Question about Intel Socket 478 CPU COLLING FAN & HEAT SINK up to 3.2GHz
Overclocking i want to increase the speed of my processor i am having a intel(R)4
  • floyd111 Oct 28, 2007
    please help me out as i want to adventure the world of overclocking.
    Problem Solver:
  • 5 Answers
First off... be warned overclocking is not for the faint of heart... now let us begin...
I can't stress this out enough if you plan on overcloking it's worth spending some money on some fan's specifically a CPU fan to make sure it stays cool. A side effect of overclocking is increased heat.
Restart the computer and go into your BIOS. Look for the setting to change the bus speed. Depending on your specific CPU it should be 200 MHz (if it's not don't worry, most computers now are 200 MHz). There should also be an option called the multiplier. This one is usually unavailable. If it is available you have a high-end CPU model that is "unlocked".
The system bus is multiplied by the multiplier and gives you the resulting speed.
200 x 16 = 3200 => 3.2 GHz
IF your multiplier is unlocked you can increase it... it's not then we have to use the system bus.
When you change the system bus it increases the speed of everything in your system... that is the link in between  individual components. But it's a double edge sword... it will cause you system to become unstable more quickly and reduce the maximum overclocking potential.
Increase the bus speed 3~5 MHz at a time. Restart the computer boot into the Operating System and run applications you normally would. If nothing crashes, hangs, freezes, locks up... you can reboot the computer and increase the bus speed again. Repeat theses steps until:
a) reach a point where the system becomes unstable
b) you feel like pushing your system more is getting to risky
This is a very basic answer on how to overclock. For more information, guides and other goodies is a good website for more information and guides.
WARNING: If you push the system to far to fast without doing it gradually you can surpass the computer components limits and cause damage to the computer parts. I am not responsible for any damage that occurs. This is just a guide.
Posted on Oct 28, 2007
I have pentinum4 intel(R) celeron processor 1.3 GHZ processor. I want to increase the speed of my processor without any hardware change. I have 40 GB HD & 512MB with windows XP RAM.plz help
you cannot change the speed of your processor unless your processor supports overclocking. however your processor does not support that.
if your computer is running slow try upgrading the RAM to 1GB.
also check to see whether you have unwanted applications running in the background
Jan 25, 2010 | Intel Celeron D 335, 2.8 GHz Processor
I have a intel dg31pr motherboard with e7200 processor.i want to overclock it.plz help me............
Overclocking is something you should only do if you are fairly experienced with computers. Most motherboards that overclock are made for overclocking as are the processors used. Good overclocking requires a balance of increased FSB, multiplier, increased voltage to the ram and sometimes the processor as well, and excellent cooling. It is easy to burn out your system by overclocking. There are many things you should know first. For that reasion alone it is impossible for me to tell you how to overclock it.
But, go to This is a site made for people who want to overclock. Read and browse through the forums. You will also find some excellent by the numbers guides there. Sigh up and jump in. When you perform your first overclock, come back and tell me. I've been overclocking since 2002.
Nov 05, 2009 | Intel DG31PR Motherboard
Overclocking is set from the BIOS configuration. Not all BIOS allows overclocking, it may need a BIOS upgrade.
Check the ASUS WEB site for your model motherboard.
Overclocking the CPU (ie running at a higher clock speed) and increasing Frontside bus speed will give better performance BUT there is a downside too, if you overclock too high you could overheat the CPU and it could fail.
Sep 01, 2009 | ASUS P5GC-MX/1333 Motherboard
Problem in overclocking my Processor.
1: You problem is your power supply, PSU. When you try to give more power to your CPU by overclocking it, it doesn't have enough wattage, or power, to get the CD drive, or your sound card to work. This is why the CD drive works again when the CPU isn't overclocked. So, in this case, to overclock your CPU, you would have to get more power to your system by getting a more powerful PSU, or one with more wattage. How much you can overclock your processor depends on a variety of different things. Your RAM, PSU, HDD, CD drive, etc. I would not go past about 3.4ghz with your processor, however, a "max overclock" is hard to determine.
2: The maximum temp for your processor is 70C, 158F. I would try to keep your temperatures under 60C to ensure your processor doesn't "die early" on you. The multiplier cannot be changed, only the FSB can be changed. You should be able to create a "profile" in bios and set it to your default so that it loads up automatically when you boot up. Make sure you find a stable configuration before you make a default profile.
Mar 30, 2009 | Intel Computers & Internet
I want a faster processor using the one I have now............
first off, there is no pint in overclocking a celeron, on top of it a laptop, u may just end up ruing every thing.
but if u still insist... there are softwares' which can help u...
please be sure to do proper research and understand well what u are going to do...
visit this to know how to use the above software
Clockgen is another such software... (google it to know more about it)
all the best !
Mar 24, 2009 | HP Compaq WF1907 Monitor
How to overclock a pentume 4 processor
Increasing of FSB (processor clock) from 10% up to 15%.
from 1700Mhz you can get 1850 Mhz.
from 2400 Mhz you can get 2640 Mhz
from 3000 Mhz you can get 3300 Mhz
but not all mater board allow this do.
Mar 07, 2009 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
System speed
Your CPU speed depends on your front side bus speed. Overclock is an option but never recommended. The upgrading ram is cheapest and most noticable upgrade you can do. If your do want to upgrade your computer i would recommend upgrading ram. Remember any computer with a 32-bit processor can only reconize 4 gig's of ram.
Jan 15, 2009 | Intel Motherboard
Overlocked my Intel Pentium 4 3.00 Ghz
You have to go into your bios and see what your front side bus and memmory speeds are. If you overclock you cpu, sometimes you need to underclock your memmory. Say step your memmory down to 333mhz and overclock your front side bus(fsb).
Normally your fsb is 200 and only increase it by mhz. Restart, go into windows. and see if it is stable.
I always use cpu-z and gpu-z to check all of my hardware settings. I use ati tool to overclock my x1950 and it is great. There really isnt any good cpu overclocking tools because its better to do it in the bios.
Do a specific search in google for your processor and overclocking.
Jun 06, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
The 800 MHz seems to be your system bus speed and not the CPU speed. They a related but no quite the same. Overclocking is usually defined as forcing something to operate at a higher speed than it was designed to. If you changed the 800 MHz to 1.6 GHz in your BIOS then yes it could be considered overclocking.
One thing I would like to mention is that when changing clock speeds in your BIOS, do it in small steps, if done in large steps it can cause system instability.
Oct 28, 2007 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
How can I overclock my 166mhz classic computer?
Overclocking is not really recommended to be done by normal users. For overclocking your computer, you should have extensive knowledge of the hardware of your computer.
Overclocking may result in a totally non-working computer, burnt up Processor and motherboard and the likes. Also, overclocking results in heating problems, so you need to have made the arrangements for taking care of this heat issue.
Basically overclocking means increasing the Clock Speed of your comuter. Suppose I say that I have a Pentium 4 - 2.4GHz computer, the 2.4GHz part is the clock speed, which is increase in overclocking. Surely the computers with higher clock speeds work faster but that comes at a price. A small mistake on your part and your computer is no more working.
There are various Forums and sites on the internet that discuss Overclocking and its intricacies in greater detail.
Here's a pointer:
PS: Search google for "overclocking" and you should get a lotta links to work with.
Oct 13, 2007 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Computers & Internet Logo
132 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
