Fusin temperature do not reach the terperature of work in 20 sec. • Poor connection of the fusing unit • Fusing thermistor defective or out of position • Fusing lamp open • Fusing thermostat open • Power supply board defective This condition be clear when entering to service program mode press "Total Clear (yellow key) 1 0 7 and to maintain presed the clear stop key (orange key) more 3 sec.
Comments:
Sep 02, 2009
- Enter SP 5-810 (SC code reset), select execute, select close. Exit SP mode, turn the main power switch off then on.
What code? Try entering service mode then turn off copier and turn it back on. (push these buttons in sequence Clear modes (yellow) 1 0 7 then hold the red stop button for 5 or so seconds you are now in test mode
Was this helpful?
Yes
No
Popular Solutions for Ricoh Aficio 2022 All-In-One
We have ours on the network, and it is set up to forward all incoming faxes to an email address...
(More)
We have ours on the network, and it is set up to forward all incoming faxes to an email address instead of printing. It was working fine, then it started printing faxes, and on the Communication Failure Report, it is saying the error is #1 Hang up or line fail. The email account is good and is reciving emails just fine. How can we fix this.
I Cannot install Ricoh 2022 with snow leopard. I tried to use the drivers I found in...
(More)
I Cannot install Ricoh 2022 with snow leopard. I tried to use the drivers I found in www.ricoh-support.com but they are for leopard (10.5) and they don't work. I also used the drivers I found from apple (ricoh 2022 gutenprint v.5.2.3) but nothing again. The printer seems to be installed but when I try to print something it doesn't go to the printer (usually it stops at 59% in the quew). The IP adress is right and checked and the printer is on. Do you have any idea? Thanks
Everything I print from my Brother HL-5240 printer comes out with both sides of the paper/check...
(More)
Everything I print from my Brother HL-5240 printer comes out with both sides of the paper/check curled up.
