Question about Hotpoint Aquarius WF000 Front Load Washer
Fuse keeps blowing
Initially the on/off button stuck in now after getting button out keeps you know why?
  • 164 Answers
Replace the the button, it is shorted to the cabinet
Posted on Oct 29, 2007
Why dose my fuse keep burning the one ander the hood
If fuse keep blowing up, there is a short on the wiring for that particular fuse.
Check the cover on that fuse box and it will normally tell you what number that particular fuse location.
Check your manual of your vehicle and it will tell you what device/comporent is connected to that fuse. Once you figure out what device/component is connected to that fuse then you can start your diagnosis on that particular device/component.
For example, there is one particular fix I've done which the fuse keeps blowing.
I've checked the location of the fuse and check the users manual for that particular fuse and it indicates a cigarette lighter. I've check the cigarette lighter and there was a coin stuck inside the hole which causes the new fuse to blow. Once the coin was removed, the fuse did not blow anymore.
Nov 20, 2016 | Cars & Trucks
My kawasaki f580v lawn tractor keeps blowing fuse to regulator ?
look for short in wiring anywhere near motor or exhaust
Jul 09, 2014 | Garden
1999 silverado stuck in 4lo. fuses keep blowing. how do i get it back into 2whee
isolate the reason for the dead short that keeps blowing the fuse. Look for a broken wire under body on a actuator or a wire that has rubbed through on the transmission .
Apr 23, 2014 | 1999 Chevrolet Silverado 1500
Fuse for cooling fan keeps blowing
check to see if the fan spins freely if it is sluggish or stuck replace the fan motor as it is drawing excessive current and blowing the fuse.
Dec 29, 2013 | Chrysler Pacifica Cars & Trucks
We keep blowing fuses in our popup camper
First you have to write down what fuses are blowing ( writing down makes it easier when checking out system since we are dealing with more than one). After you know the fuses check your fuse box owners manual to see what that fuse controls. We need to know this to go on. The problem is you have a short or an item going bad. You will have to check the items(fridge, microwave, radio etc.). The easiest way to check is know when fuses blow what were you doing cranking up camper using the microwave etc. With this information you narrow down where to look. To eliminate an item unplug it and recheck if problem goes away that item is the problem. Also check wiring at any bends that occur when cranking up camper if that is when fuses blow that could be entire problem since you have multiple fuses blowing as long as all of them started blowing at the same time. Good luck if you have more problems or get stuck supply some additional info and your results and we can proceed further if neccessary.
Sep 23, 2009 | Electronics - Others
2009 e250 keeps blowing 10 amp parking fuse then
if it keeps blowing the fuse you have a short in the wiring
Sep 11, 2009 | 2009 Ford Econoline Cargo
70a fuse in main box keeps blowing
dead short in wiring, maybe or fan moter is stuck or will not turn causing fuse to blow? can you smell wiring getting hot> or brushes shorting in fan moter.
Jun 25, 2008 | 1989 Honda Accord 4 Door
The fuse in the plug keeps blowing. Initially it would run for a while - sometimes 3 or 4 cycles - before blowing. It now blows the fuse the second that I plug in to the socket, even with the on/off button...
Lower the outlet hose into a washing up bowl, it should then Drain. Check the heater to see if it is earthing you get to it by removing the right hand side panel.
Nov 28, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint Aquarius WF000 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
