Question about Intel Motherboard
GA-G31MX-S2 Motherboard
Will never boot until I clear CMOS,    E6750 cpu, Crucial memory, 80 gig serial HD, onboard graphics and sound, tried safe mode and optimised defaults in BIOS, updated BIOS and Chipset, have all windows updates, memory is on compatible list.   Removed power cord and cleared CMOS using pins and also by removing battery.     -- CONFUSION--  Please Help
Most windows boot issues can be fixed by running chkdsk /f from a dos boot disk or from windows repair console (on OS Installation CD)
Posted on Jan 08, 2009
    Problem Solver:
  • 12 Answers
Try changing your CMOS Battery the CR2032...
Posted on Feb 05, 2008
I'm stuck in boot loop with a new configuration. Any Ideas other the reseting the CMOS to get out of the boot loop?
power supply? check and re-check connections (hard drive, cpu power cord, main connection to motherboard).
its your memory listed under the "memory support list" of your motherboard manufacturer?.
if not listed, contact the manufacturer (motherboard and memory) to make sure that they work together.
if none of these works, you have a bad motherboard. Good Luck
Jul 29, 2014 | Gigabyte GA-B85M-HD3 - Intel B85 Chipset...
I actually have the 512mb graphics card but my question is how do i install graphics drivers when the installation disc wont even do a complete install?
unplug power cod, open computer Cabinet panel, remove cmos for 2 min and reinsert cmos,
wipe graphics card socket, reinsert graphics card, TURN on computer, press f2 to load default setting
you do not need to disable onboard graphics. in bios, some bios default configure your graphics card to primary
hope will help you
Apr 29, 2014 | ASUS Video Card ATI RADEON HD 5450, (1 GB)...
Blue screen Dell Dimension 0x0000007B
plug the HD in other PC and execute Scandisk Complete
Jul 18, 2012 | Dell Dimension E520 PC Desktop
Ga-g41mt-s2p onboard video not working
Remove ram memory one at a time to rule out issues, if video graphics card can be disconnected do it to see if any change in beep codes, do the same with the remainder of the hardware such as the hard drive and additional parts. My sense is the motherboard is bad, but you need to be sure as much as possible.
Mar 03, 2012 | Gigabyte GA-M61PME-S2 Motherboard, AM2,...
HI I have a Gigabyte motherboard 945GCMX-S2, I have a 1GB ddr2 (667 Hz) hynix ram already installed ..to upgrade it i installed another 1GB dynet ram (666 Hz)..but my cpu beeps now...i remember runni
You should be able to as it can take 4 gig total according to the manual.
Memory:
2 DDRII DIMM memory slots (supports up to 4 GB memory) (Note 2)
Supports dual channel DDRII 667/533 unbuffered DIMMs (Note 3)
Supports 1.8V DDRII DIMMs
Note 2. Only for GA-945GCMX-S2.
Note 3. Only for GA-945GCM-S2.
Feb 06, 2012 | Gigabyte Computers & Internet
I have a gigabyte ga-h55m-s2. the problem is the onboard lan is in deep sleep mode.. how can i wake up the onboard lan?
Have you tried loading the defaults of your BIOS? or resetting CMOS through the jumper?
Hop it works for you.
Jul 29, 2011 | Intel Motherboard
GIGABYTE GA-M61SME-S2 AM2 NVIDIA GeForce 6100 Micro ATX AMD Motherboard Will not post, tried clearing CMOS, moved memory chips around. Still does not post.
Is this a new board? Check the processor to make sure that it is seated properly. You will have to remove the fan and heatsink, but if you put the processor in yourself, it is possible that it didn't seat properly.
Mar 19, 2010 | Gigabyte GA-M61VME-S2 Motherboard
Graphic card for GA-8IPE1000 series
HI there.
There are loads of makers of memory and graphics cards out there to choose from.
For the ram i would recommend Corsair or Kingston, you can get this ram as a matching pair so the both run at the same speed, the best ram to get is DDR 400.
As for the graphics card, i recommend ATI radeon X1650 Pro 512MB graphics card.
These upgrades will make your machine purr like a kitten with an excellent gaming experience.
Good luck and thanks for choosing FixYa!!
May 27, 2009 | Gigabyte GA-8IPE1000-G (MBGA81PE1000G)...
Computer sounds like its on but no display
Remove all plug-in cards including the memory and clean the contact points with a pencil eraser... Insert them back and try... You should hear 2 short beeps, which means Okey... Long beep means that there is a problem with the memory or one of the memory... Keep me posted if not solved...
Happy Fixya...
May 21, 2009 | AOpen AX4B-533 Tube (91.8A210.102)...
Chassis intruded!!
Clear RTC RAM (CLRTC)
This jumper allows you to clear the Real Time Clock (RTC) RAM in CMOS. You can clear the CMOS memory of date, time, and system setup parameters by erasing the CMOS RTC RAM data. The onboard button cell battery powers the RAM data in CMOS, which include system setup information such as system passwords.
1. Turn OFF the computer and unplug the power cord.
2. Move the jumper cap from pins 1-2 (default) to pins 2-3. Keep the cap on pins 2-3 for about 5-10 seconds, then move the cap back to pins 1-2.
3. Plug the power cord and turn ON the computer.
4. Hold down the <Del> key during the boot process and enter BIOS setup to reenter data.
Except when clearing the RTC RAM, never remove the cap on CLRTC jumper default position. Removing the cap will cause system boot failure!If the steps above do not help, remove the onboard battery and move the jumper again to clear the CMOS RTC RAM data. After clearing the CMDS, reinstall the battery.
You do not need to clear the RTC when the system hangs due to overclocking. For system failure due to overclocking, use the CPU Parameter Recall (C.P.R) feature. Shut down and reboot the system so the BIOS can automatically reset parameter settings to default values
Mar 18, 2009 | ASUS P5V800-MX Motherboard
Intel Motherboard Logo
119 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
