Question about LG 42LC2D 42 in. LCD HDTV
Color distortion After the TV has been on for an hour or so the colors become distorted. A lot of purple/red " shimmers" on the screen and looks like a mirage. Eventually it goes away and normal color returns but it is unpredictable. Adjusting color on menu has not resolved the issue. All cables are connected.
  • 1 more comment
  • Anonymous Nov 08, 2007
    yep I have the same problem however when you turn the tv off and back on again it is fine and then after different time perioods from 10 minuites to 40 minutes later the colour goes again and there seems to more pink in the screen and mirages of colour and it shimmers
  • Anonymous Feb 11, 2008
    I am also facing the same problem after I shifted my TV from one place to another by scrolling the tv stand. The screen is divided into three colors pink, blue and green.
  • kellcho Aug 02, 2008
    I have a Samsung 42" that is 2 yrs. old. About 6 months ago started exhibiting the on and off color distortions - looks like cartoons. Initially you could tap on the top of the set and it would return to normal but that no longer works. Now the set is always distorted. I am trying to get some idea of what is wrong and just how much it might cost.
4 Suggested Answers
  • 6 Answers
SOURCE: No Picture
There are 4 bad Capacitors in this TV. LG just doesn't wnat to tell anybody......
I purchased four 2200uf @ 25v capacitor’s for $8 at a repair shop. I upgraded to 25v because these will run cooler. The tv came with 10v Samxon caps that seem to be problematic in all the units they were used in. Do not buy Samxon if you do this yourself.... I opened the set by taking off the plastic back panel and then by removing the second metal panel. There are three boards and a hard drive. The board on the far left just above where the plug goes in is the power supply board. There are five data cables and one red power cable attached to it that can be removed simply by unplugging them. The board is fastened to the unit with five small screws, one on each corner and one in the middle of the right side. If you look for three green capacitors grouped together around the middle of the board and slightly off to the right, you will probably see one that is bulging out at the top. This is most likely "C235", the main problem. The other three caps that need replacing are C202, C201 and C219. C219 is closer to the top part of the board.....
The process to replace is simple, believe it or not, and it could save you hundreds of dollars. 1, Go to RadioShack and buy a cheap soldering iron and a small roll of solder. 2, Buy four, 2200uf @ 25v capacitors, online or at an electronics store. 3, Plug the soldering iron in and let it heat up. 4, Locate C235 on the back side of the board and mark the negative terminal with a felt tip marker (you want to make sure that you put the negative terminal on the capacitor through the right hole, otherwise you will pop the cap. The negative terminal is clearly marker on all the capacitors). 5, With needle nose pliers, grip the cap and pull down while heating up the terminals. The cap will eventually come out. 6, Put the new cap in (you may need to heat the solder that is left on the board to clear the hole so it can push through). 6, When both terminals are through, bend them slightly so it stays in place. Take the solder and stretch out a few inches off the roll and while holding it in one hand, lightly touch the base of the terminal where it comes through the board, with the soldering iron and the solder at the same time. --- Try not to use too much solder.. you only need a tiny drop. This will solder the cap in place. 7, cut off the terminals close to the board with some snips and repeat this on the other three. 8, put the board back in, plug in the cables. Test the TV before putting the back panels on. It should work fine if all went well..... If you hear a pop than you reversed the terminals on a capacitor and that one will need to be redone correctly.... This might sound lengthy and potentially difficult but its worth a try. Otherwise you can pay someone to replace the entire board for BIG BUCKS with the same junk caps on it and have the same problem in a year or so. LG doesn’t want to take responsibility for this and I'm sure that it has cost a lot of people a lot of money for about $8 in parts........... This worked for me and it can work for anybody with the same problem.. Good Luck!
Posted on Apr 28, 2009
SOURCE: my vizio sv470m screen keeps distorting the images
Could be power board, could be main board, could be LCD controller and lastly - very unlikely yet possible - could be cables or rather cable connections.
It would help a lot if you post a screenshot or, better yet, a video of the distortion.
I somehow do not relate "distortion" and "blacking out".
Yet if I had to make a pick based on what you say and my experience I'd look at the main board first.
You should be able to get a replacement for under $100 at eBay and if you know what a screwdriver is you should be able to replace it yourself - a slow, but certainly not difficult process even if you do it for the first time.
