Question about Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television
Sharp aquos fault
I bought a sharp aquos tv 11 months ago and it has now developed a fault.
When the set is turned on the picture will instantly disappear and continue in sound only. It wil take many re-starts for the set to provide a steady picture. When warm it will start immediately.I have discounted loose aerial fault as a different tv will work o.k
Please advise
william.t.williams
  • 5 more comments
  • racso Oct 31, 2007
    Many thanks Guest and tpranav. Have been advised by 'expert' to contact Sharp while set is still in warranty. However the reason for hesitation was that the set was bought in England and we are now living in France. Have now found out that this may not be a problem and Sharp in France have been E-mailed(no response yet).
    Will keep you informed
    racso
  • tidalwave24 Nov 25, 2007
    my LC-40c32u Sharp Aquos has the same problem after only 12 months. Is Sharp going to recall this set or offer a fix?
  • gooze Mar 03, 2008
    Nonsense. I have the same problem with my Sharp 32D40U. I removed the back and checked all the PCB board screws. Everything is tight. I also talked to a TV repairman who said that fixing such a problem by merely tightening some screws is ridiculous. Please folks, can we not post B.S. here??!!!
  • enriquelicea Apr 28, 2009
    SAME PROBLEM AS THE PREVIOUS COMMENTATOR MY TV WILL SUDDENTLY GO OFF IN PICTURE AND SOUND WILL ONLY COME OUT HAS ANY ONE FOUND A SOLUTION?
  • emmagreen May 04, 2009
    The set is just 2 years old and like the previous posts, the picture stays on for less than 30 seconds and the screen goes blank while the sound continues. The picture only stays on after numerous restarts. It some times cuts off at odd times in the middle of a program. This has been going on for about three months and now the color is way off, every thing looks brown and purple. There is no red or green and I cannot adjust it using the menu button.
  • Anonymous Mar 21, 2014
    picture distorts after tv warms up
  • Anonymous Mar 31, 2014
    I just bought a new sharp aquos led tv and when I plugged it in to start it up the picture is in reverse. How do I change it to normal
Thanks to this forum, I was able to confidently contact Sharp and get my TV fixed.
My 32" LCD had the same problem (sound but no picture) and was out of warranty, however I phoned Sharp UK and suggested that it was a manufacturing defect rather than component failure and should be repaired free of charge - which they did!!
Posted on Mar 19, 2008
    Problem Solver:
  • 11 Answers
Just want to say I tried the option of *no 3 solution (gues)t posted Oct 2007 and it worked.
my tv is going great guns now. Fantastic. Just want to say thanks.
Posted on Mar 07, 2010
I tightened the six screws on my LC-40C32U and it seems to have worked. It's been bugging me for weeks.
Posted on Feb 02, 2008
I also got the same problem and waiting on the technician come in this friday. But your insight into this problem helps us with tracking.
Posted on Dec 19, 2007
  • madan76 Jan 08, 2008
    It works..technician came and tightended the screws...that's all.
This fault has been fixed on my TV by the Sharp Engineer. Inside the cover on the right as you look at the back is the PCB that controls the back lights, the screws holdong this assembly can come lose. The engineer removed the PCB and the metal cover over it, cleaned the pads on the board and where the PCB touches the metal cover  and the TV chassis before putting it all back together making sure the screws were properly tight this time. He also at this time uppdated the firmware / software which apparently fixes a few other bugs like the pictuer going blank if you quickly cycle through the channels.
Posted on Oct 29, 2007
Picture and sound go out on my 60" sharp aquos tv
Check its sound settings first. If it is OK, check its speaker. If you wish to get more details about these type of faults, check this link. Pull up older posts there.
Mar 20, 2013 | Sharp Televison & Video
Sharp aquos fault
Take it back to where you bought it before the warrantee runs out.
Any solution here may invole opening the set.
Oct 28, 2007 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
We have a 52" Aquos
Go into the user menu and set the default to full. If this does not correct your issue, then take it to a service center. You are still covered under Warranty.
May 12, 2011 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
We have a Sharp Aquos LCD TV 42 inch. When I
Call Sharp for warrenty repair.This problem very common in Sharp tv.Picture will come on turn power on/off button few times will work.But still under Wareenty call to Sharp to replaced the main Tuner Signal board.
Jan 15, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp aquos 46d62u has sound, but no picture
We have the same problem with our 32" Aquos. Turn on the TV and after a couple seconds the picture goes out but still have audio. So this solution doesn't permanently fix the problem, but it works instantly to get the picture back. With the TV turned off, tap the side of the set twice with the palm of your hand. Turn the TV back on, and VOILA, you have a picture. I know the last thing you think to do is to hit your TV to fix it, but that is often how my husband tries to fix things...this time it worked!!
Apr 20, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp Aquos 46 In TV Problems:
Sharp list no issues or service tips for this model but I am sure most freeze ups are and issue of weak cable signals or defective cable receivers. If this has truly been elimnated the main digital pcb in the TV could be issue or more likely the TV may need the latest software upgrade. This is most likely only able to be facilitated by a Sharp auth. service center.
Dec 11, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
TV will lose picture then go into standby!
Yes it is a temp problem as you found out for your self Great call on that BUD.. the best thing to do is contact sharp to see if they have had simular problems and if there are any recalls on this model . If not they will instruct you where to send the monitor into to be fixed.
Mar 31, 2006 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television Logo
4,339 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
