Question about Nokia 6070 Cellular Phone
During talking Hi ebody, i ahve problem with my new mobile nokia6070, i.e during talking on phone keys of set are pressing automatically, key 5 and 6. due to this i can hear the sound of key pressing also on the end listner can also hear this sound. there is no cahnce of key pressing myself. i bought this phone 5 days ago.Could anybody help me please.....
  • 3 more comments
  • Anonymous Nov 12, 2007
    i have the same prob
  • Gabbus Nov 25, 2007
    Same for me. Had firmware upgrade done at Nokia's but it did not fix it. Nokia centres are not aware of this issue.
  • Anonymous Jan 09, 2008
    same problem, along with 5 other people in the company that i work for.
  • puteri Jan 11, 2008
    i have the same problem it is irritating every time the no 6 will trigger and disturb my conversation
  • Anonymous Jan 17, 2008
    We have recently purchased 170 6070's for our work force and so far we have had 2 back with this problem. But I have only handed out 15 units.
    I have requested information on this issue with Nokia direct and my supplier. I will keep you posted.
    Thanks
    Steve
    Brigadier General:
  • 7,752 Answers
Have the keyboard replaced.
Posted on Jan 18, 2008
I have a Motorola aur12000 Cordless Phone and it does not ring loud.
Hi debora maisonave!
To modify the volume level on your phone please follow this steps:
To raise the volume:
  • During a call: press the key up to raise the volume of the call.
  • When the phone is ringing: Press the key up to raise the volume of the ringtone.
To lower the volume:
  • During a call: Press the key down to lower the volume of the call.
  • When the phone is ringing: press the key down to lower the volume of the ringtone.
Hope these steps help!
Regards
Gaby
Motorola Customer Care.
Feb 11, 2015 | Motorola Mobility Dect60 Cordless W...
Just put new batterys in safe . but safe will not stop bleeping what is the problem
Please follow these steps
Programming a user code
There are two ways to program a user code.
A 1. Press the Program key.
2. Enter the Factory Code. The green LED remains ON
while you enter the 5-digit user code of your choice.
After 5 digits are entered the green LED turns OFF.
(To enter a new User Code, repeat these steps.)
B 1. Press the red button inside the safe. The lock will
beep and the green LED will come on.
2. Enter a 5-digit user code.
Keep your new user code secure.
For your records, please copy it here:
____ ____ ____ ____ ____
Programming a password
2. Press it a second time.
3. Enter your 5-digit User Code. The green LED remains ON.
4. Enter the 5-digit Password of your choice (any combination
except 00000.) After 5 digits are entered, the green LED
turns OFF.
(To enter a new Password, repeat these steps. To erase the
Password, press Program twice, enter your User Code and then
enter 00000.)
Battery replacement
Below When old batteries are removed for replacement, your Password will be voided; only Factory and User Codes will work. To
reestablish your Password, follow the directions above under
Programming a Password.
Key override
If your electronic lock fails or you do not have any codes
available, you may use a key override to access this unit.
1. Remove the battery cover, disconnect and remove the
battery holder.
2. Insert the skeleton key (second set of keys provided)
into the key hole inside the opening for the battery.
3. Turn the key to the right.
4. Turn the four bit key to the right.
5. Open the door.
Signals
Your electronic-lock safe communicates by means of several
audio/visual signals.
Red (Error) LED + three beeps indicates
one of the following:
1. You have pressed Program key out of sequence
2. You have entered an invalid code or password.
3. You have let 5 seconds or more elapse between key entries.
Green (Proceed) LED + single beep occurs
1. After entering each digit of Factory or User Code, or
Password
2. After pressing Clear key
3. After pressing Program key
Green LED only
1. Comes on after you enter a valid code/password and
remains lit during the 4-second period in which the safe
can be opened.
2. Comes ON in the Program User Code mode after you enter
the Factory Code and remains lit until you have finished
entering a 5-digit User Code.
3. Comes ON in the Program Password mode after you have
entered your User Code and remains ON until you have
entered a 5-digit password.
Yellow LED
Indicates low battery and will typically not turn ON until
battery has been in use approximately two years or longer.
Your electronic lock automatically performs a low battery test
during each lock use.
