Question about Foxconn 6100M2MA-RS2H Motherboard
6100m2ma-2.0 does this board take vista ulimate...and if so then why does it take 2-3 boots to fire up from dead cold but will start normal when hot.what power suppy size does it require (uk) system vista 250 sata h/drive 2 gig memory ddr 2 x 667 i cd read writer,1 dvd read writer 350 power supply
  • wuppie Feb 07, 2008
    I have the same problem, but "Smart Fan Control" does not solve the problem.
    Any idea what the solution can be?
Need driver
Posted on Feb 12, 2008
I am using vista ultimate and it seems to run fine.
Posted on Feb 11, 2008
Mine is version 1 of the MB, and I don't know about vista, but it skipped on simple audio tasks, till I figured the "Smart Fan Control" was causing it. Setting it to "Disabled" in the BIOS fixed this. This lets the CPU fan run full speed at all times. Try it, it seems to be temperature related, and should either make things better or worse...
You might also see if the BIOS updates available at http://www.foxconnchannel.com/support/downloads.aspx help you at all.
Posted on Oct 28, 2007
Just bought a nviada geforce 550 gtx for my foxcon 6100M2MA-RSH2 mother broad when i boot my computer from the card it hangs at the bios splash screen i have a 500w psu and all the conneters,can any one...
I couldn't find the 6100M2MA-RSH2, I only found a 6100M2MA-RS2H, if that is the right one, you can download the manual for it here, that may help you with this procedure. (It should tell you which key gets into BIOS setup, and where to find the option to shut off your internal graphics card)
You may have to enter your BIOS setup and disable your on-board video (there is an article that gives you a general idea of how here). You'll need to take out your new graphics card and use the built-in one to disable it. Usually, the key to get into BIOS setup is F2, F10, sometimes F12 or Delete key, or maybe Esc while the computer is booting.
Look for an option for "On-board video" or something and disable it, save your changes and exit, shut off the machine, and put your new graphics card back in.
Apr 10, 2011 | Nvidia Computers & Internet
My Toshiba Satellite laptop does not fire up at all. Yesterday as I was working the screen blinked a few times and went dead. I can't get it to come back up. Tried connecting to an external monitor but it...
Four possibilities come to mind.
1. Your power supply is bad and the battery ran down.
2. Your system board died.
3. You have a bad device plugged into a USB port.
4. Your battery is bad and holding down the AC power.
To troubleshoot, disconnect all external devices, even remove the CD drive if possible. Try to boot.
Next, boot with just the battery.
Next, boot with just the AC supply.
That's about it. If you still have no power at boot, it is the system board.
Apr 27, 2010 | Computers & Internet
Specification of 4JG2 Engine-Isuzu
Four cylinder inline, water cooled, overhead valve diesel engine with dry liners available in Turbo(T) or normally aspirated(NA).
Bore 95.4mm
Stroke 107
Displacement 3.059 litre
Compression ratio 20:1
Idling speed NA 750, T 720 rpm
Firing order 1-3-4-2
Injection timing NA: 1 deg after top dead centre(ATDC), at top dead centre(TDC) for turbo
Valve clearance (cold): 0.4mm for intake and exhaust.
Oct 24, 2009 | 1994 Isuzu Trooper
HP DV5 laptop extremely hot in Vista not Windows 7
hps are born hot. an undercooler board would help.
Jul 23, 2009 | HP Pavilion dv5-1002us Laptop PC
No video
HI,
You can go into the BIOS , under onboard devices. Change the primary video controller to PCI.
refer to the following screen
http://supportapj.dell.com/support/edocs/systems/dim4700/sm/syssetup.htm#wp1052347
If the cards are not detected on the board. Then the problem could be of the PCIe slot .
Thanks
Proton
May 25, 2009 | Dell Dimension 4700 PC Desktop
BIOS dead ?
1 long and 2 short is video adapter / card failure. Replace the video card.
Apr 18, 2009 | Foxconn 6100M2MA-RS2H Motherboard
Foxconn 6100m2ma-rs2h drivers
You can go to Foxconn's website here and download what you need:
You'll need to pick fill in the information fields under "Search by Product Model" (type = motherboards, series = socket AM2, model = 6100M2MA-RS2H) and then search. You'll get 2 pages of available downloads.
Feb 12, 2009 | Foxconn 6100M2MA-RS2H Motherboard
Touch pad is on fire!
same laptop but intel core 2 duo, and I got the same problem , my touch pad is very hot sometime and I have the cooling fan underneath the laptop it's help! and after that like couple weeks later my laptop was death it wasn't boot the vista. it shown the options like 1. fix the ..... 2. start normally.
when I choose No.1, the screen turn BLANK all day and nothing changed and I power shut down and choose No.2, then it boot!! But the programs were not boot well and stuck like not completed. SO what's wrong with it???
Aug 04, 2008 | Toshiba Satellite A135-S2386 Notebook
Increase ram for vista ulimate
yes surly it will have some difference but make sure that your laptop has 2gb ram support sorry for the late reply
Jul 13, 2008 | Sony VAIO PCG-V505EC Notebook
Doesn't boot with 3Gb of ram....
Your board can only handle 2Gb of total memory.
2 x DDR2 SDRAM DIMMs, Dual Channel DDR2 533/667/800.
Check your manual.
Dec 29, 2007 | Foxconn 6100M2MA-RS2H Motherboard
Foxconn 6100M2MA-RS2H Motherboard Logo
134 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
