Question about HP PhotoSmart 7660 InkJet Printer
Will not stay on
Power light begins green but immediately turns to flickering red light and therefore will not stay on.
  • lbroer Nov 06, 2007
    I have the same problem I have tried to do a hard boot that requires the ink cartridges to be removed but they will not come out without the green light. H-P told me to get a new printer.
  • 81 Answers
Hi, this printer needs a repair, which unfortunately will cost more than the printer is worth. I agree with HP
Posted on May 14, 2008
I am having problems with Lionel Fastrack layout. When I put electrics to the layout the green light comes on and I think all is ok. However as and when I start to increase the power the red light A.
remove all the cars and engine from tracks and try it, if green stays on add one car back to track at a time and try it , when light turns red , the last car added is the problem
Mar 20, 2016 | Crafts & Hobbies
Sylvania lc320sl1
in this television .if you see the digital television .its the inverter board. try a probe pull off the small cable of inverter board .and try to turn on the tv .if the light stay green the inverter is out. thanks
Dec 10, 2013 | Televison & Video
Suzuki Liana engine is a DOHC 1.3. The problem is THIS CAR BACK FIRE immediately after little drive AND CUT THE ENGINE WITHOUT INDICATING THAT THE ENGINE IS OVERHEATING. The check engine light begins to...
Hi there:
Don't confuse this steady pulsing of the Check Engine Light light (usually one or more flashes per second) with a flicker (see above). The Check Engine Light may stay on steadily or it may flash when the vehicle is accelerated. This is very serious. There is a severe failure of the emission control system that is causing the engine to misfire to the point that the catalytic converter is damaged each time the Check Engine Light flashes. It may mean that the catalytic converter is overheating to the point that it will glow red or, in extreme cases, start a fire on the underside of the vehicle. Immediately pull over to a safe place and have your vehicle towed to an automotive diagnostician for repair. Vehicles can be severely damaged and even destroyed by fire if this condition is ignored for too long.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jun 26, 2012 | 2005 Suzuki Liana 1.3
Hi there:
Jun 26, 2012 | 2006 Suzuki Liana 1.3
Magnavox mf310bf/7 tv when i try to turn it on the green light flickers but immediately turns back red. What could be the cause of it
It is indicating either a problem with the power supply in the set or something pulling voltages in the supply down.
Someone needs to open and check power supply in the set
Mar 16, 2012 | Televison & Video
Pc wont boot up, instead a red light flickers.
Flickering LED means power supply is overloaded with something. It might be inside of the supply, but sometimes it is something else. Try that:
1. Disconnect everything from the motherboard except power supply and power button;
2. Disconnect all power connectors from all drives;
2. Remove any cards from the motherboard so all you have is power supply and motherboard with CPU and RAM, nothing else. You can keep connected the monitor and keyboard;
3. Press Power button. Will motherboard turn on normally?
If no - check electrolytic capacitors especially around the CPU, if some of them are "popped" replace them.
If yes - connect drives and cards one per time to localize the problem.
Sep 14, 2009 | Compaq Evo D500 PC Desktop
LG rear projection tv. sound but no picture.
Go to a repair centre, some parts must be fixed/replaced.
Jul 22, 2009 | LG RU-52SZ30 52" Rear Projection...
HP PhotoSmart 7660 InkJet Printer Logo
57 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
