Right as the paper starts to roll out after it has finished printing, it stops, and the carriage gets caught on the left side. It clicks loudly.
SOURCE: Mechanism Error - Print Cradle won't move! - HP 5650
This "plastic strip" is called the "carriage encoder strip". This strip dictates the timing of the carriage assembly. If the end slots aren't broken, you can re-attach it. Otherwise, you'll need to replace it. They are about $10.
SOURCE: Carriage error Hp F2280
Same thing happened to me and I took it back to the store, where I bought it from. They replaced it with a new one and told me that it didn't have any software installed, like if you have a motherboard without bios ..
SOURCE: The print cartridge cradle cannot move.
"The print cartridge cradle cannot move."
I fixed this problem by disconnecting the power cord from the power-strip and connecting it directly into the wall. My printer was not getting enough voltage from the power-strip. I hope this helps.
Fiend your solution direct from hp. Here is your solution...
http://www.hp.com/printer/prob676ijt65/solution
749
SOURCE: I have a HP C3100 print cartridge cradle cannot move
I'm glad to see that I'm not the only one who has had this problem without a solution. I found that by moving the print cartridge (with the power on) all the way to the left, closing the door, powering it off, then powering it back on, then doing the test print (cancel and color start copy key), it would print. Had to do this 2-3 times. Then tried printing a document and it printed. So far, it 'appears' to be working OK. Hope it keeps working, otherwise I will just have to get another printer...
