1998 Ford Mustang Logo
Posted on Jun 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My air conditioning blows hot air. Won't accept
My air conditioning blows hot air. Won't accept coolant. Is it a blown fuse? 1998 ford mustang. Looking for fuse diagram.
Anonymous
Level 3:
President:
  • Master 1,392 Answers
  • Posted on Jun 10, 2009
Anonymous
Master
Level 3:
President:
Answers
1392
Questions
0
Helped
657460
Points
4859
Is the system low on Freon? If not, you most likely have a bad A/C compressor, or a bad low pressure switch.
Ac not working
lots of possibilitys, 1. blown fuse
2. low on refrigerant, will not let the pully to engage
3 nothing bad about fords, but they use plastic for air dams, inside of the hot and cold deck
4. try to change from cold to hot if it does not change refer to 3.
hope this helps
99 ford mustang 6 cylinder. Recently i had to add antifreeze to my car couldn't find the radiator drain to take some of the water out so i loosened the lower coolant hose to drain some out after...
replace any soft hoses.
collapsed hoses cause water flow constriction
.that increases temp fast
to bleed air out of the system . if no air bleeder as such
with heater on full .-engine running
loosen the bypass pipe for the closed thermostat till only coolant flows no air bubbles
check if
the engine cooling fan spinning fast enough
the water pump in good condition
the interior directional flaps motors or actuators working
1helpful
MY AC ON 2003 FORD MUSTANG BLOWS HOT AIR AND DONOT HAVE OWNER MANUEL TO SEE IF FUSE BLOWN
The most common cause for an AC blowing hot air is the system is low on refrigerant. A small leak will eventually lose refrigerant until the compressor eventually will shut down. Most compressors require a minimum of 20psi to engage and chill the air. Most certified service stations can diagnose and recharge most systems for $100-150 depending on where the leak is. There are do it yourself kits available at most auto parts stores that come complete with leak detector (R-134A with dye to show where leaks are) compressor oil, and a recharge hose.
Overheating and no ac , replaced coolant fan didnt help
Headgasket may be blown. Try using the Goop found at local auto centre "Liquid Coolant Sealant"
Issue you are having is carbons leaking into the coolant tank is causing additional "BOIL" almost like blowing extremely hot air into water... Causing it to boil.
Your A/C is alone part of your Blower Fan, a completely different element to the cooling system, and you will need to recharge your AC
Try the goop. It really does work!!
1helpful
A diagram of a 2003 Ford Mustang interior fuse box?
Fuse Box Diagram
Circuit Schematic
I trust that these are what you are looking for, they are screen captures of the requested information right from Ford.
2answers
1998 Mustang 3.8L blowing #1 fuse in block..
What is on the #1 fuse circuit? What ever it is is bad, or shorted out in the wiring.
4helpful
2answers
97 Ford Econoline air conditioning and vent settings blowing hot
I know from experience that if the coolant is to low ( not just the freon levels in the compresor but the antifreeze/coolant level as well) the AC system will not cool and will blow hot. Check the coolant Antifreeze and freon levels, even with the Coolant being a little low my 1998 Ford E150 Van will blow hot. After you have ruled out of these possibilities and the chance it is the thermostat most likely the problem is what Ford calls the "Flap" it controls the air flow through the vent system when you switch from Heat to AC. When the Flap is working it closes off one systems air flow so as to not interfere with the current climate selection.
2answers
Compression for 1998 Mustang
depends on condition of engine.What you want to look for is a large difference between related cyls. If all are with in 10-15 percent of each other your problem may be some where else.
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
