My copier have a system error e0007
Dear sir it problem your copier laser unite
please clean your copier laser mirror then solve your problem
Dead all e007 is related to your fusing unit. If your fixing film (teflon film) is not rolling or turning than machine show 007. Solution for this u just make lubricants on under fixing film and on fusing assembly. If the fixing film break or damage than you replace with new this is another solution enjoy. 09328335835 yuvraj India
SOURCE: system error e007
That code means that the fusing film is out of Home Postion or the film is ripped. You will need to most likely have the fixing film replaced. You are proble going to have to get a service to repair it.
HE PROBLEM IS WITH THE FIXING FILM, IT HAS A SENSOR ON ONE SIDE THAT IS WERE THE FILM IS TORN. REPLACE THE FIXING FILM
SOURCE: I have System error E007 problem in my Canon 2018N
you have problem in fuser section must be chek the fuser film
SOURCE: system error E007
Check out my site under error codes/xerox
http://checkitright.spruz.net/main.asp?page=dp&dis=592197
SOURCE: canono ir2016 system error E007
Fixing film has been displaced e007
Having too much paper in the paper tray will cause your printer to have more frequent paper jams and double printing. Make sure you fill the paper to the fill line. I usually recommend going a little below line. I would also recommend that there is no paper from your previous jams still stuck in there. That will cause it to jam up as well.
SOURCE: System error E007
plz open out fixing assy.then see the fixing film.if it is not well plz change it then your problem may be solved
subrata sen
assistant service engineer
flora ltd bangladesh
07124064585