If a �low battery� condition is detected the Yellow LED will
come ON and remain ON during each subsequent lock
operation. (The lock will continue to function in a Low Battery
state, until battery failure.) The Yellow LED will turn OFF only
after three consecutive Good Battery readings or after the low
batteries are replaced. (Note: If the new batteries are installed
in less than 60 seconds the Yellow LED may come ON and stay
ON during the first lock operation before it returns to OFF.)
NOTE: It is recommended you replace the batteries after two
years, or when the yellow LED remains on.
Jan 09, 2011 | Safe International Electronic Digital Safe...
How to set up Panasonic Answering Machine KX-TG4391
Recording your greeting message You can record your own greeting message (2 minutes max.). 1 {GREETING REC} 2 Within 10 seconds, press {GREETING REC} again. 3 After the base unit beeps, speak clearly about 20 cm away from the MIC. 4 Press {?} (STOP) to stop recording.
Playing back the greeting message Press {GREETING CHECK}.
You can also operate the answering system by pressing dial keys on the handset
Key Operation {^} or {V} Adjust the receiver/speaker volume {1} or {<} Repeat message (during playback)*1 {2} or {>} Skip message (during playback) {4} Play new messages {5} Play all messages {8} Turn answering system on {9} Stop playback*2
Oct 17, 2010 | Panasonic DECT 6.0 Expandable Cordless...
How can i flash format my n 5200
Please try the solution given below to help you solve your problem;
1st turn off ur mobile and then press these keys ;
call receive key, * key, and 3 key .......you have to press these three keys during the powering on of your cell phone.........that's it
Problem solved,be cool!!!!
Aug 03, 2010 | Nokia 5200 Cellular Phone
Hi i hve 5200 and i hve to format it now how can i pls tell me the procedure
1st turn off ur mobile nd then press these keys call receive key * key nd 3 key .......u have to press these three keys during the power on of ur cell..........that's it
Jul 04, 2010 | Nokia 5200 Cellular Phone
I got my nokia n70 firmware deleted during update now it gets freeze
Hai,
Take a back up of you contacts and mails if any.
switch off you phone and press and hold these keys.
calling key + star key + number 3 key hold these keys and turn on you mobile and wait until you see time settings on your mobile.
This should resolve the issue.
Jan 25, 2010 | Nokia N70 Cellular Phone
Phn locked while formattin
*#7780# (*#rst0*) - This will soft reset your phone. It is different from *#7370# because all data, like contacts, calendar and notes, are not removed.
It will only reset the phone settings, such as profiles, themes and shortcuts.
The default lock code is 12345.
or try this(But it will fully format your phone)
Method 1:
Three Finger Reset for Nokia Phone
1. Switch off your Phone.
2. Hold down the following three keys, Green (call answer button) * (Star) Key, and Number '3' key.
3. While holding The Three buttons, press the power button for switch on the phone.
4. Wait for the message 'Formatting' to the screen On Your Mobile and release all keys when you see that message.
Method 2:
Hard Format of Nokia Mobile Phone
2. Now Press following key-*#7370#
3. Enter Default lock code is 12345.
4. While holding All of the buttons, press the power button for switch on the phone.
5. Wait for the message 'Formatting' to the screen On Your Mobile and release all keys when you see that message.
Method 3:
Soft Reset of Nokia Mobile Phone
1. Switch off your Nokia phone
2. Now Press following key sequence *#7780#
Please Note:
The formatting method will erase all of your Phone data.
Please take a backup before you Format.
Jun 08, 2009 | Nokia N81 Smartphone
Unable to put phone in silent in times of need - samsung j700
press <Menu> → Settings →
Phone settings → Phone profiles.
You should see different profiles such as Normal, Outdoor, meeting, etc. Choose the one you want to use. You can change the rings for each of these profiles by selecting the one you want and choosing options/edit.
Apr 21, 2009 | Samsung J700 Cellular Phone
Security code for sony ericsson
your phone is locked or not open line. consult it to a technician.
Mar 12, 2008 | Cell Phones
Headset problem
i think u ahve inserted a stereo head set into nokia 7610 . 7610 supprt oly mono output . use a single ear piece head set . the volume can be incresed by pressing right key during call
Dec 05, 2007 | Nokia 7610
Nokia 6070 Cellular Phone Logo
67 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
