Question about Microwave Ovens
Changing bulb How do I change the bulb please? can't find out in manual how to do it.
  • KK08 Dec 03, 2007
    I have the same problem. Need to change the light bulb in my Neff Convection / Microwave H7871N2GB and it's built in - is there a way to do this? Thanks
  • Microwave Ovens Master
  • 9,098 Answers
The manual will probably not tell you how to do it, due to liability concerns.
More and more manufacturer's have chosen to stop providing an easy access panel for this.
Instead, you'd have to remove the outer cover to replace the bulb.
If it's a built-in unit, it would possibly have to come out of the wall mount, too.
With a brand and model number, we may be able to give you more specific advice, along with important safety tips.
Posted on Nov 05, 2007
How to change the bulb for kleenmaid wall oven model T055x
Changing the bulb
Warning: disconnect the appliance from the power supply before replacing the bulb
- Turn the cover one quarter turn to the left.
- Unscrew the bulb and replace it with a heat-resistant (300 °C) bulb of the same size with an E14 base - 15 W.
Aug 12, 2017 | Microwave Ovens
How do I change the light bulb in a JES 1451 ?
On this model, it's not meant to be a user serviceable part.
You would have to remove the outer cover, and then the light bulb is located on the air duct attached to the magnetron on the right side of the innards.
You can find helpful exploded views and order the bulb assembly from the Pros here.
Enter your full model number from the tag with suffix and no spaces.
See these help files on safety and disassembly first.
Nov 30, 2012 | Microwave Ovens
Change oven light on PanosonicNN/SD446W
If your owner's manual doesn't refer to changing a bulb, then you will have to disassemble the oven to do so.
See these links before proceeding:
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
Oct 24, 2012 | Panasonic NN-SN657SMicrowave Oven
How to change light bulb on KHMS2050sss
If for some reason you do not have your owner's manual, you can download it here.
If changing the bulb is not covered in the manual, then it will require disassembly.
In that case, you can can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Jun 10, 2012 | KitchenAid KHMS2050SSS Microwave Oven
While changing nightlight bulb, it twisted off and short circuite
In all probability, the short took out the relay on the control board and the control board will need to be replaced.
I hope that helps.
Mar 16, 2010 | GE Microwave Ovens
I have a Hotpoint 1425 over the counter microwave. I am having trouble replacing the two bulbs.
You can download Hotpoint / GE owner's manuals and installation instructions here.
It will cover changing the bulbs.
A circuit board failure can occur if a bulb goes out and the filament shorts, or if the bulbs are removed or installed without first unplugging the oven from the power line.
You can find helpful exploded view diagrams and order parts by entering your full model number (RVM1425XX##) here.
NOTE: FixYa's Web site is currently not notifying us when replies to our Clarification Requests are posted.
So if you need more help, please reply back directly to me with your brand and full model number for free do-it-yourself tips or an estimate if required.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Sep 25, 2009 | Hotpoint RVM1425 Microwave Oven
Changing Microwave bulb
Remove lid, you'll probably need a pozi drive screw driver and a tamper proof torx drive.
The bulb is located near the front.
Mar 15, 2009 | Microwave Ovens
Changing light bulb in microwave oven
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Oct 11, 2008 | Magic Chef MCD1311ST Microwave Oven
How do you replace a light bulb in a GE microwave oven model no.Jes1451BJ02?
The first step is to unplug the oven before changing bulbs.
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. It's at http://207.234.249.73/mwd/ge_lamp_replacement.jpg
If that doesn't answer it, please reply back.
Aug 20, 2008 | GE Microwave Ovens
Microwave Ovens Logo
118 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
