The rear doors are stuck shut, door handles do not work, inside or out. Trying to remove the door panels while the doors are shut has presented a problem. I found 2 screws in the panel, 1 in the door latch area and the other under the armrest. Have removed them but the panel still does not move. Any suggestions on where to lift, push, or pry the panels to remove them so I can look at the latch mechanism behind the panels to unlock/unlatch the 2 rear doors.
SOURCE: Trying to remove door panel. Seems stuck behind door handle.
Under armrest are two large philips screws. remove these and the panel will fall off.
Alternatively, one screw may be acccessed from the top down on the arm rest, remove small access circle, or tray insert.
SOURCE: How do I remove driverside inside door panel ?
door panel is holding by dozen plastic push pins.
strat from the button. use a screw driver or putty knife. pull the panel towards you. be careful not to damage the push pins. go around the panel toward the door hinger then the otheer direction toward the lock.once you have panel seperated from the door. push up the panel to clear the glass. (it is easier if the window is all the way down). pull back the plastic (don't destory it). you need to put that back later. now can get access to the galss and what ever else you are looking for.
SOURCE: Removing manual window handle at door panel
Uses a "c" clip to secure window handle. Requires a special clip removal tool, that can be purchased at the parts store. Hope this helps