Still I don't recommend spedning money before sharing more details and getting a more informed guidance as to where to look.
Posted on Nov 02, 2009
Testimonial: "that sounds like an excellent solution. I'm going to give a call to vizio to ask for all the required parts and take your advise and do it myself. ty!"
  • 113 Answers
SOURCE: picture distorted goes red in color after 1 hour
Most likely the problem is bad capacitors on the video module of unit.If you take the back off you should see basically 3 circuit boards-Power Supply,Main Board,T-Con Board.Inspect the main board and the power Supply Boards for bad capacitors,in most cases the bad ones will usually have a bulge on the top of the capacitor,a normal cap will have a flat top,if you find any of the caps have a slight or big bulge,as if they were getting ready to explode,they need to be replaced with the same microfarads and voltage rating which is printed on the side of each cap.Replace them one at a time,you will need a soldering gun ,solder and solder wick to properly do the job.You can find all the tools you need at your local radio shack.The solder wick is used to extract the old solder so you can put a new cap in,the caps will have 2 legs.Also you must look at the cap and line up the negative side of the cap to the negative symbol on the board,there should also be a plus symbol where the cap goes in on the board.Good Luck and let me know if you need more information.
Posted on Mar 27, 2011
Lines going through it and is very distorted
Search Results
    Troubleshooting Distorted Pictures - Stereo & Video Repair ...
    www.stereoandvideorepairco.com/.../DistortedPictureTroubleshooting.ht...
    Usually, this occurs on CRT projection TV's, and occasionally on CRT ... Dark, light, or colored bars can be seen rising slowly through the picture, ... Known as "hum bars" or "common-mode noise," these result from AC power line hum coming ...
    Flat Screen TV Has Lines Going Through Screen - Possible ...
    removeandreplace.com/.../flat-screen-tv-has-lines-going-through-screen-...
    Jun 17, 2015 - Flat Screen TV Has Lines Going Through Screen - Possible Bad ...inch LCD TV which is showing lines (vertically) and getting extremely hot. ..... If you leave the projection TV on for a certain amount of time does it ..... If so the plasma gas is most likely causing the screen to become distorted or color issues.
    Distorted Colors in an LCD Projector ' Business ...
    yourbusiness.azcentral.com/distorted-colors-lcd-projector-8597.html
Feb 08, 2016 | Televison & Video
The pisture is distorted on top left part of the tv and the color is off lots of purple
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded over.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dul
Dec 03, 2010 | JVC AV-56WP74 56" Rear Projection...
My TV PT-56, I'm not sure if it is the colorwheel or the convergence. The color green overlaps with purple and someone mention color wheel what do you think?
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 17, 2010 | Panasonic PT-51HX41 51" Rear Projection...
Philips 60p8342 projection tv 1)Color distorted, whitish and dull 2)Picture bowed at top and bottom 3)Set turns off by itself 4)I can't turn on set unless its been off and unplugged for many hours and then...
These sets have several common problems listed below.
Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
  • Dull looking screen
  • White looking sceen
Jan 16, 2010 | Philips 60P8342 60" Rear Projection...
Wavy picture with blue and purple color.
Projection TV sets have two very common problems listed below.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 09, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Freezing, no audio/video/red circle
ONE THING YOUR CORDS ARE WACKED OUT AND THE COLOR DISTORTION SIMPLE NOT YOUR XBOX IT IS YOUR TV
Aug 17, 2009 | Microsoft Xbox 360 Console
The screen on my xbox 360 looks distorted with color.
mayb the cords r messed up cuz mine were lik that but then we got new cords it fixed it......or mayb its the tv try another tv first then if that dont work get a new cord
Apr 10, 2009 | Microsoft Xbox 360 Wireless Controller
Green and purple band of color
*Screen Looks 3-D
*Colors wont align
Jan 31, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Sony KP-53XBR35 TV Concave top & Bottom in wide screen, along with color distortion around sides
thats usually a convergence IC failure, Are you able to move the red and blue colors in the convergence adjustment menu?
Jul 14, 2008 | Televison & Video
LG 42LC2D 42 in. LCD HDTV Logo
452 people viewed this question
