Question about HP OfficeJet G55 All-In-One InkJet Printer
Ink lickage the ink lickage and spread inside the printer
    Scholar:
  • 127 Answers
You need to open the printer and clean the filter inside..this is usually cause when the ink filter is full.
btw, the filter is located in the lower right side of the printer...below were the cartridge stops when your not printing or turn the printer off.
Posted on Oct 28, 2007
Ink leaks and pools in right back paper tray and leaks onto desk
it sounds like your collection assembly is full. this is not something you can do anything about. it must be replaced and it will be costly. you are probly better off to replace it
May 18, 2017 | HEWLETT-PACKARD Office Equipment &...
I want to know what is inside the printer cartridge
The ink cartridge are of different type and contains ink in different form.
  • Thermal Ink jet Cartridge (HP, Canon) - The cartridge contains a liquid ink, which is heated by a heating plate on the cartridge. A bubble is formed which forces the ink which comes out of the nozzle.
  • Piezoelectric Cartridge (Epson) - The cartridge contains piezoelectric crystal, which when current is applied changes shape and size forcing ink out from the nozzle.
  • Toner (Laser Jet Printer) - A drum contains powdered ink (toner), which is spreads on the paper using negative and positive charges and the heater sticks the ink on the paper.
Regards,
Shrey
Jun 07, 2011 | Computers & Internet
My Dell 926 AIO Printer will not print after installing new ink cartridge. Ink level on computer still says empty.
you must cleaned cartridge before you plug on printer, for level ink detection you must waiting for moment for ink spread on cartridge.
Mar 09, 2011 | Dell 926 All-In-One InkJet Printer
My printer does not print blink blink blink
maybe your printer need to be overhaul clean as it may have ink spread inside around, have it clean if still persist it need to be reset.
Feb 12, 2011 | Epson Stylus C86 InkJet Printer
I have a Xerox CX-700. It gives an error code 12-374. What is the meaning of it? Please help
check it there's some obstacles in mechanical parts or the printer is dirty with ink spread inside mechanism. it needs to be clean
Feb 02, 2011 | Office Equipment & Supplies
Paper keeps getting jammed
There is a rod in the carriage of your printer that is meant for holding the cartridges. It keeps on moving and spreading the ink on the paper throughout the process of printing. If this rod is jammed because of any reason, you face a carriage jam. As mentioned above, the main function of the carriage rod is to spread the ink, so obviously any clog or ink failure will lead to a poor print quality. If rollers of your printer are leaving marks on the document, then you need to clean them with a wet cleaning pad. Never use the chemical cleaners such as benzine, thinner, or alcohol to clean the rollers. In extreme cases you might need to replace an old cartridge of your Lexmark Printer with a newer one. Once you get a new cartridge for your printer, you need to be very careful while replacing it, otherwise it might cause a carriage jam.
Nov 23, 2010 | Lexmark Office Equipment & Supplies
Parts inside your printer are near the end of their service life.
Most likely the waste ink counter has reached its programmed limit. You can replace or clean the waste ink pads. You need to disassemble the printer from the top; the waste ink pads absorb the ink during cleaning cycles and when you do edge-to-edge printing. Have plenty of newspaper or other material to keep the excess ink from spreading. Remove the pads, blot off most of the ink and then hold them under running water until it stays clear. Blot the excess ink from the area where the pads rest as well. Dry the pads (you can use a hair dryer to speed up the process). Then reassemble the printer. If you want to replace the pads, contact Epson Service.
Fill out the form here: http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp?cookies=no&com.broadvision.session.new=Yes and get the Ink Pad Reset utility. You will need to provide your printer's serial number. Run the reset program (Windows computer).
Please note that the programmed timing on the waste ink is based on the expected life of the printer. You may have additional failures with the printer in the near future.
I hope this helps.
Sep 29, 2010 | Epson Stylus Photo RX600 All-In-One InkJet...
How to free carriage jam on lexmark X4550
There is a rod in the carriage of your printer that is meant for holding the cartridges. It keeps on moving and spreading the ink on the paper throughout the process of printing. If this rod is jammed because of any reason, you face a carriage jam. As mentioned above, the main function of the carriage rod is to spread the ink, so obviously any clog or ink failure will lead to a poor print quality. If rollers of your printer are leaving marks on the document, then you need to clean them with a wet cleaning pad. Never use the chemical cleaners such as benzine, thinner, or alcohol to clean the rollers. In extreme cases you might need to replace an old cartridge of your Lexmark Printer with a newer one. Once you get a new cartridge for your printer, you need to be very careful while replacing it, otherwise it might cause a carriage jam.fix Lexmark Carriage Jam .
Sep 18, 2010 | Lexmark Office Equipment & Supplies
In my printer ink is spreading
refill it
check here how with no need of special tools
utube.png You-Tube video "iMiTopIVMxM" placeholder (do not delete) utube.png
May 20, 2010 | HP LaserJet 1020 Printer
Why does my printer use all my colored ink before it uses my black and I have it set to only use black.
even tho you have it set for black only, it will still use colored ink to clean the nozzles inside the printer to prevent dried up ink in the head. this will prevent the printer from messing up.
Jun 26, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
HP OfficeJet G55 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
