0 Hard...
usb hard disk no detected
my usb hdd 80GB segate not... Answer This...
LaCie 80GB Mobile Disk USB 2.0 80 GB Hard...
Disconnecting The Mobile Hard...
I just installed a LaCie mobile... Answer This...
Repair Service
Find Hard Drive Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
