Question about Novell IntraNetWare 4.11 for PC
Hard disk suopport
I want to Install Novell 4.11 on 80GB SATA Hard disk but failed to do so
  • Mohans Jul 13, 2008
    I'm trying to install netware 4.11 in AMD/Intel MB with SATA Drives.. Where can I find driver for SATA disks?. What kind of patches or updates I may require?. Kindly do help on this.
    Advance thanks...
    Mohan
Must use NON-NATIVE mode for SATA (compat mode) FROM BIOS select.
Posted on Sep 03, 2008
  • 1,006 Answers
If u try to install server console so follow the instruction:
Go to the server console; or Rconsole if you're remote; from the prompt type in load install. Then arrow down to license options; put the floppy in and hit enter. It will find it from there.
If you are remote, copy the server.mls file from the floppy up to the server's sys:system. Then after you've selected license options; hit f3 and type sys:system; enter. to verify the license were added go back to the console prompt and type in versions. Have a good one. :)
Posted on Oct 29, 2007
Can't install windows on FSB 800 motherboard its showing no hard disk installed in your computer but showing in the bios kindly help
If you are installing XP on a SATA hard drive then -
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Mar 18, 2013 | Computers & Internet
Asus laptop will not boot up after install of new hard drive
If your ASUS laptop uses a SATA hard drive -
SATA HARD DRIVE - XP INSTALLATION
Feb 27, 2013 | ASUS Computers & Internet
Compaq Mini 700EL hdd not recognised
If you are installing Windows XP then -
Oct 08, 2012 | Computers & Internet
How to install windows it's showing there is no hard disk in the system pls help me
If the BIOS does not detect the hard disk, then reseat the hard disk and then check the BIOS again.
The hard disk maybe faulty, if so you need a replacement.
If the BIOS detects the hard disk and you are installing Windows XP then -
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Jul 23, 2012 | Toshiba Computers & Internet
When i installing windows xp sp3 show no hard disk found
If your laptop is installed with a SATA hard disk then -
Mar 25, 2012 | Computers & Internet
Can not install os, computer says no hard disk installed
This laptop has a SATA hard drive.
Feb 23, 2012 | Panasonic Toughbook CF-30 Notebook
I have a k8upgrade vm800 motherboard. I want to install a sata hdd for storage only but the bios is not seeing the sata connection. Is there any soloution to make this possible or are the sata connections...
Is the drive initialised ... if not it will not exist on your system.
1.1 Serial ATA (SATA) Hard Disks Installation
This motherboard adopts VIA VT8237 southbridge chipset that
supports Serial ATA (SATA) hard disks. You may install SATA hard
disks on this motherboard for internal storage devices. This
section will guide you to install the SATA hard disks.
STEP 1: Install the SATA hard disks into the drive bays of your
STEP 2: Connect the SATA power cable to the SATA hard disk.
STEP 3: Connect one end of the SATA data cable to the
STEP 4: Connect the other end of the SATA data cable to the
chassis.
motherboard's SATA connector.
SATA hard disk.
Nov 25, 2017 | Asrock K8Upgrade-VM800 Motherboard
I cant install xp for the sata hard disks
The FIX.
Go into the BIOS and disable the SATA drive, this will make XP think it is a IDE/PATA hard disk. Then install XP normally, and all the device drivers (including the SATA driver).
Apr 02, 2010 | ASUS P4S800D-X Motherboard
Upgrade hard disk :SATA compatible with SATA2 ?
Dear,
Yes, You can install a SATA-II hard disk in it. There is no problem.
Regards,
Rakesh Kumar
Apr 06, 2009 | Hitachi HTS541612J9SA00 120 GB SATA Hard...
Installing Netware 4.11 in SATA PC
DOWNLOAD THIS BOOK FOR FREE AND SOLVE ANY PC HARDWARE, SOFTWARE OR OPERATING SYSTEM PROBLEMS.
DOWNLOAD NOW......
Download mirror 1 ( Hosted by HostingDude)
Download mirror 2 ( Hosted by Softpedia )
Download mirror 3 ( Hosted by Soft32 )
Download mirror 4 ( Hosted by fileflyer )
Download mirror 5 ( Hosted by Rapid Share
377
Jul 13, 2008 | Novell IntraNetWare 4.11 for PC
Novell IntraNetWare 4.11 for PC Logo
354 people viewed this question
Top Novell Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Novell Computer and Internet Expert? Answer questions, earn points and help others
